Question about Panasonic PT-52DL10 52" Rear Projection Television
No sound when the tv is on and the mute is turned off
Just started recentley, picture is playing but no sound. turn it up all the way, and sound can faintly be heard. Adjusted all settings that control sound, and nothing changes. Obviousely, the mute is not on either.
  • 1 more comment
  • dmg32 Feb 25, 2009
    yes i do, i have a receiver and dvd/vcr plugged into it. i just tried to play the sound through the in wall speakers from the receiver and switched all settings and still had no luck.
  • dmg32 Feb 27, 2009
    I figured it out. It was a bad coaxial cable going from the wall to the tv. Once i unhooked the cable from the splitter that connects the internet and the tv on the same line, the sound made check noise and i knew it was the cable. Thanks for your help though.
  • Dennis Scroggins May 11, 2010
    Do you have other devices plugged in to this projector?
  • 119 Answers
I still am unclear as to your hook up but lets try this, if you have your DVD/VCR plugged into the TV audio and video and a audio cord from the tv monitor out to an input on the reciever, this way you should hear the sound at the tv and reciever.
However if you have your DVD/VCR plugged into the reciever first audio and video connections made at the reciever you should just have a video cord fromthe monitor out of the reciever to the tv and your audio will come from the reciever
Posted on Feb 25, 2009
Sony Bravia will not unmute
Put a dvd back in and watch it. Try un muting it as the dvd plays.
Jan 02, 2014 | Sony Televison & Video
Samsung tv ct21m17mj
follow this steps and fix it. GOD BLESS YOU
  1. Make sure all power cords are connected.
  2. Try pressing the enter/play key.
  3. Make sure the TV is turned on and the input is set properly.
  4. Make sure the TV source is set properly on the TV (This is probably done on the screen; Check your TV manual).
No sound:
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Jul 17, 2013 | Televison & Video
Sound won't work
If your TV has a picture but no sound, start by checking the obvious such as whether the mute button is on or whether the volume has been turned all the way down.
Next check your cable connections and make sure everything is plugged in tightly.
Change channels to make sure that it's not a technical difficulty with your TV service provider or TV station. Call your service provider to see if they're experiencing issues with their audio.
Try reconnecting the HDMI cable after you turn off the TV.
Make sure your remote is on the correct input, and see if you have sound while playing a DVD or video game.
For a simple troubleshooting checklist, see No sound on TV and get more details on some simple fixes for this problem. I hope this helps!
Sep 13, 2012 | Mitsubishi WD-73735 Television
Mute is on when I turn my vizio on. How do I
The OSD consists of several menu options: Picture Adjust, Audio Adjust, TV Tuner Setup, Parental Controls,PIP Set Up, or Special Features. When in the TV menu, select the Audio Adjust and make sure the mute is off. It may be worth checking the manual which is avialble from: http://www.vizio.com/downloads.aspx
Aug 20, 2009 | Vizio L32 32 in. LCD HDTV
TruTech 19" LCD TV+DVD
I have a sansui 19" LCD TV+DVD
I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there.
The set is not yet 2 years old.
Mar 13, 2008 | TruTech PLV1615T 15 in. LCD Television
JVC T. V. Model # 26505
I can only suggest you check your audio feeds from your VCR to your TV or to your home theater system tuner(if you have one)
Feb 06, 2008 | JVC AV-27230 27" TV
Refering to my last post
Screen will be blue. It Is known as video mute What happens when you play a cassette now? If you are still getting sound, and no picture, then the video heads are dirty. Get a good Wet Type Cleaning cassete and clean the Video heads. Do 2-3 runs of the tape, and check if picture is now visible.
Mar 29, 2007 | Sharp VC-A373U VHS VCR
Panasonic PT-52DL10 52" Rear Projection Television Logo
89 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
