Turntable Sound Goes Flat
I have an Onkyo turntable that I've been enjoying since the early 80s. I noticed recently that the sound of every record I play goes flat when the tonearm reaches the middle of the record. More specifically, it sounds like the record is dragging, but it only lasts for about 10-15 seconds before it eventually corrects itself, and then plays fine until the record ends. I've tried adjusting the counterweight & anti-skate based on several suggestions I found online, but the problem persists. Am I forgetting something? Is there anything else that needs to be adjusted? Any help will be greatly appreciated. Thanks.
Rich K
  • richman666 Feb 27, 2009
    Thanks for the input, Duncan. Does your solution involve opening up the turntable, or is this something I can do without dismantling it?
    Rich
    Problem Solver:
  • 6 Answers
It could well be that the arm needs a re-wire. There could be a bad connection or a broken wire that makes a contact most of the time and then has a poor connection during the time you mention. Usually it is the wire that runs from the arm bearing to the wires that run out of the deck to the amp, as these are moving all the time. I find it is best to replace all the wire to save time in the long run. If you replace one part something else will always need replacing soon after.
Duncan.
Posted on Feb 27, 2009
  • Duncan Watson
    Duncan Watson Feb 27, 2009
    I'm affraid it may need to be opened up. The wires for the arm go into the turntable, where they join the phono leads.
    Duncan.
My Dual CS 430 turntable suddenly stopped playing - rest of equipment (radio, CD player, tape deck) okay. Can you help, please?
Amplifiers always take the sound of the turntable via a separate pre-amp from all other systems, such as radio and CD players. This pre-amp can go faulty killing the sound from the turntable only. If the turntable goes through the actions of playing the record, then this is the cause of your trouble.
Sep 20, 2016 | Audio Players & Recorders
How to fix flutter & wow on a Gemini 500 XLii direct drive turntable
Direct drive turntables have electronically controlled speed. If the records you are playing are warped (not flat) that will cause wow & flutter. If that's not the problem then you might try connecting the turntable to a different power outlet using a long extension cord. Failing that, the turntable needs repair.
Jul 30, 2014 | Philips gemini XL-500 II Turntable
Automatic turntable adjustments
The Service Manual may be downloaded at:
http://www.vinylengine.com/library/onkyo/cp-1055f.shtml
You will have to register (free) before downloading.
Mar 28, 2014 | Audio Players & Recorders
Got record and it is not loud. never had any problems with other vinyl records sound quality. I want the songs to be converted to MP3 but the sound on them is so flat. other records I have converted sound...
Hi, maybe the record is worn and that's why the sound is low. By using third party audio editing software (i.e. cool edit [paid] or audacity [free]) you can improve quality and volume of digital sound.
Aug 11, 2011 | ION Audio Vinyl Recording Turntable
I've connected my turntable to my stero system. When I try to play a lp the sound is terrible. I've replaced the needle. Did not help. Any ideas?
is the vinyl clean vinyl is supposed to sound weird thats what its all about. if the records not clean it could make it sound ****
May 21, 2011 | Numark ttUSB Turntable
Computor does not see the turntable
It is likely that the driver has been deleted. If you cannot reinstall the driver you could do a system restore. Click the start button, accessories, system tools, system restore. The computer will pick a recent date but you have an option to pick your own date. Select a date, in bold, when you know that the turntable was working and select ok. When the System restore has completed your turntable should be working again. This will remove any programs added after that date but will not affect your documents.
Jul 19, 2010 | ION Audio iTTUSB Turntable
Old Philips turntable 312 No sound
I am in a similar situation. I recently discovered that exact model turntable in our storage room. The Philips 312. While looking it over, I noticed the stylus is broken. I was wondering where you purchased yours?
Mar 27, 2009 | Philips Audio Players & Recorders
No Amplified Sound Coming Out...
http://www.mcmelectronics.com/product/MCM-CUSTOM-AUDIO-40-630-/40-630
Turntables need a preamp due to their very low output compared to modern components. The link above is the one I use. Try connecting to your receiver's phono input if you have one, also try the aux input. If neither of those work, obtain a preamp and you will soon be scratching with the best of them.
Jan 02, 2009 | Audio Players & Recorders
130 people viewed this question
 Grubhead
Grubhead
