Question about Apple PowerBook G4 Mac Notebook
Backlight dont light and firewire doesn't work...
After something like a short circuit in the firewire port, the lcd backlight suddenly turn off and never came back. Fuse problem ?
    Novelist:
  • 137 Answers
It could be a microfuse, which is about impossible to repair. You should test the computer on an external monitor and then, when it works fine (which it probably will), you can either find a place on the internet that will fix the motherboard or you can replace the motherboard. I haven't been able to fix any of these dark screen problems in Macs, because it's usually a microfuse or the video card that goes out. I don't think it's as simple as a backlight or inverter board, which are really robust in these laptops and rarely (never in my experience) the fault.
Posted on Feb 26, 2009
Hi I have an htc one mini m8 it suffered some water ingress everything still works fine accept the back light so found that the charging port flex is damaged does this have anything to do with the...
Hi
Any short circuit on the PCB due to water intrusion causes short circuit in the supply voltage to the back light.
Try to clean the PCB under a microscope.or replace the damaged parts.
Mar 09, 2015 | HTC Cell Phones
Klv32s310A sony bravia gets start on with green light and after a second turns to stand by mode blinking the red light 6 times after each 2 second interval
Hello Sagar,
green led means tv powered on and status ok.
Red blinking light almost always means defect, overcurrent or overload.
6 blinks for Sony lcd flat tv means trouble in backlight circuit, or backlight inverter (backlight illumination or lighting makes your tv screen visible).
common problems in the inverter circuit, which drives the backlight, or shorted drivers, or short-circuit transformers or open circuits.
You should find the problem in the inverter circuit, or in the power supply board or in the main board.
Also look for bad capacitors (electrolytic caps) which are bulged and swollen on top.
Decoupling plugs from printed circuit boards can help you in finding the problem board by elimination method.
If you power up the set after unplugging certain plugs on f.e. the inverter board , this could result in getting a green power led and concluding that this board is faulty.
succes,
Walter from Antwerp, Belgium.
Dec 30, 2014 | Sony Televison & Video
Sharp LC-52le835u Flashing lights problem
the problem is shorted backlight not the smps and main board if the backlight is shorted the unit will auto on n off thats hapen in your tv try to hang-up the wire connected to backlight it will power on
Mar 13, 2014 | Sharp 52 LC52LE835U 52 3D LCD TV
When I turn on my laptop it turns on but the screen is not working..it doesn't even light ..it's completely black and off..what can I do for this??
Possible that LCD has failed or the linking flexible cord at the hinges have failed. You need to check this out bby checking and observing for any breaks. Also check the continuity. USe an external monitor to check on the laptop and if the display is seen and the PC works then the LCD/LCD driver IC migth be faulty.
You need to check on the mother board , the power supply to the LCD/Backlight circuit.
Aug 05, 2011 | Compaq Presario CQ50-215NR Notebook
My Sharp 32 inc turn off suddenly, power green light turn to red, went turn on again screen ok for 5 to 10 second and start blink 3 time and screen turn off and power light change back to red. What...
sounds like something is shorting and the safety on the psu is kicking in.is the backlight behind your screen flickering prior to it cutting out. if so sunds like a cft has gone faulty. can be fixed though
Jun 08, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Keyboard backlight does not turn on for SGH-i617
it does sound like an short in the circuit somewhere could have been caused from something being spilled on it or being dropped, your lcd screen does not use the same one as your keyboard backlight, but check the settings by holding the cv button until the menu pops up if it dosent work then its probably broke hope this information was helpful:)
Nov 04, 2009 | Samsung BlackJack II Smartphone
Hey got a good one for ya....The TV had fallen and there is a corner on the plastic cabinet that is broken away.When plugged in and turned on the blue power on indicator will light up and you can hear a...
LCD sets sometimes will not power up until the backlight boards power up. the backlight boards have SMT fuses that open. and driver FETs (commonly also SMT) that short.
check the backlight circuits first.
Dec 05, 2008 | JVC LT-26WX84 26 in. LCD HDTV
Short circuit
If you look into the USB port and there are four finger like metal contacts and one of these is bent and touching the metal casing it is shorting out the 5 volts supply. Remove the connection to the power supply and remove the battery then straighten the finers so they dont touch anything. Replace the power adaptor and try again - if the laptop now works that is fine but you will not be able to use that damaged usb port.
Please be sure to rate this solution as we depend on your feedback.
Mar 23, 2008 | Packard Bell Easy One Silver 2120 Notebook
I got my phone wet and i dried it and the light doesnt work but the backlight works
is the light of your LCD doesnt work? If is so, the circuit of your Display having short circuit. Need to be cleaned, hoping that your display circuit not be cutted caused by the circuit shortage.
Apr 17, 2007 | Audiovox CDM8910WW
Apple PowerBook G4 Mac Notebook Logo
141 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
