Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Kitchenaid KUDS01FLBL2 dishwasher will not run
"Clean" light blinks 7 times and then pauses
  • juanrodman Feb 25, 2009
    Great help!!!!!
  • 117 Answers
Juan, I found this http://fixitnow.com/wp/2007/01/20/blinking-clean-light-on-whirlpool-built-dishwashers/
It should help you out with the issue you are having with your dishwasher. Watch the video too!
Best of luck
Posted on Feb 25, 2009
How to reset control board on kitchenaid dishwasher
Check to see if there is a manual behind the bottom panel. It should tell you what that error code is. It may be the heater is not working or some other issue. You will have to repair the problem before this will stop.
Oct 02, 2014 | KitchenAid Dishwashers
Clean light blinking
If the clean light blinks four times and then pauses and then blinks four times again and repeats, the problem is your pump motor. If there is water under the DW the pump clamp has probably failed and sprayed water onto and inside the motor. Call a certified Kitchen Aid repair service.
Aug 13, 2014 | KitchenAid Dishwashers
Led light flashes 4 times, pauses then repeats
Which light blinks 4 times and pauses wash normal heavy etc if the model in the blue box is correct the to enter diagnostic press any 3 keys within 8 seconds I usually use normal and the 2 keys to the right all lights should light up if touch pad is up top where you had to open door to accomplish this then close the door after a pause the clean light will begin to flash example 7 flashes pause 1 flash these are your fault code it will do this 3 times for each code. The tech sheet should be behind the toe panel located below the dishwasher door which just repeats what I explained.
Feb 04, 2014 | KitchenAid KUDE70FXSS Builtin Dishwasher
HOW TO RESET THE CONTROL PANEL ON KUDE60HXSS4
My Kitchen Aide Dishwasher KUDE60HXSS4 has the clean light blinking and water is coming out of the dishwasher running down the back wall. The dishwasher will not come on. The clean light just blinks.
Jul 11, 2012 | KitchenAid Architect® KUDT03FT 24 in...
I have a kitchen-aid dishwasher model # KUDio1ibl6 and it will not come on and the clean light flashes 7 times then pauses and blinks 7 time again. Do you have any Idea what this code stands for I do not...
Hello Asa,
The light blinking seven times is a error code specifically it's error #7 .The E-7 error indicates the part called the flow meter is bad. To clear that error code and get the dishwasher to start push within 3 seconds
HIGH TEMP WASH -HEATED DRY-HIGH TEMP WASH- HEATED DRY
then push CANCEL sereval times to dishwasher shuts off..it should start and run then
If the blinks 7 times again the flowmeter will need to be replaced
ON some models the "HIGH TEMP WASH" button is labled power scrub instead of high temp wash
so in that case push POWER SCRUB-HEATED DRY-POWER SCRUB-HEATED DRY then cancel as described above
In case the E-7 error returns and the flowmeter needs to be replaced the part number for it is W10195536
Gene
Aug 24, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Clean light blinks 7 times, pauses, then blinks 7 etc.?
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jul 25, 2011 | KitchenAid 24 in. KUDP01IL - Multiple...
Clean light flashes on and off 7 times, then a pause. Then repeats the sequence. Machine will not start regular cycle.
The clean light blinking 7 times can indicate a heater failure.
Press Heated Dry, Normal Washer, Heated Dry, and Normal Wash.
This sequence will run a diagnostic test and clear the error temporarily but if the dishwasher is not heating the water the error will happen again.
If the problem is a reoccurring one then I recommend checking the heater amps if you have access to a clamp-on volt/amp meter.
Remove power to the dishwasher and remove the access panel. See image below. Clamp the meter around the black or white wire at the junction box and restore power and run the test cycle. During the test the heater will come on and the meter should pick up about 8-10 amps. If you get no amp draw then the heater is not working and is the cause of the clean light blinking 7 times
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 01, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
703 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
