Question about Goodman Heating & Cooling
I accidently added 12 oz of r410 to a r22 system,
The unit was running for about 10 or 15 min , I realized what i did and shut it down. If I reclaim all refridgerant. Can I just recharge with r22?
  • 189 Answers
Do a triple evac. Reclaim, flush with r22, reclaim, flush with r22, reclaim, flush with r22, reclaim. install afilter drier. Evac down to at least 200 microns. Recharge. you should be ok.
My concern would be disposing of the old "now blended" refrigerant
Posted on Mar 08, 2009
I have a trane air conditioner operating at 70psi low side pressure but with little to no temperature on liquid line by condenser but is cold to the touch entering the air handler
What type of refrigerant? R22- 70psi is good/ r410- 70 psi not good. What is the head pressure, is the filter clean, is the coil frozen, is the fan operating properly, all the supply air grills open...lots of things cause funky pressures. Need more info
Apr 05, 2017 | Heating & Cooling
On a cpkj 48-1B Goodman heat pump I am having condenser fan issues. runs full spedd for a while then cuts down to barely running, Even after changing the motor and capacitor.
Does the condenser utilise head pressure control to maintain head pressure? if so is the unit fully charged...r22. r410 Freon.If the unit is an older model. the fan motor only runs at 850 r.p.m design flaw. The newer units now run the fan at 1075. R.p.m. I have installed many Goodman split systems and was having problems similar to yours. Hope this. Helps you
Jul 11, 2015 | Goodman Heating & Cooling
Is it better to by air conditioners with R - 410 GAS OR R - 22 GAS
R410 units are cheaper now but not as effecient as R22, also R22 is much more expensive and most likely you would have to use R22 a to recharge unit if it as allowed where you live .
Oct 02, 2014 | Cfm Daikin R410a Split System Air...
Unit was charged w/ 10.6 OZ of R22 and don't seem to be working very good?
About 61 PSIG or 33 Degrees F. If you look at the gauge on your refrigeration manifold it will give you the numbers. What is Max, it changes with temperature and humidity and without very involved controls the absolute max will not be realized over the normal ambient operating range. Good Luck
Apr 20, 2014 | Fedders A7DH45B2A Dehumidifier
A home owner had their 4ton, R22 heating and air system replaced with a new 4ton, variable speed, 16 sir, furnace and two stage heat pump. The copper line set was not replaced. The existing copper line...
No, that will not hurt your new system as the old lines were vacuumed down and all of the R-22 removed...
You will be fine and it will not void the warranty...
Feb 03, 2011 | Heating & Cooling
I would like to know the correct way to take freon r22 out of an unit..
You must have a reclaim machine and a reclaim tank and the old refrigerant must be taken to an approved EPA site for recycling.
Jun 19, 2010 | Whirlwind FH-778 Air Conditioner
Can you put a 410a air handler with a r22 condensor
No. R22 and R410 are not compatible. R410 units operate at much higher pressures than a comparable R22 unit. These refrigerants also use different types of oil which are not compatible. If you need to replace half you might as well replace the whole unit because I was told that as of January 1 of this year you can no longer buy an entire R22 unit unless it is one a dealer still has in stock. They are phasing out R22.
May 19, 2010 | Carrier 38CKC036 Air Conditioner
How to pump down a ductless air conditioner split unit to remove
if the unit contains R12 or R22 you are not permitted by law to do the work yoiurself .. you have to have a "certified" person to reclaim the freon ... you might be able to get away with removing R134A (check local law) if thats what it has ... there is a service port that you can hook gages/hoses/vacuum pump up to .. (if not, then one must be added, usually in the form of a saddle valve that penetrates a low side feed pipe ... you should vent it into an approved tank or bladder (like a big balloon) for disposal or reclamation .. there may be a community service in your area that comes out and reclaims freon from old refrigerators and such .. in my area there is a free service that will reclaim the refrigerant and take away the old equipment .. i think its free or low cost .. some people simply vent R134 to atmosphere but that is polluting and may violate some laws .. R134 was thought to pose little hazzard but that is being reconsidered now in many countries
you can become certified yourself by attending a class and taking an exam that shows you understand the dangers and are aware of the law ..
Aug 20, 2009 | Carrier Heating & Cooling
I am wondering how you send the R22 back into the AC with just gauges instead of reclaiming into a tank.
shut off valve on sm line from unit in ac mode run unit until low side big line reads in vacume then shut the valve and pull disconnect on unit
Jun 09, 2009 | Whirlwind FH-778 Air Conditioner
Heating & Cooling Logo
199 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
