Question about Sansui DTV2760 27" TV
No sound channels 2-13
Have sound from 14 on up but none from 2-13 EXCEPT channel 9
  • 790 Answers
Hi
you need to auto search your tv then test run if the symptoms is there search it manually
Thanks!
Posted on Feb 25, 2009
Audiosonic hdt909
Posssibly antenna orientation could be a factor. Also, STB suppliers recommend repeating channel search periodically so that missing channels magically appear.
Apr 22, 2014 | Televison & Video
I have a TCL L42M61AZ LCD TV. I find that the "Channel 9" programs in Adelaide, Australia, namely GEM, GO and Channel 9 DTV will not show a visual picture, only play audio. All other programs are...
A firmware update from TCL will fix the problem. Call them and they will send out the firmware and a serial cable (required for update) for free.
I did the update yesterday and it fixed the problem (sound but no picture).
You will need a PC or laptop with a serial port (RS-232).
Jan 26, 2011 | Televison & Video
My yamaha DSP AX1 amp does not work when audio is connected via optical or coaxial any suggestions how to correct this. no sound comes from any speaker except the subwoofer.
Are all the speakers turned off (set to None) in the speaker menu.(except the sub)?
2 channel direct analog stereo may still work, but any surround modes will use the speaker settings and the full DSP digital section.
Check also the input mode isn't incorrect - although if the sub is wired correctly and gives sound this can't be whats wrong.
Aug 26, 2010 | Yamaha DSP-AX1 10-Channel Amplifier
I AM ON CABLE. MY JVC AV-36150 PICTURE IN FINE ON
You`re probably getting a on air channel which means that you have to check your cable connectors and splitter if you got any, switch with other sets if you can.
Nov 01, 2009 | JVC AV-36150 36" TV
No sound channels 2-13 EXCEPT channel 9, which has sound
Try turning off the SAP in the menu. I hope this helps you.
Feb 25, 2009 | Sansui DTV2760 27" TV
TV problem
Might be as simple as you have the SAP or second audio progam turned on, go in to the sound menu of your set and see if it's set to S.A.P if so turn it to Stereo
May 15, 2008 | iLO 2600 Television
RX-V596 center and rear channels do not have any sound
Nevermind... My center channel output was set to "NONE" I've had this receiver for a few years now, probably set it that way back when I got it. Oh well, Helps to re-read the user manual...
The info is in the "SET MENU" section of the manual, Pages 35-38. Should solve the issue for "almccrum" above as well.
If you don't have your manual it can be downloaded here:
www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V596.pdf
Oct 06, 2007 | Yamaha RX-V596 Receiver
Sansui DTV2760 27" TV Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
