Question about Sharp Aquos LC-52SE94U 52 in. LCD HDTV
Sharp Aquos not always starting up immediately when powering on??
I own a Sharp LC-52SE94U, sometimes when turning on my TV, I have to wait for the TV to fire up. I hear the relay click 1, 2 or 3 times and then nothing. Sometimes it fires up right away, no problem at all and then sometimes it starts right after the first click or sometimes after the 3rd. Usually when it reaches the 3rd click the Front lights located on the TV for the POWER and the OPC lights blink. Then I have to power off and power on the TV again and it could start right up.
I am not sure if this is a conflict between hardware (since hardware firing up sometimes appears to help assist the TV in firing up) or dirty power, since my building is not exactly the newest. Other than this issue the TV works great.
My other hardware is a Samsung HTTX75 HTIB, Sony PS3 and Motorola PVR 3416, not sure if the conflict lies in there somewhere.
Any help would be appreciated.
Also I contacted Sharp and they sent out a repairman and of course the TV started up fine while he was here. So he reset the display and it seemed fine for awhile. This issue is hit or miss, but dam annoying, sometimes it will not happen for a week or 2 weeks, then 5 times in a row.
I had the same exact thing happen. I think it's related to a failed firmware update attempt after reading a post on the AVS forum of a guy who also had this problem on this TV. What I did is plug back in the USB drive with the firmware update on it that I had used earlier, and the TV started right up.
Posted on Jul 11, 2009
Tv doesn't power on
Check and replace damaged component/s at its main power regulator board / replace the board as card basis.
Sep 18, 2013 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
MY Sharp LC46D62U wont turn on
Power and OPC LED lights flashes?Common on Sharp LCD tv.Tv is still useable.Tv have Tuner signal board problems.Every times Power and OPC LED lights flashes.Just push the remote power button again and wait.Sometimes Power and OPC LED light will flashes require push power again wait again Power and OPC will flashes two or three time push power button and wait.Must do this two or three time before the backlight will light up and tv work.
Jan 07, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Aquos model LC46D64U...approx 2 years old..Won't power up and get the power light flashing 3 times then the OPC light once..which is repeated...Any ideas...I believe this is quite common with Sharp TV's
I have a Sharp LCD 46 in.tv do this often.Yes,it is.This problems,the tv Tuner signal board have problem,but the tv is still useable.The POWER and OPC light indications flashes.Just push the power switch again,wait see tv turn,not POWER and OPC flashes again,push the power switch agian and wait.Have to do this like 3 or 4 times sometimes,than the tv backlight will come on,tv will work.Don't know but,if u require to pushing power button more 10 or 12 times,the tv Tuner signal board don't take an turn on the tv backlight get the tv to work.The Tuner signal board is dead,time to replaced the tv Tuner signal board.
Oct 18, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Does the sharp Aquos LC-52 support HDCP? I have Dish Network and for some reason can't watch any HD PPV channels, Dish Network says it's a TV issue. Can you help?
DISH Network blocks multiple video outputs on all PPV and most premium content to prevent recording, and they will tell you it is a TV issue. Ensure that your receiver only has one video cable coming out, to only one device (ie HDMI to the TV) and try again.
Oct 03, 2010 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
Sharp LC-52SE94U shuts down and restarts automatically
There is a software update for this model via the Sharp website. Included is a link to the compressed folder. Once you uncompressed the folder there are instructions in the folder on how to install the update. It doesn't specifically say this is a fix but as a TV technician personally its the fist thing I would try.
Link to Sharp software update
Nov 17, 2009 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
Just bought this TV at Frys. Had no instructions
Just visit this link and look for the product manual
http://www.sharpusa.com/products/FunctionGetLiterature/1,1166,34,00.html
Jun 23, 2009 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
Sharp aquos lc-52se94u green screen
If it it new, take it back. The product is not working properly.
Apr 30, 2009 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
Sharp Aquos LC-32D4OU
Comment by Guest, posted on Oct 25, 2008My Aquos has the same problem. I'm not sure how I discovered this, but when I lean the TV forward and hit the power button it will turn on every time. If the screen blacks out and I don't lean it forward when I hit the power button, the screen will just remain blank. It is very weird, but at least repeatable.
- Thank you, Guest. That did it. It definitely seems to be a problem with the TV. Tilting it and hitting the power button helped me get the video back.
Jun 05, 2008 | Sharp Aquos LC-32D40U Television
Lcd sharp tv flashing green light
Try unplugging the unit and while unit is unplugged hold the volume up button and channel down buttons down and while depressing both buttons plug the unit in. Let go of the buttons and the unit should come on in the service mode. There will be a small k on the screen. With the sharp remote press the channel up button once. This should bring up a menu that will show a lamp error line. If the lamp error is = to 5 the unit is in lamp error shut down. User channel down to highlight that line and curser right arrow to highlight the lamp error #. Hit the enter button to clear the lamp errors. Now unplug the unit and let it sit for a minute and plug back in. I hope this corrects the problem. If the unit does not come on by doing this or if it does and you do not find lamp errors the power supply pcb may have been damaged by the surge.
Jan 06, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Aquos LC-52SE94U 52 in. LCD HDTV Logo
379 people viewed this question
Top Sharp Televison & Video Experts
Dave Naylor
Dave Naylor
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
