Question about Linksys Wireless-G Broadband Router
Lost wireless connection
Reset the router to default and now cannot get past id and password box
  • pipefitter67 Feb 28, 2009
    i lost wireless connection to my laptops how can i get it back
  • 537 Answers
Default username is linksys I believe. The default password is admin.
Posted on Feb 25, 2009
Forgot password
If you forgot the d-link configuration password - the default user id is admin and password is admin
If that does not work then below the router there is a reset button use a paper clip to push and hold it down for 20 seconds it will reset the password to default ( NOTE : YOUR ROUTER CONFIGURATION WILL BE LOST IF YOU RESET THE ROUTER)
If you need the wifi password Click on the icon, which is usually next to the clock, and then right-click your connection. choose the wifi connection and right click right click and Select Properties and then check the Show Characters box. Doing this will display the password.
Oct 10, 2013 | D-Link D Link Xtreme N Dwa 552 Desktop...
WIRELESS GATEWAY
How to View or Change Your Wireless Network Password
Symptoms:
You have lost or forgotten the password to your wireless network
You have lost or forgotten the password for the router, access point or other network device
You left the default password or used a weak password and someone has hijacked your network
Depending on the router, you can either view or reset the wireless network password (also referred to as the passphrase or security key) if you can log into the router. Some routers mask the wireless network password, so while you cannot recover it, you can enter and save a new password.
If you cannot log into your router because you have forgotten the router password or your network has been hijacked, please refer to "Lost or forgotten password for router or other device" below.
To view or reset a wireless network password:
Launch your Internet browser and type http://www.routerlogin.net in or http://192.168.1.1 or http://192.168.0.1 the address field for your browser. Enter the router's username and password.
The default username is admin, the default password is password.
From the left-hand navigation menu of the Router administration interface, select Set Up > Wireless Settings
Note: On some routers this option will be under BASIC > Wireless.
From the center screen, you find the current wireless security settings under the Security Options heading.
If the wireless network passphrase is visible, review it and use it to log devices onto your network.
If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
Read more about Securing your Wireless Network.
If you cannot log into your router:
- If you were routed to the NETGEAR website or getting the "Page cannot be displayed" message when trying to login to router, make sure you are connected to the NETGEAR router. Check your wired connection and make sure cable is securely plugged in and LED is on. If wireless adapter is on, make sure you are NOT connected on a different wireless network.
- Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default access information to reconfigure your router settings. NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
See the following articles for more information:
Secure Your Wireless Network: WPA/WPA2 (Recommended)
Reset and Restore a NETGEAR device to Factory Default Settings
Default Password for NETGEAR devices
Jul 19, 2012 | Gateway Computers & Internet
I lost my net gear n150 cd and i want to change my password..
How to View or Change Your Wireless Network Password Symptoms:
  • You have lost or forgotten the password to your wireless network
  • You have lost or forgotten the password for the router, access point or other network device
  • You left the default password or used a weak password and someone has hijacked your network
  1. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  2. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings.
  3. From the center screen, select your encryption type from under the Security Options heading.
    • If the wireless network passphrase is visible, review it and use it to log devices onto your network.
    • If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
Sep 10, 2011 | NetGear WNA1100 WirelessN 150 USB Adapter...
I have a WGR 614 Netgear and have forgotten the password and need this to connect for a Wi-Fi, how can I access my password?
If you have the ID/password to login to the router, use them to login to the router, and then view the current password.
If you have "lost" that ID/password, you need to do a "factory-reset" to reset the router to the "default" ID/password. Then, use these "default" values to login to the router, and then to reconfigure both the "wired" and "wireless" network-adapters, and set a new password for your new wireless network.
Feb 19, 2011 | Computers & Internet
Hey, my name is Wesley Murphy and I'm having trouble with our Netgear g54 wireless router. We just got a lap-top and we're trying to get wireless set up on it. We do have internet, that isn't the problem....
you might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
also
make sure your routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
or
if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
hope this helps
Feb 10, 2011 | Computers & Internet
Lost my password and cannot connect new netbook
hi
  • If you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings.
    To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
  • Step 2reset-password-linksys-router-1.2-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep2 span.image a:first').attr('href','http://i.ehow.com/images/a02/2p/6m/reset-password-linksys-router-1.2-800X800.jpg'); }); Once your router is hard reset, you will need to login and reconfigure it again.
    To reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
    LinkSys Default Password
    On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
    Once you are past the login screen, you are able to reconfigure the LinkSys router.
    You want to go to the management tab and change the administrator password to something else to keep others from accessing your router.
  • Step 3 After changing the administrator password then you will need to enable WEP or WAP security so your nosy neighbors aren't tapping into your wireless network. I am picking up 4 networks with my pc antenna.
  • Jul 21, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
    I lost my password and lost the WGT624 installation CD, how can i get the router to work on a new laptop
    If you have lost the password to access the router page then you have to reset the router
    Ensure that you have all the details regarding your internet connection before resetting the router
    If you reset the router you can run the smart setup wizard and get connected by entering correct information in all the pages of the wizard
    If you are looking for the wireless password:
    Access your router page ( Open Internet Explorer --> Type 192.168.1.1 and enter it--> Login name(default)-admin, Password(default)-password) --> GO to wireless settings,under Wireless settings you will find the wireless password.
    Jan 17, 2010 | NetGear WGT624 Wireless Router
    I had my Laptop worked and it was reset back to out of box
    You need to RESET your wireless router. Her is how: Press and hold the Default Reset button until the test light blinks on (about 10 seconds). Release the Default Reset button and wait for the router to reboot. The default administrator's password is password The default IP is 192.168.1.1 Hope this helps
    Jun 11, 2009 | NetGear RangeMax WPN824 Wireless Router...
    Lost Password to router
    Hold the reset button on the router for 30 second, do not let go of it after the diag LED turns off, continue holding it until 30 seconds have passed. After you?ve done this, the router will revert to factory defaults, all of your settings will be lost. By default the default Password for the router is admin, and there is no User Name.
    Feb 16, 2006 | Linksys EtherFast Cable/DSL and Voice...
    1. Right-click on the icon in your taskbar that represents your wireless Internet connection.
    2. Select "Open Network and Sharing Center." 3. Click "Manage Wireless Networks."
    4. Click the icon that represents the wireless Internet connection you are trying to recover the password for. Select "Properties" from the toolbar.
    5. Select the "Security" tab. check the "Show Characters" box to display the password for that particular wireless Internet connection.
    Get instant Linksys router support at http://www.vtechsquad.com/linksys-router-support/ to fix Linksys router problem.
    Feb 16, 2006 | Linksys BEFSR11 Router
    Linksys Wireless-G Broadband Router Logo
    41 people viewed this question
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
