Question about Denon AVR-2802
Can't get clear sound when not in "bypass" mode on Denon Pro Logi
When using anything other than bypass, the sound is like it is coming from a badly tuned radio station. Used to work perfect, but have not used in a long time. Great sound from right and left channels.
  • 119 Answers
From the FM radio mode, from your remote press the speaker button to make sure just the front speakers are on, make sure surround is off and use the tone cotrol button on the right side of the amp to adjust the bass and treble. That should clear things up a bit
Posted on Feb 25, 2009
Denon AVR - 2807 flickers in TV mode with picture & sound.
Change the hdmi cable and try. If not then you have an hdmi fault module.
Dec 15, 2013 | Denon AVR-2807 Receiver
Stuck on standby mode
Sounds like it might have a blown amp channel. Best to have a pro look at it.
Jun 18, 2013 | Denon AVR-1912
I have a Denon AVR 1912 purchased 1 1/2 years ago. All I have hooked to it is the cable box and then it runs it out to the TV and surround sound. My Denon stopped sending the picture to the TV but I can...
I would double check all the connections to and from the Denon. Cables and poor sockets are the biggest problem with these kind of systems. Double check the settings of the Denon for outputting video signals.
May 30, 2013 | Audio Players & Recorders
I have a Denon 1611 hooked up with XBOX, DVD, and CHARTER CABLE BOX to a SAMSUNG UN55C8000. For whatever reason I have no sound coming from my (TV) speakers and no sound at all when I switch to my game...
It would appear that your receiver, from pictures I looked at, has 4 HDMI in and 1 HDMI out. Looking at the specs of the tv, it has 4 HDMI in. I'm guessing that you have your receiver set up with speakers and sometimes you'd rather listen to tv speakers? I didn't download a manual however, usually to get sound from tv speakers you may have to turn off av's speakers or, there may be a way to bypass. If you could give me more info on hookup and what you want to do I could probably be of more assistance.
Mar 11, 2011 | Denon AVR1611 5 Channels Receiver
I have a Denon AVR 790 for about 8 months now. Hooked up a combo DVD VCR player using the red/yello/white cables. It worked fine for about 6 months. Now I cannot get the DVD or VCR to play. I get sound,...
If dvd combo player is only video source connected with Denon AVR 790 then unplug yellow video wire from Denon and plug it directly in TV input, now video signal will go directly to tv and sound will come from Denon AVR 790 speakers during dvd playback.
This is simple bypass that wont effect surround sound of dvd playback.
Let me know if you have additional question.
Thanks.
Oct 20, 2010 | Denon Audio Players & Recorders
No power ,all fuses are fine
More than likely the power supply has gone bad. I do not know if Denon uses a switch mode power supply or a linear supply. One way to tell is the weight of the amp. Heavy = linear supply and light = switch mode. Common problems with switch mode supplies are the FETs used for switch or the PWM generator (pulse width modulation generator) Linear supplies more than likely would have a bad bridge rectifier or shorted bypass cap on the DC rail.
Feb 06, 2010 | Denon AVR-2500 Receiver
I have a Denon 2800 hooked up to a Pioneer DV-C302D and while DVD's thru the Denon, the sound will come on and off. At the same time the Denon will be switching between analog and digital mode. Is one of...
It's a cable or connection.
The Denon apparently has an automatic selector to choose the digital input over the analog input if both are present (my Pioneer does this). The random switching is telling you the digital input is intermittently dropping out and coming back. You don't say if you're using the optical or coaxial digital interface. Coaxial is less prone to connection problems. If you use optical, make sure the ends are clicked in and there are no small radius bends in the cable. Tight curves reduce the optical power. Either way, check the connections and wiggle them to see if you can cause the problem to return.
Jan 18, 2010 | Denon AVR-2800 Receiver
How do i hook up a PS3 through my denon avr1905?
ONCE YOU CONNECT THE OPTICAL CABLE AT THE DENON, YOU ALSO NEED TO CHECK THE AUDIO SETTING FOR THE INPUT USED AND MAKE SURE OPTICAL IS SELECTED AND LAST ONCE YOU SELECT THE SOURCE INPUT USED TO CONNECT THE PS3 TO THE DENON PRESS THE INPUT MODE BUTTON ON THE FRONT LEFT OF THE DENON UNTIL YOU SEE DISPLAYED THE WORD AUTO, THIS SHOULD GET YOU SOUND AS LOND AS THE PS3 IS OUTPUTING AUDIO OVER THE OPTICAL
Mar 01, 2009 | Denon AVR-1905 Receiver
Problem with Denon AVR 1508 in DTS NEO 6 Format
WHAT TYPE OF AUDIO CONNECTION IS USED FRON THE SAT TO THE DENON? IT HAS BEEN MY EXPERIENCE THAT YOU MUST CHECK THE OUT PUT FORMAT OF THE SAT OR EVEN USE A COAXIAL OR OPTICAL CABLE AND ON THE FRONT OF THE DENON PRESS THE INPUT MODE BUTTON TO DISPLAY AUTO
Sep 24, 2008 | Denon AVR-1506 Receiver
Denon AVR-588 Sound Delay
FIRST, IF YOUR USING HDMI CONNECTIONS IN THE DENON HDMI SETUP YOU HAVE TO TURN THE AUDIO DELAY ADJ. ON
SECOND, THE DELAY TIME ADJ, FOR OTHER SOURCES IS LOCATED ON PG 27 IN THE MANUAL, HERE IS THE LINK TO DENON SITE WITH MANUAL
http://www.ca.denon.com/AVR-588-OM-E_102.pdf
Jul 12, 2008 | Denon AVR588 Receiver
Denon AVR-2802 Logo
124 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Dennis McCollum
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
