Question about Gigabyte GA-8IPE1000-G (MBGA81PE1000G) Motherboard
How much RAM would this System run
I have P4M80P System Man.
System modelAWRDACPI
at the moment I have 1G of ram, would like to run 2G
Thank you Lorraine
  • keyman7 Feb 25, 2009
    Thank you for the help
    Appreciated
  • 33 Answers
Hi Lorraine,
on the manufacturer's website I could find out that your computer's motherboard supports up to 4 GB RAM.
Here's a quote of the Gigabyte's website regarding this type of mainboard:
  1. Type: Dual Channel DDR 400 / 333 / 266 support
  2. Max capacity: 4 GB
  3. DIMM slots: 4
Just let me know if there are any further questions!
Kind regards from Germany,
noris017
Posted on Feb 25, 2009
Will extra computer memory be used if the maximum is exceeded?
Windows XP can't use over 2.1 GB of RAM for applications though up to 4 GB can be allocated. The extra RAM is used for the system only. It shouldn't hurt to have extra there.
Nov 10, 2013 | E-Machines eMachines Desktop PC
T6524 won't recognize all ram
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
Feb 24, 2013 | eMachines T6524 PC Desktop
I have a toshiba satellite A135-S4467 laptop, using two memory slots, totaling 1G. I've bought a Kingston ValueRAM - 2GB PC2-6400 DDR2 Laptop Memory Module. What is the best way to install my new 2G...
Hi, Yes, it would be best to take the old RAM out. I am assuming that this is 1 stick totalling 2GB. Optimally it would be good to have 2 x 1GB modules totaling 2GB, so they could work together. Otherwise, yes, just remove the the old ram and install the new module. If you are running a 32bit operating system, 3GB is all the system can use anyway. Hope this helps!
Jul 13, 2011 | Computers & Internet
I upgraded my memory RAM 2g and added 1g so it makes a 3G of ram but how come when my pc boot up up i can only see 2G ram single chanel. wen i go to my my computer----properties----general under computer:...
Could you please go online and in a search engine type "MAX RAM E-Machines (here put your model #)." Pick a link that secribes your maxi,um ram and if it's only 2GB you'll have your answer. If the max is higher there should be instructions on how to set the computer to acess and show the RAM.
Regards,
Selk
Nov 19, 2010 | E-Machines eMachines Desktop PC
Ram Installation more than 3G ex: (4G or 5G) will read 3.25 G How? i am using 2 units of KVR800D2N6/2G pulse 1G original>
Probably your Operating System is a 32bit. 32bit OS can only read up to 3GB of RAM regardless of the capacity of RAM you install. For example you installed 2pcs of 2GB RAM, that makes it 4GB in total, 32bit OS will only recognize 3GB. upgrade your OS to a 64bit OS and you can upgrade your RAM up to 8GB depending on how much your motherboard can handle.
Sep 15, 2010 | Computers & Internet
Ram upgrade problems
looks like you have the wrong ram for your system Kingston is showing this for your system KVR667D2S5/2G
but try refreshing your bios i doubt it will work but give it a shot with your ram installed just hit F2 to get into bios when starting your computer save and exit that should refresh it
Nov 03, 2009 | ASUS Eee PC 900HD Netbook
WHAT IS THE MAXIMUM RAM OF THIS MOTHERBOARD
• Three SDRAM DIMM sockets.
• Designed to support up to 3.0 GB of system memory
Robert
Please take a moment to rate this solution.. thanks
Feb 01, 2009 | Intel D845WN (KD845WNPAK10) Motherboard
IBM ThinkPad T40 2GB Max RAM
The T40 has two ram slots, you can put a 1g chip in each totaling 2g. If the chip will remove, then it is changeable. Vista needs a minimum of 256 to run, so, when you change BOTH chips to equal 2g it will probably read 1.744g, or it may read the full 2g. If it only reads 1g, then the second slot under keyboard may have malfunctioned. It could also be that the 256 chip is bad and your really only running 512 now. With all that said, in order to achieve 2g, you will need to put a 1g chip in each slot.
Jul 08, 2008 | IBM ThinkPad T40 2373 Notebook
Adding RAM
If it has 4 slots and supports 2Gb max with 2 slots currently populated with 2 x 256mb chips you'll need to remove both those chips and install 4 x 512mb chips to reach the max of 2 Gb.
May 10, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
Increase RAM
You can increase the RAM only if it's DDR2 up to 2g,
Jan 22, 2008 | Computers & Internet
Gigabyte GA-8IPE1000-G (MBGA81PE1000G) Motherboard Logo
546 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
