Question about Panasonic TH-42PX60U Television
Red light flashes 10 times - Panasonic TH-42PX6U
I heard that the flashing codes on Panasonic plasma units represent a specific type of error.
upon plugging in unit and pressing power, the red light flashes 10 times -- do you know what that represents?
My TV is now 1 1/2 Years old and out of warranty. The screen went black and will not turn on now. After reading your problems I can see that I am going to have a rough time repairing. Any help would be appreciated.
    Brigadier General:
  • 8,619 Answers
Hi
After you switch it on can you hear any sound coming from the TV.Also have you tried to switch it off for 1hr .
Posted on Feb 25, 2009
  • Rylee Smith
    Rylee Smith Feb 25, 2009
    It could be due to one input into the TV, which had the HTPC connected via a DVI-to-HDMI cable plugged into the HDMI 1 slot. *IF* the HTPC was already on, then it would have the blinking. *BUT* if the HTPC was off, it should have booted fine (assuming you cleared the blink first by powering off the HTPC, unplugging the TV, and replugging the TV back in with the HTPC still off). After this I would suggest to move the HDMI cable from slot 1 to slot 3. After making this one change, everything should work for sure. You could even leave the HTPC on and turn on the TV last.
    In case if it doesn’t work by this then check the power relay and the power supply either or both can be bad.
    Please revert for any clarifications.
    A “Fixya” rating would be appreciated.
    Thanks
    Rylee
  • Panasonic Master
  • 13,433 Answers
The problem / symptom you are facing is a protection mechanism when a fault is detected the tv goes into protection mode and displays a error message in this case 7 blinks.
you will need a service manual which includes the list of codes and explanations of them.
I have to warn you, its not recommended attempting to fix a tv at home. Do you have previous experience?
Who to fix broken panasonic plasma tv
Adam, 1 st thing to try is holding the power button in 20 seconds and see if it resets.Check the links below and do not be afraid to google search your problem yourself, there is a lot of info. out there onm this problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Panasonic Plasma TV Repair Understanding 10 Blink Code for 2011 Panasonic...
Panasonic 10 flashing red light
Panasonic Plasma 10 and 2 Blinks TEA1611 ETX2MM702 704 706 Power Supply TH...
May 02, 2016 | Panasonic TCP65VT25 65 inch VT25 1080p...
My panasonic plasma hd tv red light flashes 10 times and will not come on
Check its fan SOS board for fault. Visit this site for more details. Pull up older posts. Blinking codes to Panasonic Plasmas are given in detail.
Mar 31, 2013 | Televison & Video
Panasonic viera th-p42g10a plasma tv has flashing red led light
The number of flashes is indicating a specific error. If you let me know how many times the light is blinking I will let you know whats most likliy causeing the issue. Reply to this same post for assistance.
Nov 09, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
I have a Panasonic model TH-50PZ80U and the red light for the power flashes 10 times. I unplugged for 20 minutes and plugged back in to find it flashing 10 times again
I can tell you what is the caused of the 10 flashes of the led light (Panasonic Plasma TV TH-50PZ80U). I'm online at pay question click it here if you want to know it and I will help you to fix it yourself.
Sep 27, 2011 | Televison & Video
TH-42PZ80U Panasonic Plasma, red light flashes 10 times
Panasonic said "A" board,
A board SOS Detect (Explanation)
10 Blinks SOS: The voltage regulators IC5400 and IC5401 in the A board generate SUB9V and SUB5V. The 9V and 5V from these ICs are monitored by IC1100. Any abnormality on the SUB9V or SUB5V lines, triggers the shutdown circuit and the MPU shuts down the unit. The power LED blinks 10 times.
But need to measure the connection SC2, if it short, it will be the SC board.
The knowledge obtain from: Real case of repair by myself.
Information from Panasonic training manual.
Apr 27, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Panasonic Plasma HDTV 50" Viera--won't turn on. Red light flashes 10 times followed by a 3 sec pause, then repeat 10 flashes. Have solved problem by unplugging it and plugging it back in, but that is not...
Please make sure your connectors are in the proper place.
The HDMI inputs on the rear of the TV are optimized for use with Audio/Video devices, Blu-ray Disc Player, DVD Recorder, etc.
The front or side HDMI inputs only are designated for PC. To use the TV as a PC monitor, advise customers to use only front or side HDMI inputs.
Jun 16, 2009 | Panasonic Viera TH-50PZ800U Plasma TV
Panasonic TH42PZ70B
Flashing RED lights in Panasonic TVs means a fatal error code. Unplug the TV, wait 1 minute and replug. If the LED still flashes it needs professional service.
Sep 04, 2008 | Panasonic TH-42PA20U/P 42 in. Plasma EDTV
hey there! i finally figured it out!! If you have a computer hooked up with the HDMI cable in the back of the TV and the computer is either on screen saver mood or sleep mood then it is trying to make the television go to sleep aswell. So the only way you can have a computer hooked up to the TV is if you use the front HDMI hook up. pretty weird but thats what was wrong with mine. Hopefully that was the problem :):)
Nov 02, 2007 | Panasonic TH-42PX60U Television
Panasonic TH-42PX60U Television Logo
372 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
