Question about Mackie SRM-450 System
Loss of power & clarity
The srm450 mackie's seem to have lost both power & clarity. I have taken them to the authorized repairer & they cannot find anything wrong with them. I compared them to another pair of 450's & the difference is very noticable
Do they sound good at low level? If so i would suspect the drivers may be a bit smoked.Some drivers will still work after being overheated but exhibit a lowered impedance to the driving amp and do all sorts of bad things including possibly burning up the driving amp.If they are still under warranty,bring them back and tell them they better check them out again cause your 12 year old cousin can tell they are in distress and if they still can't find anyhting wrong maybe you can get him a job.But seriously,give them the smell test.Put your schnozz near the center of the woofer cone, then tweeter center to see if you detect any burnt smell at all.even a little bit can be a clue that there is a big prob.Next step is to remove the suspect from the case and give it a feel.while you are doing this,give the amp circuitry a quick visual for anything burnt or obviously dammaged.The smell test is really good for the amps as they get REALLY smelly when they are in trouble.Try to gently move the cone inward and then outward.NOT hard enough to damage it but what you are looking for is any slight drag or uneven cone movement like a slight scraping.If you have another decent speaker that is similar in size(not really necessary) and quality(i consider this very necessary),try the substitute to see if you are on the right track.What we are trying to do is narrow the prob down to the actives(amp/crossover circuitry) or passive(actual speaker mechanisms).Actives need a tech.Passives need you to get a replacement speaker and install it yourself.may be just a woof or maybe a woof and a tweet or whatever.remember,you need to listen closely(this is a mental process) to decide if what you hear(physical process) is good audio.Take it from there Sparky!This process is good for any active speaker.
Posted on Feb 25, 2009
Power supply circuit diagram
There is almost certainly a reason the PSU has blown, these are not very reliable units and the amp has probably gone and taken the PSU with it. You are better off taking it to a dealer and getting it fixed. If there is no power on the seecondary and there is no short the transformer must have blown (assuming you're not trying to check with a DC meter)
Jan 19, 2014 | Mackie Srm450v2 Srm450 Srm 450 V2 Active...
Mackie 450 thermal light on no sound
could you give some more info? what are your running into your speaker? and how exactly is it run? once we weed out common issues like switched up cables, than we can move on to internals.
which on that note, I think this is a manufacturing defect
here's a link to the schematic if you want to go poking around the circuits.....
or actspk.pdf
take a resistance test between D56 pin1 and Q35 pin2. thats where this issue seems to be stemming from from ones ive worked on. I have know it to be an internal track that was broken and needed to be glued back down. definitely not the first time ive seen this....
Dec 07, 2012 | Mackie SRM-450 System
Blown Mackie srm450 woofer makes sound but rattles when turned up
I need more information, but some similar event i remember with SRM450 and was the paper cone on the speaker, not visible from outside but inside was severely cracked all round, hope this helps.
Apr 23, 2012 | Mackie SRM-450 System
Hi; My mackie srm450 is not giving bass anymore what can I do to repair it ?
FIrst of all this is not a repair site per se. We help by providing information that you may require to repair something.
For your specific problem, there can be many causes. The speaker itself can be defective, the amp may be blown or the crossover could be malfunctioning. Without seeing the actual unit, I cannot possibly know which is the case. These are decent units and rarely fail in this manner. In my experience, the likely problem is the speaker itself. You can contact Mackie directly for a replacement. If you have an ohmmeter, disconnect one of the speaker wires and measure across the speaker terminals. You should read either 6 or 3.6 ohms. If you read infinity, the coil is open and the speaker must be replaced. If you feel that you cannot attempt this repair, please update this with your location so I can suggest a repair facility close by.
Apr 12, 2011 | Mackie SRM450 PA Speaker
When turned on: srm450 has no sound, but all leds (power and signal) is normal. If I turn the volume up (near maximum) , the srm450 sound is activatet again , and peforms normally. I then turn volume down...
2 Unscrew the fixing screws on the back. (just the outside ones)
3 Take the back off and turn the amplifier circuit board to face you.
4 About 2" from the left and about 4" from the bottom you will see a sort of tab. pull it off gently and widen the 2 prongs slightly.
5 Put the jumper tab back on and re fit the amp.
Dec 26, 2009 | Mackie SRM-450 System
Repair a Mackie SRM 450 Speaker The Speaker is making a crackling sound while playing. The sound keeps cracking up.
You probably need to replace the diaphragm. The diaphragm is located behind the back cap. Simply remove the back cap, remove the diaphragm, clean the voice coil gap with a piece of masking tape, install a new replacement diaphragm, reinstall the back cap. That it!
You can see videos on how to replace diaphragm at this link.
You can buy a new Mackie SRM450 diaphragm at this link.
Jul 20, 2009 | Music
Mackie SRM450 won't power on.
I am also getting the same problem. Complete power off. Was working like a dream. No given signs that this would cut off. Sent this for repair, the current quote is £160.00 for the amp module to be repaired. I was hoping to find somewhere that can supply, repair, or change for much less; considering that It is worth est £250.00 second hand!
Jun 06, 2009 | Mackie SRM-450 System
Mackie srm450 the tops on one speaker is not working
Hi There, This is quite a common problem with the Mackie SRM450's. You will find that you need to replace the diaphram on the top. This can be done by removing the 16 screws from the back of the Mackie (quite a long pain in the **** job) with a long handled cross head screw driver.
Once you have done this you should then remove the hex bolts from the back of the drive where the black and right terminals are. When this is done, pull off the cover and swap the diaphram out. With the new diaphram in place reverse the steps above but before you screw the back on, power it up carefully and check the sound is now working.
If the diaphram keeps going eg every 3 to 4 months then you will need to change the driver which is quite expensive to do. If you need spares and are based in the UK, contact who carry spare parts or can undertake the repair.
Hope this helps.
Feb 22, 2009 | Mackie SWA1501 Subwoofer
Mackie SRM-450 System Logo
341 people viewed this question
Top Mackie Audio Players & Recorders Experts
Vito Vacirca Jr.
Shehu Pro
Shehu Pro
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
