Question about Vizio L32 32 in. LCD HDTV
Digital channel numbers are different
How do I re-catalog the channels to the same numbers as before the digital conversion?
  • 718 Answers
The channels for a digital stations are really just "names". Thy will be the number for the old analog channel followed by a "-" and a number 1 through 4. The actually frequency can vary
from the old frequency. You can see this at;
To set up your tv, you will have to connect your signal source (Antenna or Cable) to the set.
Go into the menu and select the Signal source (Channel) to match what you connected.
Go into the menu for scan or auto program and SCAN in the channels in your area.
Now you can watch the stations on your set.
If the broadcast frequency of any station change, you can re-scan it in again. The "name" will not change so the change will be invisible to you.
Posted on Mar 05, 2009
What does RF CH mean?
What is the difference between a RF channel and a virtual channel? The RF channel is the channel that the TV station uses to broadcast its signal. Before the conversion to digital, TV stations were normally identified by their channel number, and most people knew that a particular network was on a specific TV channel. While analog broadcasting was being phased out and all TV stations were converting to digital broadcasting, it was necessary for the TV stations to continue to broadcast their analog signals on their original RF channels, and also broadcast their digital signals on a different RF channel. However, since the TV station used their broadcast channel as part of their identification, they wanted to keep using the same channel number. To allow this to happen, the new digital television broadcasting standards (ATSC) provided TV stations the ability to continue to use their original channel number and also tell the TV set to tune to the new RF broadcast channel when their virtual channel number was selected. The original channel number is called the virtual channel number, and it will be followed by a period and a second number (3.1, 7.1, etc.).
One of the benefits of converting to digital for the TV stations is that they now have the ability to transmit more than one program at the same time on the same RF channel. The number of additional channels they can broadcast is determined by the resolution of the program (SD vs. HD, text only, music only, etc.). The second number in their virtual channel number indicates that one of the additional programming sources from the same TV station is being viewed (10.2, 10.3, 10.4, etc.).
When selecting an antenna, it is important to understand the difference between the RF broadcast channel and the virtual channel. Antennas are designed to receive specific ranges of RF channels, and the antenna needs to be selected for the RF channel you wish to receive. TV stations broadcast in two broad frequency ranges, called VHF and UHF. RF channels 2 through 13 are considered VHF, and RF channels 14 through 51 are considered UHF. In order to pick up the channels, the antenna has to be designed for the correct frequency range. It is very common today to find that TV stations using virtual channels 2 through 13 are actually using RF broadcast channels in the UHF range. Although not as common, some TV stations using virtual channels 14 through 51 are actually transmitting in the VHF range. An antenna designed for only UHF channels will not work effectively for RF broadcast channels in the VHF range, and an antenna designed for only VHF channels will not work effectively for RF broadcast channels in the UHF range.
Apr 09, 2015 | Televison & Video
I keep hearing two people speaking at th4e same time. It's like two different channels
The most likely thing is that there actually are two people speaking at the same time. Different radios have different numbers of operating channels, but it's not uncommon to "run out". Have you tried operating on a different channel? Activating squelch tones and digital security codes doesn't create more channels, it just prevents your radio from squawking when other people are talking. If you disable them, you can monitor any channel, and try to select one that's less busy.
Jan 22, 2014 | Radio Communications
Sony Bravia Digital TV won't tune Channels 350 and 350, can't manual tune wither as it will only accept 2 digit numbers, even though it tunes 201 ...
These numbers are the LCN (Logical Channel Number) assigned by the broadcasters. It will only be at 350 if it is the same channel from a different transmitter. You need to know the 'channel' of the frequency to manually tune it in. You are talking about the program number not the channel (frequency), a common mistake. i.e ABC in Sydney is transmitted on CH12 (226.5Mhz) and the LCN's for each program are 2,21,22,23,24,201 & 201. If your antenna also picks up the signals from the Kings Cross transmitter ABC is CH30 (543.5Mhz), as these are later in the spectrum they are put in the LCN list starting at 350.
May 10, 2011 | Televison & Video
My phone nokia 6700 classis has a hearin problems where the other person can't hear me...i need a solution for it pls
This is not a hardware problem! You're phone has grabbed a oneway voice channel. Report it to your service provider. They probably hv a bad t1 in traffic. (a t1 provides 24 different voice channels for conversations) It's quite possible you keep hitting the same t1 but a different channel.
Mar 09, 2011 | Cell Phones
I have had an outdoor antenna for several years to recieve HD local. Before the conversion I purchased a Samsun HD Tuner. It was working fine will all channels working and guide providing all program...
8 11 & 14 are std definition. All digital channels are 1.1, 1.2, 1.3, etc. You may need to re-align your antenna. Digital is Very Very direct, analog was very scattered. Hope this helps
Jul 08, 2009 | Samsung DTB-H260F
Recent digital conversion - cannot pick up all local channels
Have you gone into your tv's setup and reprogrammed or scanned the new channel assignments?
BTW, what is your tv model?
Jul 07, 2009 | Toshiba 32AV500U 32 in. LCD HDTV
Since all TV chanels went digital, the TV Channel reception and the Weather reception are lost. I only get a recorded message about the T.V. conversion to digital.
Try using the menu function to re-search for channels. The digital changeover moved many channels and you may just need to have the set search for them all again.
Jul 03, 2009 | Sony Televison & Video
Insignia converter only goes to channel 69.
I have seen this issue with another brand of DTV converter. The fix for that unit was to use the menu setup for the initial installation instead of just rescanning. This made the converter regenerate the channel table with the correct channel numbers.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Panasonic PV-V4021 VCR.
An analog VCR can only be used the same way as an analog TV. You should be able to set the VCR to the converter boxes output channel ( 3 for example) and then set the VCR to record that channel at the correct times. Then just tune the converter box to the correct channel. Please note that if you try this while you are at home (recording one thing while watching another) you will wind up recording whatever is on the channel you change to.
Oct 11, 2008 | Panasonic PV-V4021 S-VHS VCR
Directv Samsung problem
I also have directv.At this point,it is a video signal issue on their end.The up conversion is ok at best.Depending on the original video that is probably as good as it gets.The other problem is the wow factor from hd.It is hard not to be critical of the non-hd channels.
Mar 02, 2008 | Televison & Video
Vizio L32 32 in. LCD HDTV Logo
224 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
