Question about HP OfficeJet 6110 All-In-One InkJet Printer
How to change the ink
How to open the hp 6110 printer to change the ink
    Genius:
  • 2,120 Answers
Pull the black cover open above the paper cassette.
Posted on Feb 25, 2009
    President:
  • 2,692 Answers
4 Suggested Answers
  • 57 Answers
SOURCE: hp 6110 printer
The issue that you are experiencing might be due to various reasons.
The most common reason is an ink cartridge that has one of the following problems:
1.One of the print cartridges is low or out of ink. Black and all three colors must available.
2.The paper has already been printed on or is colored paper.
3.Protective tape on a new print cartridge has not been removed.
4.Contacts on the print cartridge are not meeting the contacts in the print carriage correctly.
5.Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
6.The print cartridge is defective.
Please check the same and try the below given instructions to get the issue resolved.
Using a clean, dry lint-free cloth (a coffee filter works well), wipe the cartridge contacts, from the top to the bottom. The contact area of the cartridge should be rubbed briskly to remove the waxy lubricant material from the gold contacts. The contacts inside the printer may also require cleaning. Using a clean, dry, lint-free cloth, gently wipe the contacts, from the top to the bottom.
Please perform the step given below to power cycle the unit after removing the print cartridges from the printer:
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the USB cable from the computer.
2. Wait 30 seconds.
3. Plug in the power only
4. Repeat steps 2-3 two more times.
5. On the third time after plugging the unit into power, reconnect the USB cable from the all-in-one to your computer.
Reset the All-in-One to the factory default settings :
Note:
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
This should resolve the issue.
Wish you good luck!
Regards,
Lawrence
Posted on Mar 09, 2008
simard2
  • 124 Answers
SOURCE: how to open the hp 6110 to change ink
I will provide you with the Manual on your HP Printer below. Just go to the following Link below!
HP OfficeJet 6110 Owners Guide
Thank you for using Fix Ya!
Have a Great One!
Hope this Helps you out!
  • 73 Answers
SOURCE: where is the ink cartridge located on the HP office jet 6110 prin
if you are to lift the top part of your printer you will see the cartridges inside as shown below:
Lifting the scanner bed exposes the entire paper path and gives your hands plenty of space to replace ink or clear paper jams.
Posted on Apr 11, 2009
Ink name
Heres the link that lets you know the compatible ink for this printer
Supplies for your Officejet 6110
Cartridges, paper, support and specs for your product
http://www.shopping.hp.com/webapp/shopping/supplies_model.do?product_code=Q1638A&aoid=5504&lang=en&cc=us
HP 56/57 Black/Color Combo
Hope I help you a bit
Mar 28, 2011 | HP OfficeJet 6110 All-In-One InkJet...
I don't know how to get out my ink cartige
Paper goes in the bottom tray in between the guides.
There is a handle just above the paper tray to open a door for changing cartridges.
Jul 21, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I am receiving an error message on my HP Officejet 6110 printer screen that prevents the printer from functioning. The message is "Open door. Clear carriage jam and then press enter." I've tried opening...
yes, that is a carriage jam and not paper, the grinding is from the clean station that gets blocked with dried ink and cant move. you need to open the printer and clean the ink off of the clean station so it can clean properly and not cause a carriage jam.
Jun 29, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Where is the ink cartridge located on the HP office jet 6110 prin
Apr 11, 2009 | HP OfficeJet 6110 All-In-One InkJet...
How to open the hp 6110 to change ink
Have a Great One!
Feb 25, 2009 | HP OfficeJet 6110 All-In-One InkJet...
6110 Print Cartridge
There is a handle right below the number keys. Once you lift the top part of the machine the ink cartridges scrolls to the middle of the opening. replace accordingly. The ink cartridge numbers are on the lids so you will know which one goes where.
Mar 03, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
