Question about Electric Stanley Tre500 Staple Gun / Sharpshooter
Staples don't drive deep enough. How do I adjust depth.
Often staple is left protruding out 1/8" or so. Lost manual, and don't know if dial on top is designed to adjust depth setting . Thanks, Robert
  • judyngaryol Mar 22, 2009
    Exact same problem!! Staples don't drive deep enough. Also, don't know what dial's for. Needs more pressure then I have strength. Help!
  • 187 Answers
Http://www.stanleytools.com/default.asp?TYPE=STATICLEFT&PAGE=knowledgebase.htm&LEFT=left_knowledgebase.htm
Go to website and type in tre550 and you will find a copy of a PDF instruction. It is very limited. They also have a tool tips area.
Posted on Nov 13, 2009
  • wire12me Nov 14, 2009
    For some reason, some of my solution didn't show up in my first answer. The dial on the top is the depth setting. Often, the depth setting is knocked off the selected setting while handling the tool. The best bet is to drive the staple/brad in as far as you can and then use a good old fashioned hammer to seal the deal.
What.size staples needed for arrow fastener ct50
Product description
Product description
2750-1378 Features: -Revolutionary design with ergonomic handling.-Easy release drop in loading channel for staples.-Battery contains an easy to read LED charge meter.-Built-in safety switch prevents accidental firing.-Adjustable staple drive with depth of drive dial.-Light weight design for prolonged stapling tasks.-Can use T50 type 1/4'' staples (2750-0719), T50 type 5/4'' Monel staples, T50 type 5/16'' staples, T50 type 5/16'' Monel staples, T50 type 3/8'' staples, T50 type 3/8'' Monel staples, T50 type 1/2'' staples, T50 1/2'' Monel staples, T50 type 9/16''.-staples, and T50 type 17/32'' Ceiltile staples. Includes: -Kit includes case, charger, and tool. Specifications: -10.8 volts.
staples needed for arrow fastener ct50 Google Search
Jan 11, 2018 | Arrow Tools & Hardware - Others
What staples does a black and decker electric stapler 9700 take and where can I buy them?
Hi Stephen,
Of course the manual states to use their staples for best results.
However it does at least state it is designed for a wide variety.
Most hardware stores have a range of staples to choose from.
Home Depot, Harbor Freight, Lowes etc. Try a chisel point this may help penetrate the wood deep enough. All staples are not made the same. So again trial and error may be the quickest route. Fortunately you can purchase small boxes for your testing.
The manual for this stapler is here:
(Page 2 talks about the staples to use.)
Black Decker 9701 Instruction Manual Page 2
Good luck and hope this helps!
Jan 04, 2015 | Arrow Tools & Hardware - Others
Why is my Stanley TRE 500 locking up after stapling a short time. What is the + and - on top for? I have lost my manual.
Make sure you are using the right staples for it. This will prevent lockups. You can also try spraying the staple track with a dry silicone lubricant.
The Plus and Minus is to set the strike pressure. Low for cork board, high for oak paneling.
Here is the manual, the TRE550 is close enough.
Stanley TRE550 Electric Staple Brad Nail Gun
Sep 21, 2014 | Electric Stanley Tre500 Staple Gun /...
How to adjust depth on bostich mk111fs
There is no depth adjustment on this tool -
If the staples are going too deep - most likely the piston (#17) has threaded off the driver inside the tool, you have a broken piston bumper (#62) inside, or the teflon foot pad (#56) on the bottom of the tool is the wrong thickness for the flooring you are using.
If the staples are not driving far enough - most likely you have a broken / chipped driver blade (#21) or the teflon foot pad (#56) on the bottom of the tool is the wrong thickness for the flooring you are using.
Detail
Sep 01, 2014 | Stanley Bostitch MIIIFN Flooring Nailers
Our staples won't go all the way through . We
You didn't list the make and model of your stapler but if it's not driving the staples flush with the surface here are some possible causes:
1. The wood; If you are driving long staples into hardwood or knotty lumber you may have to use shorter staples to see how they set.
2. Stapler settings; Turning the air pressure up isn't the answer to driving staples deeper, it is only harder on the stapler. Most staplers work in the 90 to 120 psi range. The lower pressure you use the longer your stapler will last. Check/adjust the depth of drive control on the stapler to determine where the top of the staple is driven to.
3. Broke stapler; If it's not driving them to the proper depth but the level they are driven to is consistant, you may have a damaged piston o-ring/seal or the end of the driver is broken off. You'll have to go into the gun or take it to a service center to check these things.
Mar 04, 2012 | Air Tools & Compressors
My stanley tre500 shoots like a semi automatic weapon. Is it adjustable? Thanks Nancy
Hi Nancy,
Do you mean it rapid fires, or do you mean fires the staples to deep?
If it fires too deep, the adjustment for that is on the back of the gun. The + and - give more/less depth. Adjust it towards the - direction to get the brad/staple to no penetrate as far.
Thanks,
Handie Andie
Jun 16, 2011 | Electric Stanley Tre500 Staple Gun /...
I am having problems getting the staple to go all the way in -- recovering dining room chair seats. I have lost the manual -- does the dial with + and - have something to do with it? Stanley TRE500...
Hi Rita,
Yes, the + and - adjusts the depth of the staple. You should check the setting periodically as it has a tendency to move as you handle the stapler.
Also, holding the nose of the staple flush and steady on the surface helps to drive them to the proper depth.
Hope this helps. If it does, I'd appreciate a 4 thumbs up, keeps me working... Thanks,
Handie Andie
May 08, 2011 | Electric Stanley Tre500 Staple Gun /...
Setting staples too deep
The depth is set by the bumper and the bumper spacer. Are you sure these were put back in? the air pressure only makes a small difference on the depth...
Mar 11, 2010 | Stanley Bostitch STB-MIIIFS Flooring...
FixYa RainCo R1b 7C -16
Hello; If the gun is AIR operated, adjust the AIR presure DOWN on the regulator on the air compressor tank? If it is electric operated! there should be a depth DIAL (say 1-8, 1 being the least depth and 8 being the most; depending on the hardnest of the item being stapled) trial & error to be tried on a scrap piece first......! hope this helps, John.
Aug 19, 2009 | Staples Tools & Hardware - Others
TRE 500 Staples don't go in deep enough.
Dial controls depth. Set it to "+." Watch out setting isn't accidently changed during use. Tre500 isn't powerful enough for hardwoods, etc.
Jun 04, 2009 | Electric Stanley Tre500 Staple Gun /...
Electric Stanley Tre500  Staple Gun / Sharpshooter Logo
1,630 people viewed this question
Top Electric Tools & Hardware - Others Experts
eddie_brown
Level 1 Expert
Jim London
Jim London
Mike Carew
Are you an Electric Tool and Hardware - Other Expert? Answer questions, earn points and help others
