Question about Sunbeam 6198 Toaster Oven with Convection Cooking
Sunbeam toaster oven upper heating coil not working
Hello-- my sunbeam toaster oven's upper heating coil is no longer working-- is there a way to replace this piece? Or do i need a new toaster?
  • shawnie4blue Feb 25, 2009
    thanks for the info!
    i did try to get the element out & it doesn't seem easy!
    Gues its time for a new one! too bad
    President:
  • 267 Answers
The part (element) cannot be bought , its connectors are welded into place ........ if you realy love your oven , you can get one by shopping in a goodwill store for a used oven and cut the element out and cut and weld the element into your oven ........ this does work ,i have done it
Posted on Feb 25, 2009
    New Friend:
  • 3 Answers
I saved an element from another oven and it had bolt on wires not welded,fixed it just now in about 20 mins....but then again i am an appliance service tech
Posted on Nov 24, 2012
Can I get parts for a Bravetti convection toaster oven, specifically upper elements?
Fixya does not sell replacement heating elements. Try checking with a local appliance parts supplier.
Aug 22, 2016 | Euro-Pro EP278 Bravetti Platinum 1500...
To replace the upper heating coils(2)
Toaster ovens are inexpensive, may be better to replace the unit, then fix it.
Oct 13, 2013 | Toaster Ovens
I need an owner's manual for the Sunbeam 6067 Toaster Oven.
Sep 08, 2012 | Sunbeam Toaster Ovens
Need heating element (upper) for GE168947 toaster oven
You should be able to install a new replacement element or a used element from another GE168947 toaster oven.
Jul 03, 2012 | Toaster Ovens
This toaster no longer toasts food evenly, it takes twice as long, it appears that the broiling coil element may not be heating...Can these elements be replaced?
the elements can be replace, BUT, it is just not cost effective. you can buy a new toaster for less the the cost of repair.
Jan 03, 2011 | Cuisinart Toaster Ovens
The toaster (upper) part of our 4-slice toaster oven model 6067 suddenly stopped working after several months of using it consistently. Will return it to Target but hoping it's an easy fix. We kind of like...
Hi there. I just repaired mine. The wire connected to left side (as you are looking at the front of the toaster) of the front top heating coil had come off. I replaced all four of the crimps going to each side of each of the top two heating coils as well as the wire going between the front and back coils on the left side. Make sure that you use HIGH TEMP crimps and HIGH TEMP wire. I had the crimps and purchased the wire from a ma and pa repair shop here in my town1_24_2012_10_47_09_pm.jpg
Jan 01, 2011 | Sunbeam 6067 Toaster Oven with Convection...
Heating element no longer works. is there a fuse or is it the coil that's the problem?
I had the same problem and discovered it was the plug on the heating element was loose. I'd check continuity with a ohm meter across the coil. If it shows a closed circuit there isn't anything wrong with the element itself and could be as simple and cheap as tightening up the connector.
Dec 28, 2009 | T-Fal Avant Elite OT8085002 Toaster Oven...
Sunbeam 6198 Toaster Oven with Convection Cooking Logo
1,234 people viewed this question
Top Sunbeam Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
Are you a Sunbeam Toaster Oven Expert? Answer questions, earn points and help others
