Question about Nintendo DS Lite Console
Ds broken? Green light blinks, bottom screen flashes, turns off.
Hi, I have a problem with my daughters ds lite. Its fully charged, when I turn it on, the green light flashes, and the bottom screen blinks white for a split second and turns off, light off too. About 2 weeks before this, her volume stopped working, but it worked with headphones just fine. (not sure if this is related). Also, she has an r4, but I have 4 kids who are always switching their r4 cards (they have different games on them...) and its only with the one ds and the others have used that r4. It doesnt work with a regular ds game either, or gb advance game, or no game either, just turns off. Any advice for a fix-it-myself? Or is it dead? Thanks in advance :)
  • 152 Answers
You will have to open it up and desolder the fuse that says, F2, and then solder a small piece of wire onto the two spaces that the fuse sat on in order for you to bridge the fuse because it's probably blown. Then try powering it up. If it works, then you have just repaired it. If it doesn't then there must be another fuse that is blown. Try testing the fuses with a multi-meter. I am guessing that it could be the F1 fuse if the F2 fuse was also the culprit. Do the same thing to bridge the F1 fuse and then it should work.
Posted on Mar 01, 2009
I checked both fuses and are ok? other idea? please help us!!! Regards ;)
Posted on Jan 04, 2010
BROKEN TOP SCREEN
  • redaxium Jan 04, 2010
    TOP SCREEN CRACKED OR RIBBON CABLE THAT CONNECTS IT TO THE MOTHERBOARD IS LOOSE
5 Suggested Answers
  • 8 Answers
SOURCE: R4 CARD FOR DS LITE
just delete games and reload those cards do that all the time, make sure you drag the games into the themes folder.open system folder you will find the themes /games folder in there.enjoy
Posted on Dec 30, 2008
AcroneSF
  • 23 Answers
SOURCE: Ds does not recognise R4
Try eject, blow into the port then reinsert. There is a possibility that your ds has blocked the r4 from being used on that ds.
Posted on Jan 07, 2009
  • 31 Answers
SOURCE: Problem with r4 and ds lite
Try the paper shim trick first. It could be that the older NDSL's slot one contacts have become "sprung" and aren't making good contact.
Cut a piece of paper slightly narrower but longer than the R4. Put it on the non-contact side of the R4 and insert the R4 (with the paper on the back) into slot 1. It may increase the thickness of the R4 such that the slot 1 fingers now make contact.
Posted on Jan 12, 2009
luke87123
  • 14 Answers
SOURCE: r4 stopped working on my ds lite but works on friends one
Email or Call Nintendo or send them your Ds, and they will give you a new one.
Posted on May 27, 2009
My ds lite just switched off and it was charged
Hi, so if you try switching on the ds lite, nothing at all happens ??
Does the green light flash even if it is for like a split second.If it does then it is more likely top be a blown fuse. If 1 of your screens flicker also, this could be your problem as the ds will not start up with a broken screen. Please advise
Jul 31, 2012 | Nintendo DS Lite Console
My problem is that every time I turn on my ds lite the white light flashes and then it shuts off and it's fully charged.
Hi the solution to your problem is
A failed top screen the ribbon had gone
The green light comes on screen flashes an then goes off
I repair nintendo ds lites in the uk
So can sort you out for a reasonable price
Apr 23, 2011 | Nintendo DS Lite Console
My sond ds lite wont turn on and the charge light
Yes, this problem is normally caused by one or both of the fuses have blown on the logic board.
Feb 17, 2010 | Nintendo DS Lite Console
My ds will not turn on
It sounds like one of you're screens has broken. What you have discribed is generally what happens one either the top or bottom LCD screen has broken.
If it is the top screen the bottom screen will flash for 1/2 a second and the DS turns off.
If it is the bottom screen the DS should still turn on but with no reaction from the screens. (the Ds will shut down immediatley after turning on)
Sep 17, 2009 | Nintendo DS Lite Console
Green Light Flashes
Possible you have a defective LCD screen. Could be the upper or the lower. Personally i think the upper (broken LCD Flatcable)
john
Nov 26, 2008 | Nintendo DS Lite Console
DS lite, power is on but nothing happens
Ditto... except my daughter is 10. Both screens remain black, are fully charged and green light stays on for more than 4 minutes.
Sep 14, 2008 | Nintendo DS Lite Console
DS Lite just died but power light still on
before i answer how many times had you charged since you bought the ds
Aug 18, 2008 | Nintendo DS Lite Console
My ds turns on, then a couple of seconds later, it turns off
if the bottom screen flashes it's the top lcd screen (yes the top) is broken
Aug 02, 2008 | Nintendo DS Lite Console
Nintendo ds lite not turning on
see if you need new carger or if it needs new batteries
Jun 26, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
1,824 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
