Question about Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor
25 gallon air compressor wont shut off,changed air regulator
Will not reach pressure of 125 pounds and wont shut off
  • 25 Answers
You have a valve plate problem . It could be a slipped "o" ring to a bad reed valve. There are rebuild kits for that purpose. The kits include a valve plate assembly. It covers all the bases. When you look at this area pay attention to the partitions of the head gasket/"o"ring. You may avoid the cost of the kit.
Posted on Feb 25, 2009
Why does compressor push oil through air filter when it shuts down ?
Minimum pressure check valve is bad. when unit shuts down air pressure goes back thru compressor and pushes oil out the air filter.
Jun 02, 2015 | Ingersoll Rand UP6-20-125 120 Gallon...
Compressor UP6 25 125, runs all the time but is only under load for a short time, should it shut down between loads?
This unit will shut down if unloaded for a set period of time. Usually 5 to 10 minutes. This time could be longer if some one has changed it from the factory setting. There is a timer in the control box that starts counting down when the unit unloads. If it stays unloaded long enough for the timer to count down the unit will stop until the air pressure drops to the low set point on the pressure switch. It will then start up. If the unit loads before the counter counts down the timer starts from the beginning when it unloads again. This cycle continues until you manually shut it down or you stop using air long enough for the timer to reach Zero and shut down.
Apr 22, 2011 | Ingersoll Rand UP6-25-125 120 Gallon...
Pressure switch dows not shut off motor when
Pressure switch has gone bad and needs to be replaced. Part runs around $25. Go online and put in model number, pressure switch. You will find companies that sell replacement parts. I had to replace mind, it did the same thing.
May 03, 2010 | Porter Cable 18 - Gauge Brad Nailer and...
Motor runs pressure stays around 25psi
if they are oilless compressors then the rings are worn
Jan 15, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Compressor 25 psi thats it
I assume it keeps pumping, but doesn't build any more pressure. That is probably bad valves or rings. If your unit has a crankcase breather, and it is puffing alot of air, look for rings. Otherwise valves.
Dec 15, 2009 | Campbell Hausfeld 26 - Gallon Air...
Compressor shuts off before reaching max pressure
Yes,but if the max is 125 you don't want to increase it above 110 and set off the pressure relief valve.
Jul 21, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
I have a 33g craftsmans air compressor oilless
have a 26 gallon air compressor , changed regulator switch but it still wont shut off
Feb 22, 2009 | Craftsman Air Tools & Compressors
Air compressor does not regulate pressure to set point.
Emglo airmate compressors are set from the factory to shut off at around 125psi. There is an adjustment (remove cover to pressure switch) that will controll the cut-off pressure but it is not recommended changing the factory setting. There is also a safety valve installed that will open at about 160psi. It is a small brass device with a pull ring. When things go wrong with the pressure switch (rectangular box with power cord coming out of one side) the safety will pop open. There is a pressure regulator with round knob on panel that will lower the pressure to the tool, however this regulator does not control the pressure switch. Let you compressor run untill it shuts off and verify pressure to be about 125, if it is then all as well. Good Luck
Jan 03, 2009 | Dewalt d55151 factory reconditioned emglo...
Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor Logo
728 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
