Question about Dryers
Dryer not heating
Our dryer was purchased in 2006 recently it quit heating .It is a maytag electric dryer model #mde308dayw
  • 547 Answers
Most likely heating eleament change you can find here as well as diagram http://www.partstap.com/ please rate me thank you for useing fixya
Posted on Feb 25, 2009
My maytage dryer mde308dayw drys the clothes, but it takes a longtime. The dryer heats, but water builds up around the inside of the door of the dryer.
You will need to clean the vent system on your dryer. Lint buildup restricts the airflow and will keep the clothes from drying.
Oct 17, 2011 | Maytag MDE308DAYW Electric Dryer
Please in very careful detail exsplain how to attach four prong plug wires to my maytag model no mde308dayw please help?
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 03, 2011 | Maytag MDE308DAYW Electric Dryer
My question is "How do
open dryer:
http://www.partselect.com/dryer+maytag-atlantis-open-cabinet+repair.htm
heating element:
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
May 22, 2011 | Dryers
I have a maytag dryer model # mde308dayw. How do you access the heating element to replace it?
remove 2 screws on the front cover by the floor lift bottom of front cover outward toward you and remove ,then undo wires at door switch,then remove drum belt and drum,then the heater element is at the right side near the base in a duct assembly
May 04, 2011 | Maytag MDE308DAYW Electric Dryer
Dryer won't come on - when you push the start button it just buzzes - what's wrong
I had a dryer not the same model like yours but It had the same problem.
Well it happens because of :-
Heating - When it heats then it stops untill its cool
I hope it helps
Dec 28, 2010 | Maytag MDE308DAYW Electric Dryer
Dryer won't start
On the bottom left is the heating element. On that element is a limit. If open the dryer will not run.ba9d1b0.jpgHere is an amana late model service MANUAL:
Apr 07, 2010 | Maytag MDE308DAYW Electric Dryer
What do i take apart the dryer to replace the heating element in my mde308dayw maytag dryer? the back seems to be attached to the sides and unable to remove. thanks
the steam on the front was 2 spring clips,one on each side in the front, use a putty knife to pop it up,then looks on the back wall and you will see the thermal fuse and the heater coil-mike
Feb 04, 2010 | Maytag MDE308DAYW Electric Dryer
How do you expose the heat element
Take of back of unit, unplug first. Heat element is near heat duct side with wires attached to it. Unscrew and slide it out. You could also put a tester to each wire to see if you have a complete connection. If ok check thermal switches, one could have gone bad.
Aug 17, 2009 | Maytag MDE308DAYW Electric Dryer
Dryer squealing?
you need to replace the felt around the door if it is not this it is in the motor and I would just use it tell it dies then replace. thank you for using fixya
Jun 19, 2009 | Maytag MDE308DAYW Electric Dryer
Dryers Logo
153 people viewed this question
Top Dryers Experts
