Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
How do you adjust the tension of the v-belt on the u6630-900
I am replacing both belts on my vacuum cleaner but the v-belt is still a little loose and I am trying to adjust the tension if at all possible. I am lost at to how to take the hood assembly cover off. Please Help if possible.
    President:
  • 389 Answers
Hi! I'm not so familiar with this model, but I believe the V-belt is only under tension when the brush roll  control is in the "HARD" or "OFF" position. I'm not sure what the exact mechanism is, but I suspect that moving the control to the "ON" position is what places the belt under the correct tension and thus drives the roller.  Please let me know if I'm right! As for your other point, not sure what you mean by the "hood assembly cover" or why you might want to take it off. If you can clarify, I'll help if I can.
Posted on Feb 25, 2009
    Problem Solver:
  • 5 Answers
Once you get the screws out, there are very small plastic clips molded into the hood that clamp to the clear plastic. these are located on the outer edges in about the middle of the sides. get a bright light and you will see it will be obvious.
Posted on Apr 22, 2009
    New Friend:
Make sure brush setting is ON (carpet) not OFF (floor).
Posted on Jan 19, 2013
I replaced both belts on rollers after the drive belt broke and now the rollers do not spin when I try to operate it. Is there a reset button I am not seeing?
It sounds like the belts need adjusting. The instructions that came with the belts should explain how to adjust the belt tension. Additionally check for debris around the brushes. This may be the reason for the belts breaking to begin with. Without the belts on the brushes should turn freely by hand. If that doesn't do you can call Consumer Care 1-800-237-7691. Hope that helps.
Nov 14, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
How to repair windtunnel hoover agitator that will not turn
Likely a broken belt. Also check the agitator brush roll bearings (in either end under the end caps) for hair, strong, thread, etc. as this will make the brush roll harder to turn and wear/break belts prematurely. If all these check okay, then observe the tensioning roller that causes the V belt (runs from the idler pulley to the brush roller) to be sure it is swinging down when the handle is released to hold tension on the belt, causing it to rotate. These tensioning rollers can break, but often are locked into the "Bare Floor" setting without the user noticing. Slide the carpet brush roll selector (located on top, next to the floor height slide adjustment) back and forth and make certain it is all the way into the "Carpet" setting to allow the tensioning roller to engage. [Note: The tensioning roller is always retracted (in the neutral or off position) when the handle is in the upright position. You must release the handle to allow this tensioing assembly to engage.]
Sep 05, 2014 | Hoover Model U6485900 Upright Vacuum...
Why doesnt bissell carpet cleaner brush turn properly
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Aug 06, 2014 | Bissell Carpet Cleaner Powerbrush Deep...
I just replaced my hoover belt and it is too loose to make the brush spin. Is there an adjustment to tighten the belt
Greetings from GoVacuum,
The belt is going to be loose as long as the vacuum cleaner is in the upright posistion. If you have the vacuum cleaner with the handle locked in the upright setting, then the belt will be tight around the skinny belt. Once you release the handle of the vacuum cleaner, you can watch as the belt tightens over the roller brush. There are numerous problems with this particular model. We have recorded a very helpful video review of how to replace the belt, and do basic maintenace for this particular model. Hopefully this will help you figure out the correct installation, and other maintenance work you can do yourself.
Here's the video;
If this still does not fix the problem, and the brush is still not spinning, please feel free to email me at chris.jones (at) govacuum.com. I'm always more then happy to try and help you fix the vacuum.
If this information helped you, please click the rate this solution by clicking the thumbs up icons in the right hand corner of this solution.
Thank you very much,
Chris Jones
GoVacuum.com
Mar 18, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Beater Bar Belt loose and bar won't turn
Provided that the motor isn't loose, the belt should fit tightly. If you had reassembled the beater bar back in the vacuum improperly, the belt would be tighter, rather than looser. If you are sure that the motor isn't loose and the beater bar was reinstalled correctly, then either tha belt slipped back off the motor shaft, or they sold you the wrong replacement belt.
Jul 18, 2009 | Hoover U6630-900 WindTunnel Bagless...
Belt tension adjustment
If you are looking at the belt while the vacuum is in the upright and locked position, the belt will be loose. The idler removes tension so the brush doesn't spin while you walk away and put heat marks in the carpet. Hit the lever that allows you to move the handle low, like you are vacuuming under the bed, and the belt gets tight.
May 25, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
New Hoover belt nbr 385280-34 installed, belt still too loose.
There is no adjustment. As they wear they cut the groove in the roller deeper. Sure fix,and what Hoover will tell you to do is to replace the roller. If your like me though that isn't any good. so what I did was wind wax coated dental floss into the groove that the belt rides in and in and then put a couple of drops of super glue to hold the end and it works like a charm. Don't put too much in there the belt has to have a groove to ride in.
Belt keeps fallling off
adjust tension of the belt.....u possible need a screwdriver or spanner
Apr 19, 2009 | Oreck XLS700A Upright Vacuum
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
278 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
