Question about Proview PL926WBi 19" LCD Monitor
Computer power button for the monitor blinks blue
My monitor won't turn on and won't turn off. When I disconnect it from my computer it won't go to sleep. When I try to plug in my power it trys to refresh my screen gives me a little picture then shuts off and power button blinks blue. It is only 2 years old. Why would this happen.
  • 558 Answers
There are two reasons for this to happen there are blown capacitors inside the monitor and or there transistors on the board that have failed. both can be repaired.
Posted on Mar 21, 2009
Monitor won't turn on power button blinks blue
Your computer is not POSTing and the monitor has gone into standby mode as it is not receiving a signal from your computer. My published guide entitled My Computer is not turning on!!! Is it dead!!! No POST!!! will get your computer working again!
Happy testing!
damnor01
Nov 27, 2010 | Gateway FPD1975W 19" LCD Monitor
Viewsonic monitor vx2035wm goes black with a steady blue light on power button when the monitor is turned off or computer is restarted. Disconnecting it and letting it sit for a minimum of 24 hours makes...
I've been having the same problems with my Viewsonic.I plug it in and the blue light blinks but there's no picture it's just a black screen.I do know if Viewsonic doesn't repair my monitor I'll never buy anything from them again.I have the LCD Viewsonic 22' Vx2235wm monitor.
Does anyone have any idea what could be wrong with mine?I've bought a new video cable & video card but the monitor still does the same thing?Thanks
Oct 29, 2010 | ViewSonic VX2035WM LCD Monitor
How do I turn it on
Hello.
To power on the Gateway VX750, press the power button on the front. The power button has 3 sides with a "G" in the middle.
The LED indicates the power status of the monitor.
  • Not lit - The monitor is turned off or does not have power connected.
  • Blinks one time and then goes off - The LED blinks one time when the monitor's power cord is plugged into an AC outlet to indicate that power is detected.
  • Lit solid blue - The monitor is turned on and active.
  • Blinking blue - The monitor is in power saving mode. Before entering power saving mode, a message briefly appears.
Hope this helps.
Aug 12, 2010 | Gateway VX750 (Black, Platinum) 17" CRT...
My monitor does not turn on and the power button light keeps blinking ... <my Gateway monitor light blinks blue slowly but the screen is blank
This is usually a sign that there is no signal going to your monitor, check all your cables and then reboot.
Jun 28, 2010 | Gateway FPD2275W LCD Monitor
My monitor will not go back on. There is a green light blinking
Hi ,
In order to isolate whether its the monitor or the compurter tower you can do a self test to check if the monitor is fine .Turn the computer off and then disconnect the cable for the monitor from the back panel of the computer tower.It will be a blue connector with screws on it .Undo the screws and then disconnect it then turn the computer on ,if the monitor is fine you should get a message that would say check input signal or you will have some kind of message on the screen that tells you that the data cable to the monitor is not connected.If u dont get any message that simply means that the monitor has gone bad and needs to be replaced...
hope this helps you .....all the best
May 12, 2010 | Acer AL1916W 19" LCD Monitor
The power button is not working it blinks a green light
Disconnect the display from the Computer and remove its power plug. While the display is turned off, press and hold the power button for 30 seconds. After two minutes connect the power cord and the display cord to the Computer and the power source and turn it ON.
If the power indicator on the display keeps blinking, then it's required to open it up to repair it.
Feb 26, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
VL 1919 power button blue light blinks and screen
Yea I fixed it ..bought a new monitor......I tried the old monitor on two other PC's same problem.....
Nov 23, 2009 | Computers & Internet
Dell E173FP 17" Monitor
I just had the same problem as well - mine happened during a windows update, related? Also, for me the monitor doesn't come one even after disconnecting from computer, nothing, just blinking green light.
Nov 04, 2007 | Dell E173FP 17" LCD Monitor
Dell P1110
Hi, The part where you see some color bars and blinking green led is what we call MONITOR SELF TEST. A diagnostic pattern consisting of four colors (red, green, blue and white) appears, and the LED flashes slowly. this happens when signal cable from the monitor is disconnected from the tower and leaving the power chord for the monitor plugged in. If the monitor works properly on a different computer. then its a problem with the computer's video card sending out signal. im 85% sure that its a problem with your video card.
Oct 02, 2007 | Dell UltraScan P1110 21" CRT Monitor
Proview PL926WBi 19" LCD Monitor Logo
243 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
