Question about Singer 5050 Mechanical Sewing Machine
Singer sweing machine 5430c not letting the thread on upper portion for sweing and needle is broken. what is the problem and solution of it .
  • Jen Soriano
    Jen Soriano Feb 29, 2012
    where can i buy accessories ,i am living in Pasig City,near Cainta Rizal?
Can u tell me how to overlock with singer 5430 c
Posted on May 29, 2009
Setting of the tention is required
Posted on Mar 06, 2009
Singer 7470 computerised sweing machine is breaking top thread every after1-2 feet stiches plz suggest me wt to do top gthread is not too tight , i cleared all the lint in the bobbin thread is gd qlt
The needle thread breaks
1. The needle thread is not threaded properly
2. The needle thread tension is too tight
3.the needle is bent or blunt
4. The needle is incorrectly inserted into the needle holder
5. The needle thread and the bobbin thread are not set under the presser foot when starting sewing
6. The threads were not drawn to the rear after sewing
7. The thread is either too heavy or too fine for the needle
Jun 15, 2015 | Singer Sewing Machines
I can't figure out what the thread guide is on my singer machine to thread the thread through to the needle?
The biggest problem most people face when having troubles pull the bobbin thread up is one of the following.
Wrong needle size (or broken/bent or otherwise damaged needle)
Needle is not fully set into the needle bar.
Needle is not correctly oriented.
Pulling up the bobbin thread is a simple matter of threading the upper thread, and inserting the bobbin with about 6 inches hanging loose. Grasp the top thread lightly.... turn the wheel counter clockwise one full revolution (the needle will go down and back up.) Just pull the top thread slightly and you should see the loop come through the throat plate. Use something like your scissor point to swipe under the presser foot to help retrieve the bobbin thread.
What is the model of your machine?
Aug 28, 2012 | Singer Sewing Machines
Upper thread will not catch the bobbin thread
make sure to use every thread guide
try a new needle
make sure the bobbin is inserted correctly
if these suggestions don't help & if the machine is still under warrenty take it back & let them check it
Mar 20, 2012 | Singer Sewing Machines
I have a Singer 5430c and the needle plate is broken . I need a new needle plate.
They can be bought for around $28 online. Or else call Singer at 1-800-4singer and order from them
Feb 20, 2011 | Singer 5050 Mechanical Sewing Machine
Singer 5430C bobbins thread always loopy
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Feb 15, 2010 | Singer 5050 Mechanical Sewing Machine
Cut thread in the middle of sewing.
The tension of the upper therad is too tight. loosen it by following the instr in the manual
or the upper thread is notspinning off the feel freely while sewing. Make sure the upper thread is not getting cought while sewing,
Ot the upper thread is incorrectly threaded, remove the thread and rethread the machine.
Good Luck.
Aug 16, 2009 | Singer 7422
Under side of fabric.... the thread is a mess
Remove the thread from the upper portion of the machine.
Place the presser foot in the up position.
Turn the handwheel so that the take-up lever is in the highest position.
Ensure that the upper tension dial/knob is set to 5.
Thread the machine all the way and through the needle.
With the presser foot still up, hold the thread from behind the needle and pull about a foot of thread through. It should pull through with very little resistance.
Now lower the presser foot, pull the thread and you should feel great resistance.
If so, now try to sew.
If not, there is a problem with the upper tensioner.
Jul 20, 2009 | Singer 3116 Simple
The needle is always broken how can i fix my singer sewing machine model 287
Make sure the needle is in correctly with the flat side to the rear of the machine, make sure to thread the upper and lower portions of the machine correctly. If this does not solve your problem
Feb 19, 2009 | Euro-Pro 473
Singer futura CE-100 4 blinking reds lights
This error indictaes that the upper thread is broken. If it is not the sensor is telling the computer the thread is broken. Try tightening the upper thread tension some and rethread the upper thread.
Dec 23, 2007 | Singer CE-100 Futura Computerized Sewing...
Singer 5050 Mechanical Sewing Machine Logo
619 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
