Question about HP OfficeJet 4255 All-In-One InkJet Printer
Printer keeps telling me to remove and check left cartridge, which i have done and have installed a new one, with the same message coming up.
  • 28 Answers
I'm not sure if this printer has one but some HP printers have a small ribbon cable that connects to the cartridge holder. There is a small wire spring that holds the cartridge in the holder, however this spring will puncher the ribbon cable rendering the printer useless telling the user to insert a new cartridge. Way to go HP.
Posted on Feb 25, 2009
I keep getting a msg saying carterage error on my printer
If you DID NOT use a HP cartridge you get the error message.
If you did use a HP cartridge. Unplug the printer. Wait 2 minutes.
Plug in the printer. If same error message. Remove cartridge and reinstall. Make sure no clear tape is left on cartridge contact face.
Jul 11, 2012 | HP Officejet 4355 All-In-One InkJet...
I keep getting message: "Remove and check ink
If you have already checked it by taking out and inserting it back then try this
Do it only if you have connected the printer by USB
1. Unplug the power cord
2. Press and # and 6 at the same time
3. While holding them plugin the power cord, you will see a message
SEMI FULL RESET on the screen
Release the buttons and let the Printer do what ever its doing
Jan 02, 2011 | HP OfficeJet 7310 All-In-One InkJet...
Keeps saying install c
When the printer says "install C" it is referring to the Cyan (blue) ink cartridge. If this is not a new cartridge, you might have to replace it. If this is a new cartridge, try following these steps.
1. Unplug the power cable.
2. Remove all 4 ink cartridges.
3. Close the ink cover
4. Plug the power back in.
5. Wait for the machine to warm up and tell you that the ink is empty.
6. Reinsert all 4 ink cartridges.
If you keep getting the same message you should try another cartridge. You can put the yellow cartridge in the blue spot to see if you get the same message. If you get the same message then the machine is broken. If you get a new message then the cyan cartridge needs to be changed.
Thanks,
Pat
Nov 09, 2010 | Brother DCP 130C All-In-One InkJet Printer
Message no cartridge when installing new cartridge. I have installed new ink cartridges but the printer keeps coming up with the message 'No Cartridge' Reinstall the cartridge. I have done this three or...
Hello ,
Start by opening your ink cover and read the LCD screen; this will alert you as to which ink cartridge is not being recognized; make sure the cartridge that it is telling you is empty has been changed.
If the unit is still not recognizing the cartridge you have changed, follow the steps below.
  1. Unplug the power cord for the printer unit.
  2. Open the ink cartridge cover and remove all ink cartridges.
  3. Close the ink cartridge cover.
  4. Plug the power cord back in.
  5. Reinstall the ink cartridges.
Thank you,
Pat
Mar 28, 2010 | Office Equipment & Supplies
''Check Print Cartridge'' light keeps blinking On HP psc 1210v AIO
Bad ink Cartridge, I got a new cartridge and within a week had the same problem replaced the cartridge and problem solved. To bad these things are so expensive.
Nov 17, 2008 | HP PSC 1210v All-In-One InkJet Printer
Keep Getting Error Message "(Colour) Toner Not Installed"
I think in the menu you have to select replace cartride.. then new or same with new toner...
each toner cartridge has connections and you must make sure all are tight... or you get alot of errors.
Sep 10, 2008 | Konica Minolta magicolor 2300DL Laser...
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Right cartridge incorrect" and "Left cartridge incorrect
    Many newer HP Printers internally keep track of your cartridges by a serial number embedded into the cartridge. When it's low, the printer remembers. This is entirely done within the printer itself, and not the printer software. Some printers EXPIRE the cartridges after 18 months according to the installation date even it is not empty.
    Outrageous, but true.
    A fix? Most HP printers will only keep 2 cartridges in memory, so if you have 2 extra cartridges, (even empty ones) you could cycle them through to reset the printers memory, and reset the ink level to full. Basically, even though you've refilled your cartridge, the printers has the cartridge's serial number stored in memory. This will reset it.
    Jun 02, 2008 | Dell 962 Photo All-In-One InkJet Printer
    Hp psc 2410xi photosmart all-in-one printer.
    Here's what I found when this happend on my two 7410's. Take a look at where the ink cartridge slides into it's holder. Shine a flashlight on the circuit board at the rear. You will no doubt find it has a puncture in it that breaks the little tracer wires on the board. The culpret is the tension spring arm. It likely has come off it's base support and when that happens, and you install a new cartridge, the cartridge will push the tip of the tension wire g right into the circuit board. After you fix the circuit board, apply some silicone glue to the spring base mount to hold it in place.
    Apr 16, 2008 | HP OfficeJet 7410 All-In-One InkJet...
    CARTRIDGE PROBLEM
    check ur cartridge if they have ink left, or replace new ink cartridge.
    Mar 07, 2008 | HP PSC 2175 All-In-One InkJet Printer
    HP OfficeJet 4255 All-In-One InkJet Printer Logo
    203 people viewed this question
    Ben Johnson
