Question about Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
Hydrostatic transmission on Husqvarna LGT2654
Bolt heads shear and belt comes off. too much torque? design flaw?? HELP!! This tractor has just over 30 hours on it.
  • 57 Answers
SOURCE: My Husqvarna Hydrostatic transmission is not
A common problem on mowers with hydrostatic transmissions is the pulley on top of the transmission. Most have splines which wear out. Also make sure fan on top of transmission is turning. Could be overheating.
Posted on May 15, 2009
shadtremonky
  • 353 Answers
SOURCE: Mandrels keep breaking
do not hose it off right after cutting the heat will **** water right into the bearings
this is what i assume sense you have not indicated any impacts to the deck
Posted on Jun 20, 2009
  • 21 Answers
SOURCE: blowing fuses
try unplugging the pto, starting the mower and then engaging the blades. If it still blows a fuse the problem lies in the mowers wiring. If not the problem is the pto. Hope this helps
Posted on Jul 27, 2009
  • 420 Answers
SOURCE: john deere 300 garden tractor hydrostatic drive will not work
check two things, make sure the by-pass rod is pushed all the way in and the drive belt from the engine to the rear end (tranaxle). If both check out ok do not attempt to service the tranaxle at home. have thet serviced by a dealer.
Posted on Jun 02, 2010
rycgl
  • 1545 Answers
SOURCE: need belt diagram on husqvarna
Here is your manual. Please see Figure 5 on Page 7 for the deck belt routing. Other useful diagrams and pictures are in this manual as well.
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2006/HOUS2006_O0602065.pdf
Posted on May 02, 2011
Mower wont move forward or backwards and makes a ticking noise when pushed.
Just a thought , maybe the key that locks the pulley to the input shaft on top of the transmission has sheared and the pulley is just spinning on the shaft or the key on the axle shaft that locks the wheel to the axle and that would allow the brakes not to work.
May 19, 2016 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut hydrostatic transmission slipping
first i would check the belt tension also check the belt for oil is so look for the cause of the leak the repair the leak and replace the belt
Jul 30, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have the Husqvarna LGT2554, with les than 30 hours. The drive belt slips off all the time. I have put it on 5 times and nnow purchased a new one and just put that on. I did 4 swipes and it slippped...
THERE SHOULD BE GUIDES, THE LOOK LIKE LONG BOLTS THAT ARE NEXT TO THE PULLEY, THESE NEED TO BE CLOSE TO THE PULLEY TO HELP KEEP THE BELT ON WHEN THERE IS DECK MOVEMENT ,. MOWER OFF , DECK DOWN AND ENGAGED.. SIT THERE AND STARE AT THE BELT AND PULLEYS TO MAKE SURE THERE ALL LOOK LEVEL AND TRUE, THE TENTIONER BRACKET CAN GET BENT EASILY. THIS IS WHAT I HAVE FOUND
Jun 17, 2011 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Need belt diagram on husqvarna lgt2654
May 02, 2011 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Tractor will not pull. Replaced drive belt with no success. Ant suggestions?
put some thought into a new hydrostatic transmission. they are expensive, perhaps as much as buying another mower.
Apr 19, 2011 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Placing the belt on LGT2654
Does anyone have a layout on how the belt goes on the 2554
Jul 14, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Hydrostatic transmission will not engage
Check the drive belt and make sure the relief valve is in the drive position if this looks good you need a new trans or get it repaired.
Sam
Jun 27, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Change hydrostatic transmission oil
we have tractors and, yes any of those drain bolts will work (for best results do both) then after its drained, put the drain bolts back in and top up the level
Oct 27, 2008 | Husqvarna Garden
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
626 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
