IBM Aptiva E 240 (2158240) PC Desktop Logo
Posted on Feb 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I Need a power supply cord and a keyboard and mouse
I need these for a IBM Aptiva Model number 2176-C65 serial number 230W725
Anonymous
Level 3:
President:
  • Master 2,653 Answers
  • Posted on Feb 25, 2009
Anonymous
Master
Level 3:
President:
Answers
2653
Questions
Helped
744896
Points
7663
If it's a desktop 98% of them all use the same power plug. Just call any local computer repair shop and they'll sell you one for hopefully no more than $5.
1helpful
Hello, i currently use a IBM desktop with IBM keyboard and mouse but i just bought a microsoft wireless keyboard and mouse which i just installed into my desktop using the installation CD. They are both...
Hi Tony,
It appears that you have an IBM desktop whose BIOS isn't capable of booting off of a USB keyboard and mouse device. Older computers used to require that a PS2 mouse and keyboard be attached before booting, to prevent you from booting a machine without any way of controlling it. You have 3 options:
1. leave the corded mouse and keyboard attached and never use them
2. update the BIOS for your desktop to the newest one in hopes that the updated BIOS will allow for USB mouse and keyboard operation
3. go to a computer store and get a PS2 to USB converter/adapter. They're small and relatively inexpensive. It plugs into the PS2 port, and makes your computer think that there's a PS2 device connected, when it's actually a USB device.
3answers
How do I setup and IBM Aptiva to auto boot when the power comes o
It should automatically boot when you add power, without any intervention by you.
2answers
Re upgrade, memory, speed etc?
Upgrade the RAM/Memory? Yes to the maximum *********** Bord will support.
Upgrade the Processor for more speed on a 9 year old Mother Board? Probably not worth the trouble.
2answers
My dad's computer won't turn on
chessmaster2 has some good points... you need to make sure your computer is getting power first... a lot of motherboards have a tiny green light that is on when computers are plugged in but off. If you are not sure what a mother board is, then you probably can't do much more than what chessmaster2 gave you. By the way, if this computer is old, the majority of computer problems that you've described are because the power supply is bad. A lot of people don't regularly (2x a year) blow out the dust from their computer. So it collects dusts which then block the ventilation holes, so things overheat and go out, and typically that is the power supply.
Ok, I'm trying to help my dad, he's got an IBM aptiva 2174 model 572 s/n am71xp2. He's in AZ and I'm in CT. He said he got it to turn on the other day, used it, then shut it off and now it wont' turn on....
the cords etc only fit one way in one place... exploded parts view on computer equipment ? forget it, how do you think us technical guys survive ? :) seriously though, try checking the power delivery from the power cord before it plugs into the transformer, then check if the transformer is delivering power... voltage meter and common sense not to electrocute yourself ( or your dad in this case ) would be wise. further remove the battery and see if it works with the mains plugged in without a battery ( faulty battery perhaps )
Its more than likely the transformer though and these can be purchased at reasonable proces either at a dedicated IBM aftermarket parts supplier, IBM themselves or trawl the net...
good luck
Ibm wireless mice model ro07uo
Go to control panel and click on the Mouse icon. then when you get the Mouse Properties window, go to Buttons and go to the Left Button and using the drop down change the key to function as you desire. You will also have to reset the right button to use to double click to open programs. Hope this helps. Bud
2helpful
3answers
Which key to enter to bios to format pc IBM pentium III
del.. button on your keyboard old models may require F6
2answers
Dead
    1. Check your Keyboard-Video-Mouse (KVM) switch. If the system is connected to a monitor, mouse, and keyboard through a Keyboard-Video-Mouse (KVM) switch, or console selector switch, then disconnect the switch and connect monitor, mouse, and keyboard directly to the system. If this solves the issue, please contact your switch manufacturer for support and compatibility on the switch. Some switches can have a firmware update applied to resolve common problems.
      Note: BladeCenter Telco chassis - The KVM module contains keyboard port, mouse port, Power LED, Location LED, Critical Telco Alarm LED, Major Telco Alarm LED, Minor Telco Alarm LED and a video port. The PS2 keyboard and mouse connectors are standard 6-pin Mini Din. The Telco alarms mirror the Telco alarms located on the front panel of the media tray because they use the same signal lines. The KVM module allows the connection of a VGA monitor for system maintenance and control. The video connector is a standard 15-pin VGA. The KVM module is hot-swappable. It is docked into an edge card connector located on the backplane:
    2. If you have your system daisy chained for KVM capabilities using the C2T port (e.g. xSeries 330),
      then you must flash the C2T firmware after flashing the system BIOS, in order for the mouse and keyboard to work. Otherwise, after a BIOS flash, you will lose keyboard/mouse capabilities unless you walk up to each machine and push the select button.
    • If you are using NetBAY Advanced Connectivity Technology (ACT) CAT5 cabling in your rack server, instead of KVM cabling, click here for ACT information.
    1. Check for POST/startup errors. If you are getting a POST/startup error on the keyboard and/or mouse:
    2. Verify that all items are firmly connected to the correct ports, and that the cables are undamaged with no bent pins. The PS/2 style mouse and keyboard ports look identical, but are not interchangeable. The mouse and keyboard must be attached to the correct ports in order to be recognized by the system and to function correctly.
    3. Swap each item for known good units. If a new item works where the original did not, then the original component must be faulty.
    4. If the keyboard works during the POST/BIOS screens, but not in the operating system, check software logs for device driver errors. Contact your software vendor for more support in configuring the I/O devices.
    5. Check the F1 Setup error logs for system component failures or errors. These are found under Event/Error Logs. Troubleshoot suspect components further to determine if the hardware is faulty. If an IBM component is determined to be faulty, please contact your local IBM Support Center for warranty replacement of the part(s). Please have the Field Replacement Unit (FRU) / Customer Replacement Unit (CRU) part number and Machine Type, model and serial number ready.
    1. Run hardware diagnostics. Replace any parts found defective.
    Download the latest diagnostics for your system
    1. If you can down the system, check the keyboard cable connector on the system unit for proper voltage.
    2. Power off the system.
    3. Disconect the keyboard cable form the system unit.
    4. Power on the system and check the keyboard cable connector on the system unit for the voltages shown:
      PIN Voltage (Vdc) 1 +5.0 2 Not used 3 Ground 4 +5.0 5 +5.0 6 Not used
    5. If the voltages are not correct, replace the system board. Otherwise, replace the keyboard.
    6. If these steps have not solved your problem:
    7. [email protected]
    Monitor won't come on
    When you say the pc is working fine, it's hard to tell if there is no visual from the monitor. Are you getting the 2 usual spaced beeps when your pc boots up, is your keyboard ps2(normal pin type plug or USB)check you have keyboard and mouse in their correct connectors (mouse-green plug, keyboard-purple plug) I'ts more than likely had a bit of banging about in storage and especially if it's been in a cool area, then placed in your house, there may well be condensation points inside which may take a few days to dry out. Try your monitor in a friends pc to eliminate that first.
    Top IBM Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    ExpressFiX
    ExpressFiX
    Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
