Question about Maytag Neptune MDG5500AW Gas Dryer
No hot air for dryer
I have a maytag neptune gas dryer. it runs but only cool air comes out
  • suezenss Mar 01, 2009
    I purchased the Maytag Neptune Gas Dryer second hand. It will not heat and I am unable to diagnose the problem. In addition, I can not figure out to get the access panel removed. Please Please assist, thanks!
  • Anonymous Mar 01, 2009
    no hot air. is it a fuse and where is the fuse located?
I would check the air duct discharge real good before taking anything apart! A clog down line will cause the igniter to kick off resulting in blowing cold air! You need to sqeeze the air duct or take it off as lynt is soo light you will not even notice a clog but your dryer will! Good luck!
Posted on Mar 02, 2009
  • 547 Answers
This is most likeky thermostat you can find here
Posted on Feb 25, 2009
I have a Maytag Neptune model number MDG9700A gas dryer...When I first turn the dryer on the dryer will get hot for about minute then the gas turns off and will not heat up again...It glows fine after...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
Aug 01, 2011 | Maytag Neptune MDG9700A Gas Dryer
Maytag neptune gas dryer-gets warm and then air goes cool
The problem is the dryer coils are failing. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help
Jul 19, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune running very hot, even on lowest heat setting
your cycling switch or hi-limit switch is defective they are near the heating element inside the dryer
Sep 01, 2009 | Maytag Neptune MDE5500AY Electric Dryer
two more things you can check are a blockage prior to your lint trap ( you can usually tell by how much air is coming out of the exhaust) and run it on the air only function which should not engage the heat element at all. If you are electrically inclined you can check the power to the element to see if its shorted to an " on" condition this is a bit complicated and dangerous to do so I wouldn't advise it. 220 plug runs one circuit for the element and one for the motor to turn the drum.
Aug 16, 2009 | Dryers
Natural gas dryer running too hot
I suspect you have a blocked air vent. A blocked vent will make you dryer run hot. Most vents get blocked by lint near their exit to the outside. There's usually a screen at this location to prevent small animals from crawling into your house. Often this screen gets clogged with lint. Most vents are designed to allow removal and cleaning of this screen from the outside.
Jun 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune - everything works, not getting hot
check to see if it has an igniter if so that could be your problem.
Nov 22, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune mah4000aww 53314036yk
Check the solenoid. It may be bad. This allows the water to come in.
May 07, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
448 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
