Question about Symantec Computers & Internet
Taskmanager is not running - Symantec Computers & Internet
  • 537 Answers
Do you want task manager to run? If so, go to start run, then type:
taskmgr <enter>
Posted on Feb 25, 2009
System Idle Process uses 70 to 85% CPU in windows task manager
System Idle is unused CPU cycles, represented by the dark portion of the CPU graph/taskmanager icon. Hard to reconcile your saying CPU usage is 90% in Taskmanager when taskmanager is reporting 87% system idle at the same time. Enabling "show processes from all users" will unhide some running processes but it still shouldn't contradict that 87% unused CPU cycles. On the taskmanager Performance tab is show "one graph PER CPU" enabled?
What was changed in your system between the time these symptoms started and the last time it behaved normally? Did you try a System Restore to a point when it did behave normally?
Are your CPU core temperatures normal or high? Is CPU stepping reducing the core speeds, possibly because of power saving or overheating issues?
Jan 30, 2013 | ASUS Computers & Internet
Tip
Steps to Delete Files Used by another Program in windows
Hi,<br />Follow these steps to delete any files used by another program.<br />1. Right click the windows taskbar and open taskmanager.<br />2. Kill explorer.exe from the taskmanager.<br />3.Click file-&gt;open new task from the taskmanager window.<br />4. Type cmd.exe in the box and command window will come.<br />5. Go the directory of the file to be removed.<br />6. Delete the file using following command<br /> del fileName<br /><br />
on Jan 05, 2011 | Computers & Internet
How to enable control panael,taskmanager
Method 1 - Using the Group Policy Editor in Windows XP Professional
  1. Click Start, Run, type gpedit.msc and click OK.
  2. Under User Configuration, Click on the plus (+) next to Administrative Templates
  3. Click on the plus (+) next tSystem, then click on Ctrl+Alt+Delete Options
  4. Find Remove Task Manager in the right-hand pane and double click on it
  5. Choose the option "Not Configured" and click Ok.
  6. Close the Group Policy Window
Method 2: Change the Task Manager Option through the Run line
  1. Click on Start, Run and type the following command exactly and press Enter
REG add HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System /v DisableTaskMgr /t REG_DWORD /d 0 /f
Method 3: Change Task Manager through a Registry REG file
  1. Click on Start, Run, and type Notepad and press Enter
  2. Copy and paste the information between the dotted lines into Notepad and save it to your desktop as taskmanager.reg
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"DisableTaskMgr"=dword:00000000
3. Double click on the taskmanager.reg file to enter the information into the Windows registry
Method 4: Delete the restriction in the registry manually
  1. Click on Start, Run, and type REGEDIT and press Enter
  2. Navigate to the following branch
    HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ CurrentVersion \ Policies\ System
  3. In the right pane, find and delete the value named DisableTaskMgr
  4. Close the registry editor
For Control Panel
Start | Run | Type: gpedit.msc | OK |
Navigate to >>>
User Configuration\Administrative Templates\Control Panel\
Prohibit access to the Control Panel
[[Disables all Control Panel programs.]]
Jan 12, 2010 | Microsoft Windows XP Home Edition
How to end the process in the process tab of taskmanager?
The majority of those files are supposed to be running. Unless you know which file belongs to which program, I wouldn't try to kill them. Some of those files are drivers that run your sound, video, and other things... some are windows system components and you can't kill them. If there are processes you don't want running you must uninstall the software in add/remove programs.
Mar 26, 2009 | HP Pavilion ze2000 Notebook
My task manager has been disabled due to virus attack. help me
There is a registry hack to enable or disable Windows NT TaskManager. The same registry hack applies to Windows 2000 and Windows XP. Hive: HKEY_CURRENT_USER
Key: Software\Microsoft\Windows\CurrentVersion\Policies\System
Type: REG_DWORD
Value: 1=Enablethis key, that is DISABLE TaskManager
Value: 0=Disablethis key, that is Don't Disable, Enable TaskManager
As part of the enhanced management available in Windows 2000 and Windows XP, rather than risking a registry change, as an administrator you can enable or disable Windows 2000 Pro or Windows XP Pro's TaskManager using Group Policy Editor. This can be applied to the local policy. Note: if you are trying to override your organizations group policy, you can't. As soon as you re-authenticate to the domain, the domain or OU Group Policy will rewrite the registry setting. But if the TaskManager was accidently disabled or you need to control this item for a set of standalone boxes this is for you:
  • Click Start
  • Click Run
  • Enter gpedit.msc in the Open box and click OK
  • In the Group Policy settings window
    • Select User Configuration
    • Select Administrative Templates
    • Select System
    • Select Ctrl+Alt+Delete options
    • Select Remove Task Manager
    • Double-click the Remove Task Manager option
And as I mentioned above, since the policy is Remove Task Manager, by disabling the policy, you are enabling the Task Manager.
Mar 23, 2009 | Internet Grisoft AVG Security Full...
Desktop is not appering on xp sp3
Trying going back to before you have installed Service Pack 3 using System Restore (restart PC > let BIOS load > Press F8 > Safe Mode > When it asks you if you want to System Restore accept and load the date before you installed SP3. Try re-installing Service Pack 3.
Mar 03, 2009 | ASUS Computers & Internet
How to remove virus hijack.taskmanager?
Here are versions of a removal tool:
XP - http://www.scanforfree.com/download/hijack.taskmanager-remover.php
Vista - http://orderpage.paretologic.revenuewire.net/plav/download
And some knowledge about the virus:
Hijack.taskmanager is a malware hijacker generally installed on the system through corrupt video and media codec shareware and file-sharing p2p programs, e-mail attachments or via **** adult websites. Hijack.taskmanager can create random malvare records in system32 registry and overwhelm the desktop with **** popups and phony warning messages to threaten users to scan their pc. Hijack.taskmanager rojans can gather credit card, passwords and other sensitivel information and infect your Computer with additional malware.
Jan 25, 2009 | Computers & Internet
Help and support center
Girish,
Open the taskmanager and click the processes tab and look for these processes and end them if they are running.
  • helpsvc.exe
  • helphost.exe
  • helpctr.exe
  • Close your taskmanager and go to start, run and type CMD you will now have the command box open you will need to type each of these lines and hit enter after.
    net stop helpsvc
    cd /d %windir%\pchealth\helpctr
    rd packagestore /s /q
    rd installedskus /s /q
    cd binaries
    start /w helpsvc /svchost netsvcs /regserver /install
    start /w helpsvc /register
    The line "start /w helpsvc /svchost netsvcs /regserver /install
    " is what reinstalls the help and support service and may take a little while to run.
    Credit for this fix goes to http://windowsxp.mvps.org/rebuildhelp.htm
    Jul 11, 2008 | Computers & Internet
    Taskmanager
    use virus online scanner. you have viruses
    May 05, 2008 | Microsoft Windows XP Professional
    Taskmanager & regedit
    When you press Ctrl + alt +delete, the task manager does not appear? Try right clicking on your desktop tool bar and clicking task manager: For regedit click Start > run and type regedit
    Mar 26, 2008 | Microsoft Windows XP Professional for PC
    Computers & Internet Logo
    18 people viewed this question
    Top Symantec Computers & Internet Experts
    Tony
    Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
