Question about HP Photosmart 735 Digital Camera
HPphotosmart 735 turns on and then goes right back off.
The lens is out and camera is off. The batterys are brand new and I have changed to different ones.Was working great then all at once quit.
  • Anonymous Apr 09, 2009
    with new batteries the camera shuts down after its just turned on and says batteries are deldted and camera is shutting down
  • 423 Answers
Hi there.
First and foremost, 95 percent of the problems with the lens being stuck in or out is dirt, grit, or sand in the lens mechanism. The rest is either, the pins are out of alignment, or in extreme cases it's a problem on the circuit board ie. power.
If you keep your camera in a case, that is what does it. Cases protect your camera as well as provide a place for dirt to accumulate. Eventually, the dirt works it's way into the space between the lens and the camera, or worse, into a cog that moves the lens. Try to blow out the obstruction with an air compressor. Put the nozzle of the compressor to the camera in the space between the lens and the camera. Blow it out real good and see if that fixes it.
I have more fixes, but they require extreme measures and should only be tried if your at your wits end, and ready to trash the camera. Let me know with a comment.
Rob
Posted on Feb 25, 2009
My kodak z712 is won't turn on. New batteries. The lens extends and then goes right back and off
You say new batteries - does that include the tiny ones, that keep the clock and other internal functions going? If not, check those, too. They are usually located in a different place than the larger batteries.
Also, make sure you put the new batteries in, in the right order.
-a.
May 28, 2010 | Kodak EasyShare Z712 Digital Camera
Canon A520 powershot camera. You suggewted lithium batteries
Most likely a faulty mainboard which is causeing the powerdrain - replace the mainboard.
May 26, 2008 | Cameras
How do I set the hpphotosmart 735 to display the date on photos?
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
May 20, 2010 | HP Photosmart 735 Digital Camera
Photosmart 735 Digital Camera: how do I set the HPphotosmart 735 to display the d...
May 18, 2010 | HP Photosmart 735 Digital Camera
Camera comes on then turns right back off
use NIMH batt. NIMH gives you 1.2 power good for camera
ALCALINE & NICD gives 1.5 v which is bad and will discharge soon.
so use NIMH 2500 / 3200
Jun 18, 2009 | Sanyo VPC-S880 Digital Camera
Camera immediate shuts off after turning it on
try using lithium or nimh rechargeable batteries. I had the same problem and switched out the batteries and put in eveready nimh batteries and it works fine now. Guess the old cheap ones weren't doing the job. And they were brand new batteries.
Oct 12, 2008 | Nikon Coolpix L11 Digital Camera
Camera wobn't turn on & lens stuck in out position
My camera stopped working during a wedding. The lens is stuch out, it will power on, but right after turning on, it beeps 3 times, then turns off.
Hope we find a solution!
May 14, 2008 | Samsung Digimax A7 Digital Camera
Power on n off
I had the same problem, corrected it by cleaning the battery contacts inside the camera.
Dec 21, 2007 | Sony Cyber-Shot DSC-S500 Digital Camera
Blurry photo's . autofocus not working?
Make sure the lens is clean. Soft spectacle cloth nothing harsh Check the you have not got it set to Macro. Make sure you are not holding the camera in such a way that the focus window is obscured by your finger, If all that checks out HP technical Support for further advice.
Jun 23, 2007 | HP Photosmart 735 Digital Camera
Cant turn camera on
well just change the lens. probably the system got broken
Jan 22, 2007 | HP Photosmart 735 Digital Camera
HP Photosmart 735 Digital Camera Logo
221 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
