Question about Sharp SF 2020 Copier
On a sharp SF-2020.. I get a U5 code with 01 subcode...
What is the problem and how can I repair it? Please help.
  • Anonymous Apr 04, 2009
    Getting a U5 code on the Sharp SF 2020 copier.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 30 Answers
U5 indicates the ADF can't communicate, make sure the ADF is pluged into the copier. MAKE SURE TO UNPLUG COPIER BEFORE CKECKING ADF PLUG. If all is good then main board is bad.
Posted on Feb 25, 2009
Error f1 en sharp sf 2530
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} F1 00-sorter communication trouble detected
01-paper jog malfunction detected
02-transport motor malfunction detected
04-indexer lower limit detected
05- indexer upper limit detected
06-shift motor malfunction detected
Aug 01, 2010 | Sharp SF 2020 Copier
We have a Sharp SF 2020 copier - can we use it as a printer?There are no ethernet or usb ports on the copier. Is there a jet-lan type of card for it?
No( There are no Sharp SF 2200 Ethernet and USB- ports, There is no a jet-lan type card. sorry. For you any help((
Sharp 2020 Code Description CC Original detection problem CH Lit Steadily: Sorter not installed, or not turned on CH Flashing: DV unit not installed, not connected properly, or not latched in place properly F1 Sub code 00: Communication error between main board and sorter. Sub code 02: Sorter transport motor drive. F2 Sub code 31: Image density sensor. Could be a problem with light level. Sub code 32: Drum mark sensor problem. . Does not see mark on drum or sensor not working properly. H2 Sub code 00: Fuser thermistor open. H3 Sub code 00: Fuser temperature too high. H4 Sub code 00: Fuser temperature too low. Lamp, thermal switch, connections. L1 Scan forward problem. Motor, sensor, board L3 Scan forward problem. Motor, sensor, board. L4 Drive problem; main motor, gear, sensor, bind. L5 Lens problem. Motor sensor board. L8 Sub code 01: Zero cross. P Paper feed problem or no paper PC Card counter not installed U2 Sub code 01: Memory loss. U4 Sub code 00: Communication problem between copier and duplex unit. U5 Sub code 00: Communication problem between main board and ADF.
Mar 12, 2010 | Sharp SF 2020 Copier
Sharp copier SF-2025 displays an error code U%.
Hello sir; It can be reset by power on and open the front door, press and hold exposure key while you closing front door.
Sep 29, 2009 | Sharp SF 2020 Copier
AE Code on Sharp SF2025, What means?
exposure lamp or exposure fuse
Jun 08, 2009 | Sharp SF 2020 Copier
Melted exit rollers SF 2020 Sharp copier
Please.....do yourself a favor, and call a service tech.
Feb 27, 2009 | Sharp SF 2020 Copier
I have a Sharp SF-2030 copier and it is diplaying a F1 code.
F1 FIRST OF ALL CHECK WHAT IS THE SUB CODE .IF SUB CODE IS 00 ITS COMMUNICATION ERROR BETWEEN MAIN BOARD AND FINISHER.IF 01 FINISHER SHIFT PROBLEM.IF 06 FINISHER MOTOR PROBLEM.IF 10 THAT IS STAPLER PROBLEM.DO NOT FORGET TO RATE THE SOLUTION.MIAN JEE
Feb 21, 2009 | Sharp SF 2020 Copier
Sharp SF 2020, how to clear F code
GO ON LINE AND TYPE THE FOLLOWING:
SHARP SF2020 COPIER ERROR F CODE
ENTER
OR
WWW.SHARP.COM/COPIERS
ROD
Feb 10, 2009 | Sharp SF 2020 Copier
Service Mode On Sharp SF2530
A little rusty on this machine, but try this.
This code means you have had to many paper jams in the fuser without removal. Make sure all is clear in the fuser and exit sections.
Then on the control panel you will press a series of buttons as follows.
Press the Clear, Press interrupt, Press Zero, Press interrupt, Enter # 14, Press start, That should reset the machine...
Hope that helps...
Lbcoaster
Jul 02, 2008 | Sharp SF 2020 Copier
156 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
