Sony Bravia KDS-60A3000 won't power up 9 flashing red power light
Sony Bravia KDS-60A3000 won't power up. Power light on front of unit turns green when you power on and picture appears for two seconds then powers off with tthe power light turning red and flashing nine times. After 9 flashings of the red power light the system pauses and then repeatily does the same thing over and over again. I contacted Sony and they provided me with their troubleshooting solution to unplug the unit for a few moments from the wall outlet and then replug the tv back in and try again.....Did not work. Does anyone have /had the same problem and what was or what might be the problem and/or solution. Hope someone can help. Thank you, Don
  • mkiert Apr 11, 2009
    I have the exact same TV with the exact same problem. Help, please!
According to other posts I have read (I have same problem) there is no power getting to the fans. They recommend re-seating the fan harness again as it might have come loose or might have dust etc., in it.
I have no idea how to do this yet but that is what the trouble-shooting guide says.
Posted on Jun 06, 2010
How to get a picture on sony FULL HD 1080
Hi. Not shore of this model but could be a bulb replacement is needed, Or one of the filter covers may not be making contact.
The red light is indicative of error rather than working ( green ) or standby ( orange ).
I hope you get it sorted.
Sep 12, 2014 | Sony XL5200 LAMP - TV KDS-50A2000,...
My sony bravia kds-60a3000 loses picture, power button blinks, sound continues to work. The picture comes back on after an interval, then the cycle repeats. What is causing this?
Let your unit cool down for an hour, give proper ventilation and air flow. keep away all the obstruction from the vent, the processor has a built in thermal sensor that might be trigger by peak temp on the main board.
Hope it may help you.
Have a nice day.
Thanks for using Fixya.
Feb 10, 2011 | Sony KDS-60A3000 60" HDTV
Sony Bravia KDS-55A3000 while watching last night screen went black as if someone turned the TV off when attempting to turn it back on the the power indicator light flashes green repeatedly stops then a...
It sounds like the lamp has failed. It is advisable to use a genuine Sony lamp. The part number for is XL-5200. It will cost around 180.00. That should fix you problem. If you cannot find the lamp local to you can order it form Sony at.
1800-222-SONY
I hope this help,
Skyassoc
Dec 15, 2010 | Sony KDS-55A3000 55" HDTV
My Sony Bravia KDS-60A3000 tvturns its self off then back on within seconds. Some people say it is the lamp some say the ballast driver. What is your opinion?
Lamp,if it was the Ballast Lamp will not come on because Ballast Board is what Powers Lamp.
Mats has Lamps for $99.00 1-800-628-1118
Oct 06, 2010 | Sony KDS-60A3000 60" HDTV
I have a Sony Bravia KDS-60A3000. I changed the lamp, plugged in the TV and it was working. Was trying to reset lamp indicator, power went off, red indicator light is blinking and cannot get TV to turn off...
I went to another tech site and saw a suggestion to unplug the TV for a couple hours and then plug back in to see if this helped, but they also indicated this could be a serious power problem. I was really concerned, but tried it and it worked! I think it was running some kind of diagnostics after the new lamp was placed. Back up and running!
Dec 31, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Bravia KDS-60A3000 won't power up. Power light on front of unit turns green when you power on and picture appears for two seconds then powers off with tthe power light turning red and flashing nine...
First if you have had the set for at least two years, then its time for a new lamp. Replace your lamp and this should solve your problem. I don't know how long you have had ur television but lamps usually last about 6500 hours, thats a little less then 3years. But sometimes they go sooner. The lamp door should be located to the right of the unit on the side, if you are facing the television..
More Asistance email me at:
Delhielectronics@live.com
Sep 27, 2009 | Sony KDS-60A3000 60" HDTV
I have a sony bravia 60'' projection tv kds-60a3000. the problem is after a couple of minutes i will get no sound or picture. i disconnected the plug from my power strip for 5 minutes to cool down, then...
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
  1. Turn off the television. Unplug the television power cord from the electrical outlet.
  2. Let the television remain without power for 60 seconds.
  3. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  4. Turn on the television.
Sep 22, 2009 | Sony Televison & Video
TV(KDS60A3000) not turning on.
sounds like you need a new lamp
Sep 09, 2009 | Sony KDS-60A3000 60" HDTV
KDS-60A3000 new bulb gets 6 flashes of red led
Please put back lamp (bulb) cover properly and check as lamp cover is open/ not fixed or improper fix is also cause of LED flashing.
Jan 08, 2009 | Sony KDS-60A3000 60" HDTV
Televison & Video Logo
1,243 people viewed this question
Top Televison & Video Experts
