Question about Whirlpool LER5636P Electric Dryer
The timer is not advancing and there is no heat coming out. I replaced the timer unit for a cost of $100 and nothing changed. Any other suggestions? SuziNoHeat
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Does the dryer run at all? Have you verified the voltage at the wall receptacle and terminal block?
  • 547 Answers
Thermostat? first check heating eleament thank you for useing fixya please rate me
Posted on Feb 25, 2009
Cooling off how do you turn it on
Find your thermostat and turn to 5. 5 should be about midrange and control your temperature at about 37 degrees. If this does not work check to see if power is available at your outlet. If power is available your light will turn when you open the door. If power is available then the next thing I would check is the defrost timer. On most units it is a white hand sized control normally mounted near the compressor. Sometimes the defrost timer contacts burn out or the motor burns out and will not advance. The defrost timer has a multiprong connection with 4 leads when it is unplugged. It typically cost around less than 100 dollars. There is a manual advancement on a small dial in the center, try advancing with a flat blade screwdriver until the compressor comes on. typically 30 degree turn.
Sep 25, 2014 | Maytag Refrigerators
West Bend MC38ACL convection oven
Yes normally a fuse which they replace for it to heat again generally goes when over heated especially if not in a air flow area will cost about $100 - $120 to fix local electrian
Apr 06, 2014 | Toastmaster TLWTOB6 Lightwave Toaster Oven...
5 ton goodman package unit
I guess this is a heat pump unit, check the change over valve in the gas circuit, sounds like the solenoid on the valve is burnt out
Mar 24, 2014 | Heating & Cooling
My dryer keeps shutting off after a few 10 to 13 minutes...and clothes are not drying. An element was changed some time ago. it does heat up but keeps shutting down...is it the timer or element?
Turn the breaker to the dryer completely off and back on again. Also check that nothing is blocking the venting. Remove the vent hose and run the unit if you are not sure. Make sure the lint trap is cleaned first. It probably is neither element nor timer since it is heating and quits without the timer advancing completely.
Apr 05, 2011 | Maytag HYE3657A Electric Dryer
My Kenmore dryer will not heat or turnoff. I have
the timer will not advance without heat.the dryer heats up when it reaches temp. the heat shuts off and the timer advances,when the heat comes back on the timer stops,send the model number next time,
Jul 31, 2010 | Kenmore Dryers
Dono heat and timer dont turn
HI. Due to the fact that the timer is not advancing, this will lead me to believe that the timer is the culprit here. The timer is equipped with a motor. this motor, when energized, will advance the timer dial, thus, activating the unit, and progressing the cycle. If the motor is damaged, as in your case, the unit will not heat, or run correctly. Simply replacing the timer control module will correct this problem.
Replace this damaged timer mechanism asap.
Dec 04, 2009 | Estate TEDX640JQ Electric Dryer
Won't heat, won't advance on auto, won't shut off on timed. air only fine
I suspect you have a timer motor problem. My experience has been in most cases you cannot buy just the timer moter, you need to purchase the entire timer....at costly expense. If you can get your ear near the timer while running, first listen to hear the motor. Usually when the motor is going to quit, it becomes fairly noisy. In any case, the timer should advance,
Apr 22, 2009 | Dryers
I have frigidaire electric dryer - drum turns - no heat - timer switch/dial does not advance
replace timer,,than see if it heats,,if you ran this unit with timer not moving,,you made need to change thermerstats
Dec 26, 2008 | Dryers
Timer doesn't shut down dryer machine
the timer is easy to change, check how much it is first, mine was around $100.
Apr 28, 2008 | Kenmore 62602 Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
44 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
