Question about Ricoh Aficio 450 Copier
ERROR of My Aficio MP1500 Photocopier
My Aficio MP1500 Photocopier show 16.000.000 copies on counter display.It don't work now. How can I solve this problem
Are you sure about the model number? I believe you may mean MP2500? Regardless, sounds like an NVRam Problem. This unit is what controls the electronic counter, as well as most of system settings. This will require a service technician from a dealer with connections to RICOH.
Posted on Feb 25, 2009
Error 365 what the solution of it
SC-365 Image storage error VI out of specs, drum, drum potential sensor, charge corona, dirty optics FT 7950, 7960, 7970
Nov 24, 2014 | Ricoh Aficio Mp161 Copier Photocopier Copy...
Photocopies are not clear even after increasing image intensity.
if you have over approx. 60-100k copies on the machine it sounds like you may need regular maintaince on the machine.
to check how many copies you have press the user tools/counter button and then press counter.
Jul 13, 2013 | Ricoh Aficio 1045 Black and White Copier
Error U4 no heater ON
You need a service manual to diagnose this problem. Here is a link to cheap manual for your equipment.
http://www.tradebit.com/filedetail.php/225822562-ricoh-mp1500-aficio-mp1600-mp2000-l-service
Jun 20, 2013 | Ricoh Aficio MP 1600 Black and White...
My Ricoh Aficio 1013f has 16,000 copies on it. It
Ask the service agent, what the maintance cycle of the model is. Sound like it needs a periodic service.
This being the drum and some rollers. this will resolve the squeak as well
Good Luck
Mar 03, 2010 | Ricoh Aficio 1013F Copier
MY CANON PHOTOCOPIER SHOW EO30
E030 (The total copy counter fails to operate.)
1)Turn OFF the power, and remove
J104B from the DC controller
PCB. Set the tester range to
x1KW, and measure the
resistance between J104B-2 and
J104B-1. Is it about 500W? NO
Check the wiring from
the DC controller PCB to
the total copy counter; if
normal, replace the total
copy counter.
2)Connect J104B to the DC
controller PCB, and turn ON the
power. Set the tester range to 30
VDC. Does the voltage between
104B-2 (+) and J104A-6 (–) on the
DC controller change from about
24 to about 0 and then to about
24 V when the Copy Start key is
pressed? YES =replace the totalcopy counter.
NO =Replace the DCcontroller PCB
Apr 03, 2009 | Canon NP 6035 Copier
Aficio 551 - error code SC124
Definition- [B]
No encoder signal from the scanner motor
-Possible cause-
• Scanner motor connector defective
• Scanner motor defective
• MCU defective
• Scanner wire, timing belt, pulley out of position
• PSU defective
The screws of the pulley usually are cut that moves the scanner this causes that the car is crossed and that the sensor does not detect the home position. check and corect this defect.
Mar 03, 2009 | Ricoh Aficio 450 Copier
How to Solve Error code SC496 for Aficio 551
hello Sir; You have to empty the waste toner bottle it located right hand side bottom, open the doorlook at "A" area you will see a big narrow plastic bottle pull out a black buckle slide out the bottle, dump the toner,the code will be disappear!
Jan 06, 2009 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
266 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
