Question about Casio Exilim EX-S880 Digital Camera
Casio Exilim EX-S880 will not turn on
I used the camera a few weeks ago and it worked perfectly normally. I went to use it again two days ago and it simply would not turn on. I checked to see that the battery was placed in correctly and it was. After, I charged it and no matter how long it is in the dock, the red light blinks as if it is not charging at all. I tried different outlets. All have the same results. In the time between when it worked and when it did not, the camera was not exposed to water, heat or cold, and was not dropped. The warentee was still effective when it worked but ended literally 4 days ago...
  • Anonymous Feb 28, 2009
    I have the same problem. I can review pictures on the camera if it's plugged into the cradle. Other than that I cannot get the camera to operate. I've already purchased another battery, thinking that was the problem, but it wasn't.
  • juliaj Mar 27, 2009
    i forgot to add this: I'm able to see pictures, if I plug it in to the computer
The problem is the spring terminals inside the camera are not making good contact with the battery. I had to use a screw driver and gently push them to the left to make better contact with the battery terminals. There are three connections. I stress that you be gentle. This not the long term fix but you will be able to take pictures in the short term.
Posted on Feb 28, 2009
Can turn on casio exilim but turns off
If you have a beeping sound with no other message it is an indication you have a low battery. How old is the battery for this camera...
May 04, 2009 | Casio Exilim EX-S880 Digital Camera
My Casio Exilim ex s880 wont turn on i have tried everything
you need anew battery...try ebay or battery planet.com for a replacement.
Mar 30, 2009 | Casio Exilim EX-S880 Digital Camera
Battery Problem Casio EX-S880 Digital Camera
Ive had this happen twice. The first time I went back to the store and talked to the tech people to see if it was a problem with the camera itself but ended up buying a new battery. About a week ago, I finally found my charger to plug in the camera that I hadnt used in weeks to find the same problem once again. It must stem from long periods of non use. After finding this question I continued my research and the Casio website tells you to call 1-800-435-7732. Dont know if that helps much but I will be calling them in a little while. Good luck.
Mar 08, 2009 | Casio Exilim EX-S880 Digital Camera
Casio Exilim EX-S880 I put my camera on the charging dock and the orange light comes on. After about 15 seconds it starts flashing. I can't turn my camera on at all. The only way I do is to view them on...
if you try pushing the battery in further it might turn on, if that doesn't work just get a new battery, but make sure to take it out when you aren't using it or this will happen again.
Jan 29, 2009 | Casio Exilim EX-S880 Digital Camera
EX S880 not charging
you have a bad battery common when the battery sits to long with out being charged they are like 5 bucks on ebay.
Aug 05, 2008 | Casio Exilim EX-S880 Digital Camera
Casio ex-s880 model
It could be the battery isn't taking a charge. Since your purchased the camera last February you could be still covered under warranty. I would check with Casio.com. I found this link on their website:
http://www.casio.com/support/authorizedservice/
Jun 22, 2008 | Casio Exilim EX-S880 Digital Camera
Exilim ex-s880 wont turn on
I just called Casio customer service and they sent me a new battery in less than a week. 1-800-435-7732
May 12, 2008 | Cameras
Casio Exilim EX-Z60 Start up and screen problem
This is the lens focus gears. They are either knocked out of alignment, or debris has jammed them.
Dec 15, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Exilim EX-VZ camera won't take pictures
A new purchase? Reurn it to vendor for replacement
Aug 02, 2007 | Casio Exilim EX-V7 Digital Camera
Casio Exilim EX-S880 Digital Camera Logo
296 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
