My church has two Sanyo PLC-XF30 or XF30NL's. I just added a second wide screen monitor to our Song Show Plus projection software (the wide screen monitor shows the software full time) while my Dell 4X3 monitor shows what projected onto the screen. The two monitor setup is working fine. HEre's my problem: the left hand edge of my slides is being slightly cut off. The right edge and top and bottom are adjusted pretty well now. Our computer resolution is set to 1024 X 768. Can you help with the cut-off left edge? Many thanks, Lew in NM
  • 2 more comments
  • lewking Feb 25, 2009
    Our two monitors are:
    Software monitor: Dell SE 198WFP (new widescreen monitor 16X9)
    Screens monitor: Dell E 173FP (several years old 4X3)
    Lew in NM
    Ekse requested some information, which I posted as a comment, but he gave me no email address to send it to.
    How can I get information to Ekse?
    Lew in NM
  • lewking Feb 27, 2009
    I tried the monitor things you suggested, but nothing changed on the screens. It is definitely a projector problem. I even called the software support team and everything on the software is correct. I tried using some of the projector pc menu adjustments: horizontal settings - vertical settings - but nothing corrected the problem. The software support lady suggested a master reset on the projectors, but I could not find one in the projector manual. Is there a universal reset code for the all video projectors?
    I still have the image cropped badly on the left margin and a little on the top margin. The right and bottom margins are fine.
  • lewking Mar 02, 2009
    I found that in my Auto PC Menu on the projectors, that I could change the Total Dots and correct the alignment problem.
    Thanks for your help.
  • 13,433 Answers
Hey,
Could you send me the model of the monitors? I think you can adjust the cutoff in the monitor settings that are build in, adjust the screen position or width a little. A model would be helpful and I can answer you better.
Thanks,
Ekse
Posted on Feb 25, 2009
  • 2 more comments
  • Ekse Feb 26, 2009
    Hey,
    Thanks I got the comment. Sorry I was away.
    Looking into it now.
  • Ekse Feb 26, 2009
    The recommended resolution for the display is 1280 x 1024 Since its at a lower setting, the screen needs to be adjusted from the buttons on the front.
    First try a Auto Adjust (c button) and see if it corrects the problem, it most likely won't but try it and let me know.
    Then if the problem is not solved, open up the menu from the A button.
  • Perform monitor reset on "All Settings"
  • Push 'Auto-Adjust' button
  • Adjust the centering controls so the picture is shown fully on the display.
  • If this hasn't solved the problem drop me a comment and lets look into it more.
  • Ekse Feb 27, 2009
    Sorry, did you have the problem on your monitor or your projector display?
  • Ekse Mar 02, 2009
    Great to hear.
    Let me know if you need anything else.
    Thanks,
    Ekse
    Picture is blue
    if the projector requires a composite video cable (PbPrY) (3 rca plugins) and you only used a yellow rca video plugin it won't show the video properly
    Oct 15, 2013 | Sanyo Multi-media Prox Projector, Model:...
    My Sanyo tv is not working. The power light comes on and then starts blinking red.
    I myself had a 55 inch hdtv ready projection tv and the lamp went out in it. It cost me $104.00 plus shipping to replace it. Check out discount replacement parts but remember that if it is a projection tv, it won't last but approximately two years and you will have to do it again.
    Aug 25, 2012 | Sanyo SELECT PLC-XP45 Rear Projection...
    Sanyo PLC XU48 Need to know the lamp hours!
    press and hold down the power button for about 20 seconds. The info will show in the top right of the screen.
    Micketec
    May 25, 2010 | Sanyo PLC XU48 Multimedia Projector
    How to fix shadow (stain) projected onto screen by projector Sanyo PLC-SW30
    This could be showing the signs of the lamp needing replacement. if not dust has accumulated (clean filters) onto the mirrors in the projector.
    May 15, 2010 | Sanyo PLC-SW30 Multimedia Projector
    Projects blue screen only and not what is on the computer. Do I need to adjust settings? If so how? I have used it several times successfully, but now not projecting what is on the computer monitor.
    Blue screen is usually a default screen when there is no signal. Check to be sure that you have selected the correct input and that the computer resolution is not beyond what the projector can handle. If you still have problems, please update this and we'll look further.
    Dan
    Nov 17, 2009 | Sanyo PLC XU35 Multimedia Projector
    Sanyo plc sw20a dose not work with my laptop what
    you need to activate the external monitor port on your laptop.
    Oct 04, 2009 | Sanyo PLC SW20A Multimedia Projector
    Have a Sanyo PLC-XU35. For some reason using it
    Have you tried changing the refresh rate. It is located under "Control Panel, Display, Setting, Advanced, Monitor" I have had some success trying this.
    Good Luck
    Sep 24, 2009 | Sanyo Office Equipment & Supplies
    Yellow band on the edge of screen
    Hi chucri
    This is most definitely not a lamp problem.
    If a yellow colour in either stripes or blotches occur it is a blue LCD polarizer that needs replacement.
    May 16, 2008 | Sanyo PLC-SP20N Multimedia Projector
    Sanyo PLC-SW30
    The filters are starting to show their age. This is a normal occurance for projectors and is the result of heat. The filters and/or the mirrors might need to be changed.
    Dan
    May 08, 2008 | Sanyo PLC-SW30 Multimedia Projector
    Televison & Video Logo
    Top Televison & Video Experts
