Question about HP Pavilion dv6000z Notebook
Blue and yellow lines on the screen
Do I need to replace the LCD screen or the backlight power board?
  • dragondoors Feb 25, 2009
    hooking the computer to an external monitor no lines
    Thanks for the Fast Response. It was a big help
    President:
  • 2,653 Answers
It's either the video card or the lcd. Try hooking the computer to an external monitor. If you get the same results on the external then it's probably the video card. If not, signs point to the lcd.
Let me know if you need any more help or info.
Posted on Feb 25, 2009
Parts needed for VIZIO TV with backlight out
You can fix it if you have some repair experience, you will need the power inverter board and/or the backlight lamps of the LCD screen, first try the power inverter board, the function of it is to up the voltage from 12/24/48V to a 800-1500V needed for the LCD back lamps.
Nov 17, 2014 | Vizio XVT473SV 47 in. LCD HDTV
Rca tv powers up has backlight no sound or picture replaced main board and inverter
I would check the input board for correct power supply input
check the blue 15pf 6kv caps near the output from the PSU to the inverter.
Aug 31, 2014 | RCA 46 46LA45RQ LCD TV
AUDIOVOX fpe3707hr power lights up blue screen but no picture
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jul 07, 2017 | Audiovox Televison & Video
Blank screen with blue light
Hello
Check the backlight inverter board to your TV. This is a common fault for most of the LCD TVs. If it is faulty, the backlight won't light up, resulting a balck screen with sound.
This is the picture of the backlight inverter board to your TV. OK.12_23_2011_4_29_45_am.jpg
Dec 23, 2011 | Sceptre X400BV-FHD 40 in. LCD TV
Hi. I have a 46" Samsung LCD (LN4661) and
Ysus board and backlight inverter. Need to be replace. I there any sound?
Thanks,
Dec 11, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
I have a 5 year old pdp-5050sx Pioneer TV, it has a yellow on the screen that goes from the bottom of the screen to the middle of the screen and it is a few inches wide. the yellow bar is also few inches...
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Check the CCFL lamps too, for low light emission, if the backlight of the TV is of CCFL type.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Aug 21, 2017 | Pioneer Televison & Video
My laptop started playing up, then i got a blue screen come up and it died. the computer now comes on but theres nothing on the screen. its a asus eee 904hd. do i need a new motherboard
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 06, 2010 | ASUS Computers & Internet
It looks like the bulb in the screen is burnt out. The screen is completely dark when fully chared.
You can determine if the bulb is bad by simply connect a monitor to the fifteen pin AGP port located at the side of your computer usually color blue. If your computer display the desktop on the monitor,you should change the bulb in your computer display.To change the backlight you need to follow these steps :Power off your Toshiba laptop and make sure the AC adapter is unplugged.
Remove the screws on the side of your laptop screen. Once the screws are removed, you can remove the plastic bezel (screen guard).
Pop the bezel out, exposing all of the LCD screen. Pull the LCD screen gently away from the computer by the corner. Be mindful that the screen is still connected to the computer by a ribbon cable.
Remove the tape over the ribbon cable where it connects to the screen, and gently pull the cable to disconnect it.
Turn the LCD face down, and remove the piece of tape that holds the top metallic foil against the back of the LCD.
Lift the metallic foil to expose the backlight. Remove the single screw at the end of it that holds it in place. Unclip the wire at the end of the backlight from the inverter (power source to the backlight), and remove it from the LCD. Replace it with the new backlight (available at any electronics store or online), and reassemble the device the same way you took it apart.
Aug 30, 2010 | Toshiba Satellite A105 Notebook
The screen is white >>>
Your inverter board is OK otherwise you will not get any light on the screen, there is only one inverter board, Check the flat ribbon cable connected to the LCD panel (locate behind the LCD panel), when this connector comes off you will get white screen.
Nov 06, 2009 | Sony VAIO VGN-CR510E/T 14.1" Laptop
BENQ FP731s Monitor Problem white blank screen
You have a serious problem. ie. only the back light is working in your monitor. You might need to replace the TFT associate components.
May 06, 2007 | BenQ FP731 17" LCD Monitor
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
