Question about Maytag Neptune FAV9800AW Top Load Washer
My machine maytag doesnt function , i break open tap
Hi, I break open tap blockade ,my maytag neptune machine FAV9800AW washer , Now the display machine only twinkle´s but it is touch screem and i cant do nothing, machine doesn´t function
Please help meeeeee
  • 149 Answers
Board possible bad
Posted on Jan 14, 2010
Maytag Top load FAV9800AWW won't stop filling with water
water fill valve possibly stuck open/ water level defective sw.
Nov 05, 2009 | Maytag Neptune FAV9800AW Top Load Washer
Cold water continues running even after washing cycle is over
I agree with HawaiiTech. If your FAV6800AW or FAV9800AW has water still flowing with the washer 120VAC power cord pulled then the inlet valve is stuck open. Because you are posting in the Neptune FAV6800AW Top Load Washer forum here is some machine specific info for the FAV6800AW or FAV9800AW TL’s. If you are going to DIY here are the links you need;
The Service Manual for reference. Sears Parts Direct for reference.
See page 35/36 to access, remove and replace the hot/cold water inlet valve.
The part number for the inlet valve is 12002242. There is a Substitution P/N 25001046 you will see that here its item 21 at Sears Parts Direct. If you DIY you may want to consider a local purchase, take your water inlet valve assembly to the parts counter and make sure the 120VAC connectors on the solenoids match up. The water inlet valve is easy to replace just follow the SM.
If your machine type is not a FAV6800AW or FAV9800AW please disregard my post.
Good luck and post back if you have questions or concerns ….Rich… aka dh1200s
Nov 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Neptune TL, stops at the 11 minutes to end and will not go past, I have to shut off, hit spin cycle to finish load
Hello krabby64
Is your FAV6800AW or FAV9800AW failing with error codes dc or UC or both to the Console display? If you are I believe you are experiencing a clutch malfunction with your machine. Take a look at this post and see if your problem is similar.
If you have error codes to the display when the machine fails in the last 11 minutes (I believe start od spin cycle) can you let us know what those error codes are?
Oct 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer won't start, display monitor reas
Is your machine a FAV9800AW LCD display?
If so here are some links for the SM and parts look up.
If you machine is the above type the issue could be related to the Motor which under warranty for 10 yrs. Could be the Motor Controller which is only under warranty for 2 yrs. Maytag Customer service info is in the SM. They will need your serial number off the machine located on the back of the console right side. If you are not a DIY’er I would call Maytag for a authorized repair service call to check out the failure.
Oct 14, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Error code of "dc" on my TL Maytag Neptune
If your machine is FAV6800AW or FAV9800AW the dc/UC errors are caused by a clutch malfunction. Your machine is shutting down with those errors so your Tub Displacement Sensor is working as designed.
Fix the Clutch malfunction and you can wash a single sock or a load of blue jeans and you will not take the dc or UC unbalance errors. See this post for the fix.
Post back if you have questions or need help.
Oct 06, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Won't complete spin cycle, code dc
If your machine is a FAV6800AW or FAV9800AW see this post for a DIY repair/replacement of the clutch in your machine. If this is not your machine model type disregard my post.
Aug 27, 2009 | Maytag Neptune FAV6800AW Top Load Washer
"od" error code Maytag Neptune FAV6800Aww
At 12 years of age, your Maytag may be telling you it needs to be replaced.
Sep 23, 2017 | Maytag Neptune FAV9800AW Top Load Washer
Maytag Neptune FAV9800AW Top Load Washer Logo
102 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
