Question about Sony Handycam DCR-HC42 Mini DV Digital Camcorder
Sony camcorder my sony video camera always display on the lcd to reinsert tape
  • Rob
    Rob May 11, 2010
    We need some more information please. What exactly is your question?
    Rob
    President:
  • 1,223 Answers
Pls clean the head of camera using DV tape cleaner cassette and see if it helps pls do rate me if it helps to fix ur problem
Posted on Feb 25, 2009
Canon charge light blinks 7 times
If your Sony camcorder displays a tape transport or mechanical error code always try resetting the camcorder. This is done by removing the battery or ac power, wait 10 seconds, reapply the battery or ac power and try again. If it still goes into error try another tape. The camcorder will not always display an exact error code. Sometimes you may see an error message such as, "Reinsert the cassette", on the LCD screen. This is the camcorders way of saying, "Take the tape out and try again." Try reloading the same tape as well as a new tape. If the camcorder is still going into error this means it is time to send it in for service or repair.
The camcorder may also sometimes display a "Reattach Power Source." This is the camcorders way of saying,"Try resetting my system,so I can try again." Many people mistaken this error and think they have a problem with the battery or ac adapter. This is not true and has nothing to do with your battery or ac adapter. Reset the camcorder by removing the battery or ac power, wait 10 second, reapply the battery or ac power. If the error reappears the unit needs to be serviced or repaired.
Jan 23, 2013 | Canon VIXIA Video Cameras
My Sony handycam won't allow me to use the touch screen features in play mode. I can't rewind, play or fastforward the tape. It has reached the end of the tape - what now?
If the touch screen of the Camcorder is not working, please follow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Reinsert the tape and check the operation
Try another tape to check whether the issue persists only with particular tape.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
Note: In the above figure, 8 represents the reset button.
If the issue persists again, please perform LCD screen Calibration and check if that helps.
Please follow the steps below to perform the LCD Calibration
If the issue persists again, service is required.
I hope this information will help you to resolve the touch screen issue of the Camcorder.
Dec 18, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
If I on the power, display at LCD said 'Reinsert the cassatte' and C:31:23. Why?
The timing cam is misaligned. Its' purpose is to eject the carriage, transport the tape into the heads when there is a tape and play or record the tape. If the gear is off slightly then you will get the error. It needs to be taken apart and re-aligned.
Nov 12, 2010 | Sony DCR-TRV285E Digital-8 Digital...
I have a sony dig 8 trv340 and am receiving an error code of c31:42 what does this mean?
In DCRTRV430 Camcorder, the C:31:42 error message is a Self diagnostic display. This message can be clearly identified by the help of a Sony Authorized service technician. Each of these codes indicates the symptoms and resolutions of the Camcorder. In C:31:42, the issue is with the tape and the tape mechanism.
I suggest that you remove and reinsert the tape to check if it helps. You may also try inserting new tapes in the Camcorder. Please remove the battery and/or power cable, connect, and perform operations from the beginning. You may also try resetting the Camcorder back to factory default after removing the tape.
To Reset the Camcorder, perform the steps below:
? Please open the LCD screen to locate the RESET button.
? To reset the Camcorder, press the RESET button using a sharp-pointed object.
? Please make sure that the Camcorder is turned on while pressing the reset button.
Also, try turning off the Camcorder and remove the battery pack. Then move the 'Power Switch' of the Camcorder to the ON position
for 1 minute. After about 1 minute, move the 'Power Switch' to the OFF position.
Now reinsert the battery, turn on the Camcorder and check whether it is working fine.
Thanks.
KenSolutions
FixYa
Oct 23, 2010 | Sony Video Cameras
Sony DCR-TRV460 not playing back, blue screen
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
  1. Stop the tape.
  2. Ensure the tape has been rewound to the beginning of the video recording.
  3. Play the tape.
  4. If the issue is not resolved, stop the tape and remove it from the camcorder.
  5. Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
  6. Reinsert the tape into the camcorder.
  7. Play the tape.
  8. If the issue is not resolved, stop the tape and remove it from the camcorder.
  9. Insert a different tape with video footage into the camcorder.
  10. Ensure the tape has been rewound to the beginning of the video recording.
  11. Play the tape.
NOTES:
  • If a blue screen is still displayed, then the camcorder may require service .
  • If the tape plays back correctly, then the first tape may be faulty or there is a problem with the video recording.
Aug 13, 2009 | Sony Handycam DCR-TRV460 Digital Camcorder
I have a blue screen during playback mode on my Sony DCR-HC32. I am not able to see anything I recorded. What should I do?
  1. Stop the tape.
  3. Play the tape.
  7. Play the tape.
  11. Play the tape.
Aug 06, 2009 | Sony Handycam DCR-HC32 Mini DV Digital...
Camcorder not working
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Oct 27, 2007 | Sony Handycam DCR-TRV250E Digital...
Cannot playback hi8 ccd trv107e pal
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Jun 18, 2007 | Sony Handycam CCD-TRV107E Camcorder
Sony Handycam DCR-HC42 Mini DV Digital Camcorder Logo
141 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
