Question about Dryers
Electric dryer drum turns, but getting no heat from coil.
Date: 02-24-09
I have an old Maytag Front loading Electric Dryer, mod.#LDE9334ACE, Ser.# 16901692QK. I checked the coil with multimeter and got continuity (coil good). Next, I would like to check the thermal fuses, but need to know where to connect my test leads on these devices, and more importantly, what test results to expect if they are good versus bad.
Thanks for your help.
Todd
  • 547 Answers
Hi todd not sure of reading you should get please use this site thank you for useing fixya please rate me http://www.partstap.com/
Posted on Feb 25, 2009
There's a slight burning smell coming from the dryer drum.
Some item may have gotten between the drum that rotates and the housing and during the rolling of the drum this item may be heating up from the friction. Check closely to see if you can find anything rubbing on the drum.
Jan 22, 2013 | Maytag PYE2300AY Electric Dryer
I have a maytag dependable care plus electric dryer LDE9334ACE. It has started to make a high pitched squealing noise. I have tried to get into it to check to see if it might be a belt. No idea how to open...
That squeal is a wheel. Most likely the one closest to the heating source. I use a product called zoomspout oil because it is safe for dryers.
Your dryer has glides on it similar but not exactly like this.
check and see if they need to be replaced. They pinch and bind when the plastic wears out.
If that belt gets down in the tub groove you is gonna have trouble. The slick side goes to the tub on this puppy also.
Old school Maytag dryer repair manual
Jan 30, 2011 | Dryers
I have a maytag electric dryer and it will not heat and dry clothes. The type number is DWSR-ELE-2406026-CV54. Mod # MED5800TWO SER - MV4920498 The owners manual does not have any trouble shooting...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 21, 2010 | Maytag Dryers
Dryer is Electric. spins clothes but no heat?
What is the setting on for example towels,check lint trap in back when dryer turns does the back of drum turn red,look through door and watch. If you still don't feel heat its the coil,It should be under warrenty.
Jul 26, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Dryer does not get hot
There are a number of things that can go wrong on an electric dryer that will make it not heat...
Check out this tip that I wrote about that problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Mar 31, 2010 | GE DBSR453EBWW Electric Dryer
Maytag electric dryer for months has taken about 3 times to dry a load of clothes now it has quit spinning
Sounds like you have a broken belt.
If you have to replace your drum belt and if you have a front loading machine.
First you will need to unplug your dryer from the electric.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Also you need to remove the back,
Sounds like your other problem is with the heating coil.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
Good luck,
I hope this helps
Oct 08, 2009 | Maytag Dryers
It is making a horrible squealing nose when it runs and takes forever to dry. it is a maytag atlantis 7600 electric dryer.
The squealing noise you are describing sounds like the drum rollers in need of lubrication or replacement.
The problem with the drying could be a faulty heating coil and or faulty thermostats.
If your machine is a front loading machine:
Unplug the power cord to the dryer, remove the front of the machine, this will expose the drum and belt, then remove the drum and belt and this will expose the drum rollers.
Lubricate the shaft of the rollers with a good grade of machine oil like 3 in one Oil. If the drum roller is worn or have flat spots on them, then you may need to replace them.
Remove the back of the machine and this will expose the air tube, find the air tube from the blower to the drum, normally inside this tube you will find the heating coil and thermostats.
Good luck, I hope this helps
Oct 03, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Need help with installing belt in Maytag Electric dryer
if not able to remove rear panel,you will need to start,like most models,take top cover off and hinge back to wall then remove frt cover including door as a whole assy. lift up drum put new belt on drum ( and position in same area as old belt,it will have marks on drum from where original belt was on drum) then put rest of belt over mtr pulley and then idler pulley, turn drum by hand to align belts and put it back together in reverse order
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
I have an Maytag model # MAEDZ600TW2 Epic Z Electric dryer , the drum turns but no heat , circut breakers were checked , lint screen is clean , btw , date of purchase was 3/23/09
There are 2 common reasons your dryer will not heat.
1. Your limit switch is out on the dryer not allowing the heating element to switch on.
2. Your heating element is out.
before you try to fix this yourself it should be covered by warranty.
Apr 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Dryers Logo
85 people viewed this question
Top Dryers Experts
