Question about Dishwashers
Dishwasher drain hose cloggs every couple weekes
I have a dishwasher that is less then two years old and every couple of weeks we have to take the drain hose off and clean out this white gunk because it is clogged do you know what could be clogging this. We have had a plumber come out and roto roter and they could not help!
Thanks, Sarah
  • albert getty
    albert getty May 11, 2010
    it sounds like your running cold water in dishwasher and the white stuff is soap?
  • 117 Answers
Do you have a water softener installed in your home and is the water coming to the dishwasher at least 120F? I have some advice you can read about on dishwashers but it really sounds like a water temperature is.
http://tclaundryrepair.com/home
Posted on Feb 25, 2009
Correct cycle. Get to wash dishes.
Whirlpool Dishwasher Repair Online Manual
www.appliancerepair.net/whirlpool-dishwasher-repair.htmlFREE ONLINE Whirlpool dishwasher repair manual - Diagnose your problem ... Noneed to call an expensive serviceman, and then wait a couple of hours (or ... Common complaints are covered, such as wash quality problems (spotting,
Jul 19, 2015 | Whirlpool Dishwashers
How do I unplug a drain if I do not have an air gap
Is it a plugged problem or is the drain solenoid maybe not working. Do you hear a click when it reaches drain cycle. If not the drain valve or wiring or possibly even the timer is defective. VERY seldom that a drain hose would plug up. Make sue the hose is not kinked also. You may have plugged house plumbing under the sink or etc also.
Sep 12, 2014 | Dishwashers
Dishwasher won't drain. (Kenmore 3380957Rev A) It's been not draining that well for a couple of months, but then a couple of weeks ago, it just won't let the last inch of water out. --I can't see in...
The problem could be the pump, the drain hose or the timer. It will not drain if left to sit. The thing to try first is to put a cup of white vinegar in the machine and let it wash. This may remove sludge or scale blocking the strainer. 2nd take the hose loose at the sink drain and see if it is half clogged with grease or food. Check the hose and the nipple. Last, if it does not work take the bottom off the dishwasher. 4 screws and a plate. look for the pump and see if the hoses are clear. Sears will sell you a manual to repair and test this machine at its Parts Central on line
Jun 24, 2010 | Dishwashers
Kenmore elite dishwasher, less than 1 yr old. Wont drain. I have pressed ''Drain'' on the keypad, motor/pump runs but no drainage. If blocked, where? Can I clear it without having to dismantle and remove...
take a shop vac and attach it to the ond of the drain hose to remove the water and if you are checking the drain pump then it has to be pulled out from under the cabinet.
if the unit is less than a year old just set it up for service it will not cost you anything
Apr 10, 2010 | Dishwashers
Dishwasher not draining
you got a high end GE there unless this happened right after a new garbage disposal was installed you should call someone on this heres a picture of ur wash and drain assy.307 houses 2 check valves 325 is the drain pump which has its own check valve it worth the service call to let a repair man fix this if it happened right after a new garbage disposal was installed the forgot to knock out the k\o its a plug on the g\d were there drain hose hooks to a hammer and screw driver will knock it out hope i helped ya let me know peace.729883f.gif
Feb 24, 2009 | Dishwashers
Need to fix new drain hose to Blanco dishwasher BDW203
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
With this machine you will be better off using service!!!!!!!!!!!!!!!!
For this problem you will need to use factory service!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Aug 28, 2008 | Dishwashers
1 week after installation- is very loud
dishwasher less then 2 months old was really quiet when we purchased now has a loud vibration noise when water is pumping out.
Jul 23, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Maytag Dishwasher Model DWU9200BAB
Do you have an air gap between the disposal and the dishwasher? If not required raise the hose and as high as you can. It must be above the water level in the sink. Try attaching it to the underside of the counter. At some point the hose should be above 32 inches. It the problem is with the dishwasher itself. Don't fix, replace. They are not really designed to last over 10 years. The new ones , especially in the last year or two are a BIG improvement over any older one. So quiet you can't tell they are even running, they clean so much better and are much more energy efficient. Stainless steel interiors are just a fad. The plastic tubs are actually less likely to leak and are by there nature more quiet.
Jul 02, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwashers Logo
88 people viewed this question
Top Dishwashers Experts
