Question about Konica Minolta Minolta DI1610P Printer, Copier, Scanner, 16 ppm, 250-sheet standard paper drawer, USB (DI-1610P, DI...
Error Code C13FO
On my konica minolta Di1610 on the screen it says Error CodeC13FO and the machine is not working. pls help. thanx
5 Suggested Answers
  • 3 Answers
SOURCE: Error code on Konica Minolta C350
There is not a C0876 listed in the service manual. Perhaps it's a C0B76 - Finishing option Punch Unit Board Malfunction.
CAUSE: The shaft on which the gear rides is deformed. The punch unit cannot be driven from front to rear.
SOLUTION: Reform the shaft toward the punch unit rail. This will allow the drive gears to mesh properly so the punch unit can be mechanically driven from front to rear.
Posted on Aug 30, 2008
oranous_comp
SOURCE: proplem with KONICA MINOLTA bizhub C450
c-3451
Posted on Nov 10, 2008
Geekinator
  • 183 Answers
SOURCE: error code c-5102 in Konica minolta c252
Here’s your GEEK-steer …
This thread appears to cover the solution to your problem related to error "C5102: Main Motor’s failure to turn":
http://www.copytechnet.com/forums/konica-minolta/15515-c252-m1-operation-test.html
In addition, here’s the link to “Bizhub C250P” related support downloads:
http://kmbs.konicaminolta.us/content/support/supporthome.html
Hope this helps, and please post back with a status report and/or any further assistance you might need.
"Today's the best day of my life...and NOW you're part of it!"
Posted on Dec 16, 2008
SOURCE: IError Code C13FO on konica minolta Di1610
C13F0 - Laser error
The laser output exceeds the upper limit value.
The laser output remains lower than the lower limit value.
Posted on Aug 23, 2009
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
Minolta Di1610 error message - change t/c??? incorrect t/c type??? What to do???
Google it just as you typed it out the manufactures web page will explain better than we can
Aug 26, 2014 | Konica Minolta Office Equipment & Supplies
Machine trouble
Sir,
To clear the fuser error code, perform the following:
1. Power the machine OFF.
2. Press and hold the STOP key.
3. Power the machine ON. Release STOP after 5 seconds.
Jul 16, 2009 | Konica Minolta Di1610 Copier
Minolta di1610 error message
What error message? Does itsay toner cartragie need replaced.
Apr 04, 2009 | Konica Minolta Di1610 Copier
C13F0 - Laser error
Feb 25, 2009 | Konica Minolta Di1610 Copier
Help! i get the "Machine Trouble" error
are you sure thats the right trouble code? reboot machine holding down the STOP button. this may reset this error
Dec 04, 2007 | Konica Minolta Di1610 Copier
Problem with Konica Minolta Di1610
Incorrect T/C type means that toner cartridge have not good contact with toner chip, is good to clean this chip, or contact inside magine is not good. Change toner cartridge and if that problem remain, its needed replace contact unit on machine
Sep 21, 2007 | Konica Minolta Di1610 Copier
108 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
