Question about Frigidaire 24 in. FDB510LC Free-standing Dishwasher
Frigidaire Dish washer MODEL
Frigidaire Dish washer MODEL #FDB750RCSO
PLENTY OF WATER IS ACCUMILATING IN THE DISHWASHER BY ITSELF AND SITS THERE UNTIL I TURN ON THE DISH WASER.It is happening frequently.
    Sergeant:
  • 311 Answers
Hi there aaliyazaidi2.is the water clear or dirty that you find in the dishwasher?there are two ways this could be happening.1,if the water is dirty[although it dose not have to be ,but its a sure clue]its you drain line of your dishwasher.what happens is because the drain line is lower than the sink drain, when you use your sink water runs by way of gravity in to the drain hose and then fills up your dishwasher,till you drain it or wash a load...to solve this problem you need too make a loop as we repairman call it.get some zip ties ,or what ever[string] and tie your drain hose off at the top off the sink under the sink cabinet[imagin your drain hose as a roller coaster, the hose coming from the dishwasher is the start of the coaster before it goes to the top of the big hill.what you want to do is ,at the top of the roller coaster hill,tie your drain hose to what ever you can under you sink causing a hill so when your hose goes back down ,it ends up into your disposer or what ever plumbing it ends up into.[hay i hope i helped you understand what i mean their];#2,the other way is your dishwasher water valve may not be sealing well. the water would only be clear if this was the issue and could be warm water because its only hot water to the dishwasher.what happens here is because the water valve is not sealing water slowly adds to your dishwasher may be drops at a time,and over the hours gone by it accumulates and the you notice water in the tub.to solve this you replace the water valve.its[most of the time blue,but could be tan or white]under the dishwasher.the water line from your house goes to it.i hope this helps you you can email if you need more help. God bless ,tom
Posted on Feb 25, 2009
  • 117 Answers
Make sure the drain hose is raised 32" above the floor a suitable air gap is installed. This could also be a defective water valve not closing all the way so water slowly enters the dishwasher when it is not on. You will have to have the water valve replaced if this is the case. The valve part # 154637401.
Best of luck
Frigidaire dishwasher leaks from motor
This is caused by the cheap bearing's in the motor. Even after I have replaced my $200.00 motor assembly it still leaks. put a small flat dish under it as the leak should be small and when the dishwasher starts making a loud noise the bearings are gone and I do not recommend replacing motor as it is half the price of washer itself. I myself will never buy a fridgidaire again. However if you do replace the motor assembly it is very easy and there is a video on youtube showing you how. good luck
Mar 25, 2014 | Frigidaire FDB700BFC Built-in Dishwasher
DISH WASHER STARTED BY IT SELF
If the resetting at the household circuit breaker has not proven to be successful, then you would need to contact a professional to have the control board and panel diagnosed for repairs.
Sep 23, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
It lets a little "soaking"
your belt went bad in dish washer replace belt. dont keep runing that like that you will burn the moter up in dish washer
Feb 15, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
My frigidaire dishwasher model # fdb1050remo will not allow wter to run into dishwasher
At the back of the dish washer there is a water valve operated by a soleniod, the solenoid is defective or the valve is frozen, very easy and cheap to replace once the washer is out of the cabinet
Nov 24, 2010 | Dishwashers
We have hard water at our home, but the new dishwasher leaves a thick film on the glasses. We use the rinse agent, but it's awful.
You have to buy a cartridge type water softener and attach it to the
inlet water line of your dish washer. In addition to this there must be
a salt compartment in the dish washer.
Refer the user guide /owners manual and locate. Fill it with the special
dish washer salt. ( Do not use kitchen salt used for food).
The dish washer salt may help to certain extent in softening the wash
tub water inside. Check the switch settings for rinse aid and salt
release settings in the machine. Refer manual!
Oct 01, 2010 | Frigidaire FGHD2471K Builtin Dishwasher
Frigidaire built in dishwasher model PLD2855RFC1. Have to wash dishes pretty much spotless prior to using dishwaser. Glasses come out with what appears to be soap residue regardless if powder or liquid....
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
May 31, 2010 | Frigidaire PLD2855RFC Dishwasher
Dish washer won't drain properly
either you have a blockage inside the drain hose at the attach point under the sink , or possibly somehting stuck in the drain pump itself, preventing proper drainage, the drain pump is acessible form underneath, usually mounted ti the right side of dishwasher, "unplug first HOT WIRES"
Jan 01, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Dish washer that does not pump out the water on it"s final cycle
I had this same problem and after having the repairman over to our house several times and having the circuit board changed, I figured it out on my own...
It turns out that the pressure created from the steam during the water heating stage (HO) was pushing on the door latch just enough to prevent the motor from running properly. Because the door wasn't latched completely, the water wouldn't drain and the dishwasher would go to the "Drying" cycle without ever pumping the water out of the basin.
I adjusted the levelling on the DW and that helped, but I'm still not sure that the problem is fixed. We may need a new latch assembly.
To test this, when the DW stops running at any time, push on the door. If the motor kicks back on, this is the problem.
Dec 27, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Frigidaire Quietclean I "Not filling with water"
Sounds like you might have forgotten to turn the water on to the dish washer... it happens all the time
Oct 19, 2008 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire ultra quiet I dishwasher
Sounds like the water may not be turned on to the dish washer.
The arm spins with water pressure
Oct 16, 2008 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire 24 in. FDB510LC Free-standing Dishwasher Logo
470 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
