Question about Lexmark Wheelwriter 2500 Typewriter
I can't get documents to print in color i need color copies
  • Tim Babcock
    Tim Babcock May 11, 2010
    What color is the ribbon using right now?
    Scholar:
  • 183 Answers
The wheelwriter 2500 typewriter will only print the color the ribbon is, which normally is black.  you may be able to find a colored ribbon for your machine.  try googling it.  good luck with that.
Posted on Feb 27, 2009
Background on all white pages copies are gray
check printer settings or document settings back ground color settings
you can print a page color to any of the color bar settings so there is a setting that has been change to grey that is causing the problem
Dec 11, 2015 | Epson Stylus NX400 InkJet Printer
Why does my HP OfficeJet L7780 print blank copy with the regular copy
This is normally caused by a driver issue. Check that your device driver is correct for this particular machine.
Oct 19, 2014 | HP Officejet Pro L7780 All-in-One -...
HP Officejet 5610 All-In-One. cartridge error: refer to device documentation to troubleshoot ... I was in the process of of printing a series of documents. does not print prpoperly
Will it color copy- stand alone? Try making a copy on the printer by itself. If the copy is still printing in blue, then go to the service section in the menus, and clean the print head, if that does not work then try the recalibrate function. -If the copy comes out fine when you try it stand alone, try deleting the printer and reinstalling the printer.
Mar 28, 2014 | HP Officejet 5610 All-In-One InkJet...
How do i copy a document instead of printing using ink
Printing and copying both require ink. Scanner does not.
To copy put the document on the glass and press the copy button.
Dec 05, 2013 | Brother MFC 490cw Color Inkjet...
The scan of color document gives a black and white product
there some reasons :
1- Are you sure to select the copying color not black and white ?
2- try to reset color ink cartridge ,
3- try to select clean print head
i hope that was help you
Mohamed Hejazi
Afaqnama -Libya
ipg@hplibya.com
Mar 21, 2013 | HP Officejet 4620 e-All-in-One Printer,...
I can print a computer document in the canon pixma mp780 but I am unable to make a copy, come out blank. What is the problem?
For copy, first u need to scan a document. save it in ur desired format. then print it. give necessary instructions in scan & print settings. color/black&white, dpi, page sizes etc. etc.
Sep 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
My printer is printing everything black when using feedtray only
Their should be a Black Copy button and a Color Copy  Button . When wanting to copy a document in color you must choose the color start button.. Good Luck
May 04, 2009 | Dell 962 Photo All-In-One InkJet Printer
I want to copy a document
How often do you need to "copy" documents. Do you have a document scanner?  Your Epson is a printer.  You'll need a scanner to scan a document into your PC then you can print it out on your Epson.  If you only need a copy once in a blue moon, and you don't have a scanner, save yourself a few bucks and just go to Kinko's or maybe even your local grocery store or library and run your copies there.  They probably cost about 25 cents a page.  A new scanner will run you about $100 bucks.  If you decide that you need a scanner, you might even want to consider investing in a multi function printer which will scan-print-copy-fax.  Hope this helps.  If so, please remember to rate my solution.  Thanks.
Mar 14, 2009 | Epson Stylus Color 600 InkJet Printer
Printer will only give me black & white documents, I need color
If you can copy in color without problem, then you have to check the print settings. On your print screen click on [Properties], then [Graphics]. Verify that color, and not grayscale is checked. Make sure to click on [Apply] before closing the window. Write me if that does not solve the issue.
Sep 30, 2008 | Samsung CLX 3160fn All-In-One Printer
Scanned Items or Copies all print in Solid Black
I assume that you mean color images are being produced in black and white. If that's the case, there's a document on the HP web site that shows you what to look for and provides solutions:
Color Image Prints in Black and White
Good luck.
Sep 13, 2008 | HP PSC 1610 All-In-One InkJet Printer
Lexmark Wheelwriter 2500 Typewriter Logo
53 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
