When I used the option to "format" my camera, I realized that after this, all of my images were erased. Were my photos really erased or were they placed somewhere else?
Formatting from your camera means, it formats your memory card your using in it. Thereby it will erase everything in your memory card, so u will loose your photo.
Erasing a memory card: when erasing a memory card, individual photos are
deleted from their directories on the card. You can erase one or more
user selected images at a time, or erase all images at one time.
However, any images that you've selected to be "protected" through
another menu option will not be removed during the erasure process.
Formatting a memory card: format a memory card sample menuFormatting, on
the other hand, deletes all images from a memory card, even the ones
that may have been protected. It recreates the file system including new
directories and folders where images are saved on the card.
Unlike erasing, formatting improves the overall performance of a card.
Low level formatting: some digital cameras offer a low level format in
addition to the standard format option. With a low level format, all
data on the card is deleted. New directories and folders are also
recreated during this process.
A low-level format of a high speed memory card helps ensure smooth
continuous shooting at a constant interval. For optimal video
performance, it's also recommended that a low level format be done
sometime prior to recording.
In camera, not computer: though opinions vary, many recommend formatting
a memory card in a digital camera, not via a computer. If you plan to
use a memory card that was previously used in another camera, format the
card in the new camera before taking any shots.
Hope this helps and just keep in mind that your feedback is important
and I'll appreciate your time and consideration if you leave some
testimonial comment about this answer.
Make sure the picture you can't remove isn't locked. When you're in review press menu and make sure that photo isn't set to locked (if so unlock and you should be able to delete it).
If that doesn't help, make sure you copy off all the images on the card you want, as the following instructions are intended to clear the entire card.
After you transfer all the images you want, you'll want to format the memory card. This can be done one of two ways. If you have the appropriate card reader on your PC, you can insert the card, find it in my computer. Then right click it and select format.
The easier way is to use your camera's format feature. I don't have that specific model, but it can usually either be found in menu, or by pressing the picture review button and then menu. Formatting the card should erase all the data on it and clear off the picture you don't want.
Please leave feedback if this was helpful. Thanks.
The best way to delete all photos from the card is to format it. This prepares it for further use. FixYa is full of people asking how to salvage pictures from cards that haven't been formatted regularly.
You can download the manual from the manufacturer's web site at www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a1100_is
Please format the memory stick using the formatting tool to delete all the contents of the memory stick. This camera does not have the option to select multiple images and then delete them.
You may try to format the memory card. You can use either your camera or a computer to format the memory card. To use your camera - select the option (under Menu) to format the memory card. When using a PC - go to My computer, right click your camera or the memory card an select Format. This will wipe out all data in the card.
Your camera creates folders on the SD card to hold the images. It puts about 100 images in each folder. (See page 111 in the User Guide.) When you erase images, it may only be erasing the images in one folder. But your computer still sees the images in the other folder(s). To completely erase all images, use the "Format" function (see pages 25 - 26 in the User Guide). To completely clear it, use the Low Level Format option. You can download the User Guide here.
Press the trashcan button to erase a single image. Press and HOLD the trashcan button for the option to erase many images, all images, or to format the SD Card. It is good to Format the SD Cad from time to time after downloading the images to clear all residual memory files (even if you do not see them).
You can use the MEMORY FORMAT functions to completely delete all images and options on the Memory Card, including protected images.
* The format function restores the Memory Card to its initial state.
* The Memory Card supplied with this camcorder has been formatted already.
Attention
If you execute the MEMORY FORMAT function, all images will be erased completely and erased images cannot be recovered.
1. Set the mode switch to MEMORY CARD.
2. Set the power switch to PLAYER mode.
3. Press the MENU button.
4. Turn the MENU DIAL to highlight MEMORY and press the ENTER button. The sub menu will appear.
5. Select FORMAT from the list and press the ENTER button.
6. "ALL FILES ARE DELETED! FORMAT REALLY?" appears on the screen.
7. Using the MENU DIAL, select the item.
NO : To return to previous menu
YES : To start formatting.
8. Press the ENTER button.
If you selected the YES, COMPLETE! appears on the screen when the MEMORY CARD formatting is finished.
9. To exit the menu, push the MENU button.
