Question about Casio Office Equipment & Supplies
Can't find the absolute value button on a FX-300MS Plus
SOURCE: I need to find the antilog to -6.80 on a casioi fx-300ms calculat
Alot of people have this doubt, so I might as well make it clear.
Press the 10^x button (while pressing SHIFT, of course; it's exactly above the LOG button) followed by the number whose antilog you desire.
Example :
Let's say we need antilog(-6.8),
1. Press SHIFT, followed by LOG (i.e 10^x); this'll display a 10 on the screen;
2. Type in -6.8;
3. Press "=";
4. This'll display 1.584893192x10^-7 as the solution, which is correct!
5. Bye, lol :P
Posted on Apr 09, 2009
  • 7 Answers
SOURCE: absolutes on FX - 115ES
The absolute value button is "SHIFT", "Abs" (located on the "hyp" key)
Posted on May 03, 2009
  • 7993 Answers
SOURCE: will my casio fx 300ms factor
The FX-300MS cannot handle symbolic algebra. It cruches numbers but does manipulate litteral expressions. Sorry, it does not factor algebraic expressions.
Hope it helps.
Posted on Sep 27, 2009
SOURCE: i do not know how
Hey it is. Okay, so start with a equation: say, y = -(1 |x|). Now type y = -(1 , then press the [OPTN] button, next to the shift. Next press the [NUM] button or F5. The first menu button should be Abs or absolute value. When your done it should look like this. y = -(1 Abs (x)) then graph it.
Posted on Aug 30, 2010
rlekeyii
  • 95 Answers
SOURCE: where is the factorial button on my casio
The key combination is shift, x -1. the button directly below the shift
Posted on Apr 06, 2011
Where is the factorial button on my casio fx-300ms?
Apr 06, 2011 | Casio FX-300MS Calculator
I'm trying to do fractions on my casio fx-300MS S-V.P.A.M. can you help me
if you need to use fractions, look at the symbol the second button beneath the RED ALFA button.
Mar 31, 2011 | Casio FX-300MS Calculator
Can this calculator do present and future value?
No, it does not. You will need a graphing calculator such as the Casio FX-9750G Plus or the newer version FX-9750 GII.
Sep 19, 2010 | Casio FX-300MS Calculator
How do you put casio fx-300MS in degrees mode? please help
To change the default angle unit, you press the [MODE] button a certain number of times until display shows a rectangle inside which Deg Rad Grad appear on the top line and 1 2 3 on bottom line, with 1 under Deg, 2 under Rad, and 3 under Grad.
Press the number key corresponding to your case, 1. All angle values you feed the trigonometric functions will be considered to be in degrees. If you use the inverse trigonometric functions to find angles, the results will be in degrees.
Hope it helps.
Thank you for using FixYa and do not forget to rate this free solution.
Nov 04, 2009 | Casio FX-300MS Calculator
How to calculate calculus problem by a scientific calculator fx-991ms
If by calculus problem you mean derivatives of functions, integrals, extrema and such things, I am sorry to inform you that neither the Casio FX-300MS, nor the FX-991MS can handle them. The newer Casio calculator FX-991ES is capable of performing numerical differentiations and integrations. There also graphing calculators by Casio FX-9750G, FX-9860G as well as by Texas Instruments (TI 83 PLUS/TI84PLUS) that are reasonably performant in that area.
Hope it helps.
Oct 19, 2009 | Casio FX-300MS Calculator
Which keys do i use to put in a logarithmic equation on a Casio fx-300MS?
For logarithms one uses one of two keys
  1. [LOG] for logarithms in base 10. It is in the same column as the F1 key, on 4th row
  2. [LN] for natural logarithms. It is in the same column as the F2 key, fourth row, to the right of the [LOG] key.
No, that is not right. This is for the FX-7400G (as specified in heading). Well too bad. The information is still valid, except for the location on the keypad. That should not be too difficult to find on the FX-300MS keypad.
Jul 25, 2009 | Casio FX-7400G Plus Calculator
Factorial abbrevation on casio fx-9750GA PLUS can't find it!!!!
There is no direct or shifted keystroke for nCr nPr and ! on casio long ago.
You can access to those function using OPTN button; here is how to do...
press OPTN, F6(>), F3(PROB), F3(nCr)
Jun 13, 2009 | Casio FX-300MS Calculator
Absolutes on FX - 115ES
Apr 07, 2009 | Casio FX-115ES Scientific Calculator
Doubts
how to calculate antilog in fx-82MS
Nov 18, 2008 | Casio FX-300MS Calculator
195 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
