Question about Toshiba 36A50 36" TV
How to program my cable channels on my plasma Toshiba tv
  • 75 Answers
You could read the oweners manual it will tell you how to do this. Go in the menu and find auto search then hit search or ok or what ever it tells u to do.
Posted on Mar 05, 2009
Toshiba rear projection will not play one antenna channel
How To: TV Auto Program / Channel Scan - TOSHIBA FORUMS
forums.toshiba.com/t5/Televisions...Base/...Channel-Scan/ta.../345660
Aug 7, 2013 - The following article will take you through the procedure to perform achannel ... TOSHIBA television to store channels from a cable TV or TV antennasignal. ... The TV must not be connected to a cable box through the coax ... The Option 1 procedure is for TVs with menus similar to the one shown below. Understanding / Changing Inputs on your TV
Mar 9, 2012
46G300U Intermittent Flickering / Flashing / Pulsa...
Sep 22, 2011
new tv.... dolby digital not working through optic...
Sep 19, 2011
More results from forums.toshiba.com
Missing: rear
[PDF]User's Manual - Newegg.com
images10.newegg.com/User-Manual/User_Manual_24-207-007.pdf
High Definition TV broadcast, a High Definition digital cable program, or a High Definition digital satellite program). For details, please contact your TV antenna installer or your .... 14a) Item 14 does not apply to "Lamp unit replacement and ...... Thank you for purchasing this Toshiba TV, one of the most innovative DLP™ ...
Toshiba 52HM84 DLP Rear Projection Product Review and ...
? 10:43
https://www.youtube.com/watch?v=B4VRJPUmpho
Nov 3, 2012 - Uploaded by Channel 2012
In one of my very last videos before my old account was spontaneously shut down, I covered a decent 52" DLP ...
Jan 24, 2016 | Toshiba 62HM196 62" SD Television
Tip
Toshiba 42HP95 Channel Block Reset
Toshiba 42HP95 Plasma TV Channel Block Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV channel block?
Have you forgotten your channel block PIN, passcode or password?
If you forget your channel block passcode, you can view the locked channels without entering your password:
  • When your PIN is requested, simply press RECALL four times withing five seconds.
  • The channel block passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
________________________________________
Download Toshiba 42HP95 Plasma TV Manual
on Jul 03, 2010 | Televison & Video
Tip
Toshiba 50HP95 Channel Block Reset
Toshiba 50HP95 Plasma TV Channel Block Reset
Would you like to bypass, defeat or reset your Toshiba 50HP95 Plasma TV channel block?
I hope that helps.
Download Toshiba 50HP95 Plasma TV Manual
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Feb 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
How do i program my channels
Hello
Your Toshiba tv can be automatically tuned to all stations. The procedure follows.
Programming channels automatically
Your TV can automatically detect all active channels and store them in
its memory. After the TV has stored the channels in its memory automatically,
you can add or erase channels manually.
To add channels automatically:
1. Press MENU, then press "left arrow" or "right arrow" button to display the SETUP menu.
2. Press "Up arrow"or "down arrow" until the TV/CABLE
selection is highlighted.
3. Press "left arrow" or "right arrow" button to highlight either
TV or CABLE, depending on which you use.
If you use an antenna, choose TV.
If you use cable, choose CABLE.
4. Press "down arrow" button until the CH PROGRAM selection is highlighted.
5. Press "left arrow" or "right arrow" button to start channel programming. The TV will automatically
cycle through all the TV or Cable channels (depending on which you
selected), and store all active channels in the channel memory.
While the TV is cycling through the channels, the message
"PROGRAMMING NOW-PLEASE WAIT" appears.
6. When channel programming is complete, the message "COMPLETED"
appears.
7. Press CH UP or DOWN button to view the programmed channels.
OK.
Dec 14, 2010 | Toshiba 26HF85 26" TV
Tip
I hope that helps.
on Jul 03, 2010 | Toshiba 42HP95 Television
Tip
I hope that helps.
on Jul 03, 2010 | Toshiba 50HP95 50 in. Plasma Television
No tv channels with Philips 42FD9935/17
If you are using a Cable Box, then select the Cable Box option in the TV. If you have connected the Antenna directly to the TV, then select the Antenna option in the TV under Menu options. Try performing the Auto program.......If using a Cable Box, then no need to perform the Auto program. If the issue persists, try resetting the TV to the factory settings and check if it helps.
Jul 25, 2010 | Philips FTR-9964 Tuner/Receiver for Plasma
Recording with comcast hd box and toshiba VCR/DVD
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
Jan 17, 2009 | Toshiba DVR610 DVD Recorder/VCR
Toshiba 42HP66, HDMI problems
Your Cable box might need to be reprogrammed. Call the cable company and they will drive you thru the steps to program it, this way you will get the channels. This process might take you 30-45 minutes.
Artgirlny
Jul 12, 2008 | Toshiba 42HP66 42 in. LCD Television
Toshiba 36A50 36" TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
