Question about Ovens
Ge range model # js968 has power but cooktop & oven don't work
I disconnected and reconnected the control panel via ribbon cable ... look for anything obvious. nothing. everything comes on but burners/cooktop and oven don't heat up.
  • 360 Answers
Check for proper power (control panel is 120V, burners and heat element are 240V) You may have lost connection in one of hot wires causing the burners/elements not to work yet the control panel still will
clarkco
Posted on Feb 25, 2009
F1 error code
F1 touch pad / ERC test
This simple test will help determine whether the ERC (Electronic Range
Control or Clock) or the touch pad is defective when F1 error code is
present.
Note: Some models incorporate the touch pad in to the ERC
as a single assembly, in which case this test is not necessary. Simply replace
the ERC (Clock).
Warning: If you feel in any way uncomfortable
performing this test or making this repair, please contact a qualified appliance
repair technician.
1. Disconnect power to the range (unplug the range
power cord or turn the power off to the range at the circuit breaker). It is
very important that the power to the range has been disconnected, so please
double check before continuing.
2. Gain access inside the control
panel.
3. Disconnect the touch pad (also called keypad or membrane switch)
ribbon from the ERC.
4. Make sure there are no lose wires, or anything else
that may cause a short when power is turned back on. Assemble the control panel
back the way it was.
5. Turn the power back on.
6. Wait for at least one
hour to see if the F1 code comes back (usually accompanied by a beeping
sound).
7. If F1 comes back, replace the ERC. If it does not, replace the
touch pad.
Feb 26, 2011 | GE Profile JKP56 Electric Double Oven
Have a GE Monogram Oven Single Wall Unit. Began Flashing F1 last night. Model GL2788960. Its hard wired so I turned off breaker let it cool down and turned back on. Still Beeping.
F1 touch pad / ERC test This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single
assembly, in which case this test is not necessary. Simply replace the ERC
(Clock).
Warning: If you feel in any way uncomfortable performing this test or
making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound)
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Dec 18, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
Ge double wall oven, model number jkp26gotibb has an f1 error code. Part is no longer available. Is there any other way to fix this problem with out replacing the whole oven.
(Clock).
Dec 16, 2010 | GE Built-In 24" Double Electric Wall Oven
Getting an F1 error. Oven shuts off F1 will not stop beeping
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
Read
Nov 21, 2010 | GE Profile JKP56 Electric Double Oven
Beeping with f7 display
HI this is a touch pad or key pad issue. In most models, the touch or key pad are integrated. In this case, you will need to replace the entire control board or EOC(clock).
Now, if the touch or key pad is separate from the main control board, and linked, via linking ribbon, i would advise to use the procedure below to isolate the problem area.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Oct 03, 2009 | GE Ovens
F7 erroe code on my GE oven
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Sep 01, 2009 | GE Profile JTP56 Electric Double Oven
F7 code and a random beeping
f7 err code means problem with the control panel.control panel needs to be replaced.if u like u can try for a temporary fix.open up the control panel by removing screws at the bottom of the conrol panel.disconnect the ribbon connector which comes from the control panel and connects to the control board.take a piece of paper towel and clean its end and put it back.some times this works.do not forget to turn of the power b4 doing this.
Aug 21, 2009 | GE Profile JTP56 Electric Double Oven
GE Single Ovwn control panel is indicating an F7 display model # JKP15WOA2WW
Fix the probelm, don't replace it with another of the same problem. Try this, it's gonna work! First of all, turn off the circuit breaker. Don't replace anything. The insulation in the ribbon cable is poor. The conductors in the cable are crossed. The ribbon cable is actually two ribbons pressed together, and the conductors between the two cables are shorting or becomming crossed. Lift the two cables apart, place a piece of paper between them, fold the edges of the paper over the cable so that it does not slip out, and make sure to shove it all the way down to where it will meet the plastic display panel housing. Turn the breaker back on. There, problem solved.
Aug 05, 2009 | GE JKP15 Electric Single Oven
GE Profile Performance Spectra Range error code F0
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
Jun 20, 2009 | GE JKS05 Electric Single Oven
F7 error code
Hi Kathryn, I believe that I have already sent you my solution via another route. Hope you received it. Basicaly for anyone else with this problem, it is caused by a short circuit envolving the ribbon cable which connects the touchpanel to the electronic control. The solution varies slightly depending on whether you have a metal or plastic touch panel. If you have a plastic touch panel,you need to add some extra insulation between the two pieces of ribbon cable in the slot where it exits the touchpanel. You need to slip it down as far into the slot as it will go. A piece of paper, a piece of file card, a thin piece of mylar will all work just fine. If you have a metal touchpanel, you need to insulate the edges of the slot as well with paper or mylar. Insulate both edges. If you don't have two sections to the ribbon cable, obviously you can't put insulation between the sections. If you have a plastic touch panel and only one section to the ribbon, you are out of luck. There is nothing you can do except to purchase a new touch panel. Cleaning the contacts is a myth. It doesn't help. Hope this helps. Please let me know your results. Contact me at hutchipop@yahoo.com. Regards, Charlie
May 08, 2007 | GE Profile JT910SASS Electric Single Oven
Ovens Logo
209 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
