Cold water won't shut off.
GE Mod wnsr2100t6aa
    Scholar:
  • 106 Answers
Your inlet valve is defective, can be easily changed. Approach your dealer with your model number he will direct you to the spares shop, or tell you where you can get it.
Another thing to check is whether your exit hose behind the machine is a the correct height, approx 3 feet up before it goes into drain.
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Try these sites
Posted on Feb 25, 2009
GSS25SGMBKBS WON'T FREEZE PROPERLY
need service manual mod DE561 power suppy pn# 1601 1502 or SP-235b
Jul 06, 2012 | GE GSS25SGMBS Side by Side Refrigerator
My Sears Mod. #919.155730 ran for 2 mins. (cold 40*) made loud noise, then started vibrating bad, and stopped building up pressure. Intake is sucking air, but coming out of the little valve oppsite si
pull the heads and check for failed reed/poppet valves
check for a blocked non-return valve at the tank indicates a blockage between the compressor pistons and the receiver tank
Jun 21, 2017 | Craftsman Air Tools & Compressors
HAE A GE WATER HEATER MOD PE50TA. WANT TO INSTALL
Hi .. you would be better off with a double pole switch. That way all the power is disconnected from the heater when the timer turns it off.
Apr 06, 2010 | General Electric GE SmartWater Household...
GE 5 gallon water cooler freezes up cutting off cold water flow.
Model # please. Maybe a damper or thermostat problem b
Nov 03, 2017 | GE Refrigerators
GE Washing Machine That the Water Does Not Cut Off!
your washer valve is sticking, it should probably be replaced
Jun 17, 2009 | GE Profile JTP18 Electric Single Oven
Ge washing machine
does the cold and hot shut off at med. and high?it sounds like your cold water valve solinard is sticking and needs to be changed,(very easy fix,let me know more-mike
Oct 28, 2008 | GE WVSR1060A Top Load Washer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
