I am looking for 1998 sharp tv manual Model no 27K 6100 Serial 791513
  • 790 Answers
Hi
go to his links www.schematic.com.ua
Thanks
Posted on Feb 25, 2009
NO volume on our 27k-s100
Its likely Mute or a lockout on the audio, if out see if you have the owner manual and or the remote that came with the set, the item seen on screen is a clue.
Dec 12, 2012 | Sharp 27K-S100 TV
OWNER'S MANUAL AND A REMOTE FOR A SHARP SHARP 46'' TV MODEL lc-46s
The mauual you can get from the internet by Googling it will be in PDF format that you can print. The remote use a Universal cheap GE is good and program with one of these codes....
0079, 0123, 0063, 0020, 0004, 0009, 0226,
0266, 0006, 0095, 0122, Low cost approach.
Nov 08, 2009 | Sharp LC46SB54U 46 in. LCD TV
I turn the tv on and after a few seconds it shuts itself back off again. At that point I can't turn it back on until I unplug it and plug it back in. However, when I turn it back on it will again turn...
Possibly the main Power Regulator is damaged!!!
Open the case, then look for anything that burned out, replace it!!!
If still won't start, you need a multimeter, soldering iron, try locate output diode on power regulator board, then measure the voltages, it has 3-4 type of voltages;
first diode it should around 115V-130 V DC.
Second diode it should around 24 V DC.
Third diode it should around 11-16 V DC.
Fourth ( if exist), check diode and should around 5 V DC.
The problems usually start on second diode, if persist, follow the circuit board.
Oct 18, 2009 | Sharp 27K-S100 TV
Tv will not come on , some guy came out and said its the low voltage pwr supply, whats the cost of the supply, what does it look like and is it easy to replace if you know how to handle a soldering gun, tv...
just take your tv to a near w/shop, and ask a tech, to check components, on the power supply.
components like transistors, diodes, ic if any on thepower supply,all eletrolitic capacitors values, and change all changed value capacitors. because if capacitors change values they change oscillation hence increasing current output.
if you do that your set will come back to life again.
Apr 29, 2009 | Sharp 27K-S180 27" TV
How to switch to antenna usage without a remote for a sharp model 27K S100
several answers:
1get the original remote control
2get a universal remote control and maybe you can get menu from there.
3get menu on front panel of the tv and search for the option.
4send the tv to autoprogram. Good luck!
Mar 22, 2009 | Sharp 27K-S100 TV
Need the manual instruction booklet for a 1998 sharp analog tv
this is the website for the USA
http://www.sharpusa.com/SharpHome/1,1959,,00.html
please take the time to give this solution a fixya rating.
clarkco
Feb 25, 2009 | Televison & Video
I need to receive a manual on the operation of my sharp tv
I believe your TV is a LC-32SB24U, not LC-325B24U.
You can download a manual at www.sharp.ca/manuals
Feb 21, 2009 | Sharp LC-32SB24U 32 in. LCD TV
TV will not stay on
You have done everything that a consumer can do. The problem is most likly in the horizontal section of the tv. This will be something for a repair shop to fix.
Nov 10, 2008 | Sharp 27K-S100 TV
Not to switch from air setting to cable setting
Check the cable company website for an updated code list; they may have developed settings for your model.
Aug 24, 2008 | Sharp 27K-S300 27" TV
I am trying to fix a Sharp 27k-s100 television.
Can you use the remote control to change the channels? If not, it may be that to need to reprogram the remote to work with your TV. I just had the same problem. I have GE universal remote and have reprogrammed it to work with my SHARP 27k-s100 TV by following these instructions: http://www.ehow.com/how_9190_program-ge-universal.html The code that worked for my TV is 173. Other codes listed for SHARP are: 004, 006, 012, 029, 095, 111, 112, 113, 122, 171. Good luck!
Sep 11, 2007 | Sharp 27K-S100 TV
Televison & Video Logo
243 people viewed this question
Top Televison & Video Experts
Electro Med Services...
