Question about Durabrand DUR7 Portable DVD Player
Car adapter replacement.where can i find one.can the fuse inside be replaced.
  • 303 Answers
Yes, the inside fuse can be replaced
You can buy a new car adapter by clicking on the hyperlink:
buy replacement car adapter power charger cord for Durabrand DUR7 DUR-7
Posted on May 31, 2009
Can I fix a Samsung auto adapter charger that is not working?
check fuse. open the screw end and see if the fuse inside blew? replace.
Oct 05, 2015 | T-Mobile Tmobile Cla Samsung Cell Phone...
Fuses when to know time to replace
If the radio still plays then the cassette part of radio is no good
May 25, 2014 | 2001 Ford Windstar
Valentine one doesnt work
If you can, I'd recommend it taken back for replacement or have a stereo/audio shop look at if you think its worth it.
Jun 26, 2013 | V1 Radar Detector
My Proform 900 wont work with batteries or ac adapter after I put wrong adapter in
Since you put Wrong adapter, possible dammed blown fuse. or tripped c.breaker inside. replace fuse or reset the c.breaker and Try again.
If this Does NOT solve the problem, you have a problem in the power supply faulty. Call some service tech for fix it.
God bless you. see the block d
Aug 03, 2012 | Exercise & Fitness
Hi my tv adapter keeps making sparking sounds and is given off a smokey smell. Will not allow my kids to turn it on. We only got it at Xmas
It can be deduced from your problem that the fuse located inside the adapter is burnt out,This occurs as a result of excess voltage which is passed into the adapter,the fuse in the adapter tends to protect excess voltage from going directly into the TV unit,
Hence,when excess voltage gets into the adapter,the fuses burns out and voltage cannot flow into the TV UNIT,
The solution is to take apart the adaptor and replace the cylindrical fuse which is burnt out,or as a better alternative,replace the adapter in order to obtain optimum performance in terms of protection of your TV unit.
Thanks and take care.
Jul 03, 2010 | Televison & Video
Garmin C330 keeps shutting off
There is a fuse inside the (cigar lighter) plug on most units.
You unscrew the tip to pop out the fuse.
There is a very thin wire inside the fuse that you can see
if you look close. It should still be intact. If not, replace it.
Here is the manual for your unit page 29 shows the info you are looking for:
Oct 23, 2009 | Garmin StreetPilot C330 GPS Receiver
My wii won't power up. I am not sure what is wrong, but it won't turn on.
I just posted this somewhere else where this was asked, but I'll post it here too so it helps other people.
This is a common problem with the Wii. Even if it's hooked up to a surge protector. If there was a power surge, or the power went out, etc...anything, this will happen. The problem is with the AC adapter, not the Wii itself.
There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10 minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 5 or 10 minutes, the red led on the front should be lit up.
Aug 05, 2009 | Nintendo Wii Console
When I plug the radar in the green dot turns on for a second then turns off, nothings on afterwards... I used a new wire and fuse and nothing....what could be wrong?
Does the unit work in another vehicle? If not, first thing to check is the fuse in the power cord. The adapter (part that plugs into the lighter socket) has a replaceable 2 amp 3 AG fuse inside it. The end of the adapter, which has the silver tip, unscrews to gain access to the fuse. CAREFUL: Unscrew slowly! The tip contains a spring which may fly out when disassembling. With use, screw cap on plug may loosen. Retighten occasionally.
Jun 23, 2009 | Car Audio & Video
Unit won't take a charge in my car.Ichecked the fuse in my vehicle and its ok.The power cord to the nuvi760 has a sticker that says ''replacement fuse F3A 250V'' but I can't seem to find it
its in the tip of the plug on the charging adapter that plugs in the car..the tip screws off and fuse is inside under tip
Jun 16, 2009 | GPS
Does not turn on. ac adapter is ok.
I've been there I think.... You probably blown a 2 amp fuse inside on the DUNTKB128DE03 board. You are having a power issue inside and may need to replace the board. Check the fuse first.
Dec 24, 2008 | Sharp Aquos LC-20B2U 20 in. LCD Television
Durabrand DUR7 Portable DVD Player Logo
87 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
