Question about Soyo KT400 Chipset MotherboardAMD Socket A CPU, Model "SY-KT400 DRAGON Ultra(Platinum Edition)" -RET... (SYKT400DU)
No beeps, No video but fans and lights come on...
I rescently bought an intel pearl creek clssic series DG31PR motherboard and after assembling it...nothing. The lights and fans went on but the BIOS didnt show because there was no video on top of that the regulatory BEEP was'nt produced by the motherboard speaker.
Oh and the LEDs come on when the power is turned on including the one's on the board and on the case as well. i've tried disconnecting and connecting numerous times....HELP!!! I have the same symptoms here. No video and no beeps (except when I power off case)< but motherboard lights. This system ran fine for a year or so then it slowly started having issues.These may not be in the correct order , but I had onboard sound issues and added a sound card , thenI loat omboard usb ports and added a usb card, then I had a hard drive failure, and finally the video card failed. I replaced the video card and still nothing. The power supply tested fine with my meter. I removed ram one at a time, I have reset the cmos, and still nothing. I am trying to determine whether the problem is the Athlon xp2600 cpu or the board which has no bad physical signs. I have no spares to swap out for testing, Due to the prior failures I am leaning toward a bad motherboard. Does anyone have any other ideas or comments.
Glenn
I have had a Soyo KT400 for many years. My daughter used it in school, and it developed problems. They were cured when I took it apart and vacuumed it thoroughly. I recently decided to use it again, and it would not post. I removed the fan from the AMD heatsink and vacuumed the heatsink directly; the board posted immediately afterward. The problem may be sensitivity to high temperatures at the heat sink, but each time I have had a problem, cleaning has been the solution.
Jan
Posted on Jul 08, 2009
    Problem Solver:
Do you have a graphics card installed in the AGP or PCIE slot on *********** board?
If so take that out and test to see if the computer beeps. If it does it could be your graphics card.
Posted on Feb 27, 2009
The green LED light on the board is lighted. When I push on/off button the CPU fan moves for 1/2 a second .I tried a different power supply, but that did not work. I replaced the CPU fan, but that did not...
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+3+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DG31PR
Any abnormal beeps at startup ???
http://www.computerhope.com/beep.htm
The problem could be a ram module failing, or the graphic card if installed on the mainboard.
Or a short circuit somewhere.
Look also here:
http://www.tomshardware.co.uk/forum/243625-13-turns-wont-boot
Try starting with only 1 stick of Ram, the monitor and the keyboard connected, no other USBs to be connected.
Look also for bad caps on the mainboard:
If they look like this, the mainboard is dead.
It does not pay, to let them be changed.
Good luck
Jan 28, 2013 | Intel DG31PR Motherboard
I have no video driver softwear
here u can choos ur os and download the driver...
Nov 25, 2012 | Intel DG31PR Motherboard
Intel dg31pr motherboard create some problems so that display is not available
The first step is to try video with a different video card.
If this does not work remove the ram and try to power on the motherboard. If the machine gives a series of long beeps when the ram is not installed, it is a good thing. This determines if the motherboard is posting.
If the beep code occurs, try using different ram, preferably that is known to be good.
If the beep code does not occur then the motherboard itself is bad, and short of using a multimeter to determine what component on the mobo is actually bad, a replacement would be in order.
//halfs
May 25, 2010 | Intel DG31PR Motherboard
SIR I M BAYING YOUR COMPANY MOMHER BOARD DG31 DT-11.01.10 I NO FOUND VGA DRIVER SO PLS HELP ME
go here my friend
and download this
Video: Intel® Graphics Media Accelerator Driver for 3 Series Chipset Based Intel Desktop Boards
Jan 11, 2010 | Intel DG31PR Motherboard
I have Intel DG31PR series motherboard with 2GB
The number of the beeps is a specific post
error code and should help diagnose. e.g.:
my computer has 3 beeps to indicate RAM
failure. Note the beeps and find in your manual
or from Intel support.
Here's some help to get started:
Beep Codes
Intel Support
Jul 12, 2009 | Intel DG31PR Motherboard
Intel dg31pr motherboad not booting.
Unhook everything except power and your monitor. Put one stick of memory in and attempt to boot. Post here with results, what power supply you're using, what memory, and what processor.
Jun 07, 2009 | Intel DG31PR Motherboard
No boot, Intel Classic DG31PR, had been working ok
Do you get any beeps sounds when u start your computer? Try removing the memory card and insert it again or try another memory card slot.
Oct 12, 2008 | Intel DG31PR Motherboard
Its the DG31PR bios!
Put a non 45nm CPU on it, update the bios to the latest one , put back your 45nm processor and all should work just fine....this board is awesome.
Cheers!
Apr 18, 2008 | Intel DG31PR Motherboard
Soyo KT400 Chipset MotherboardAMD Socket A CPU, Model "SY-KT400 DRAGON Ultra(Platinum Edition)" -RET... (SYKT400DU) Logo
173 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
